Old 01-24-2018, 10:03 PM   #29
JCunningham
JCunningham's Avatar
Drives: 2017 2SS M6
buy the oem take off wheels they are forged not cast like all the aftermarkets that try to trick you by calling them flow forged. you wont pay much more and they are more than worth it.
7literc5 go to the for sale wheel section to see what other people are asking.
Old 01-25-2018, 12:08 PM   #30
Carlos_MRRWheelsInc
Carlos_MRRWheelsInc's Avatar
Drives: camaro
Ouch tricking?? thats sad, is not a trick when a aftermarket company is showing you a wheel manufacturing process.
example OE factory " Forged "wheels from the Camaro platform
weigh in at 32lb
yet a aftermarket company can produce a wider rep using a Flow forged technology/ rotary / flow/ you name it is the same and weigh less then the factory wheels by 5lb minimum each.
kind of makes you think who is tricking who right. just saying.
Chevrolet makes such an awesome vehicle but I personally feel they can shave some weight off the factory wheels easily.
Carlos_MRRWheelsInc is offline   Reply With Quote
Old 01-25-2018, 01:18 PM   #31
JCunningham
Drives: 2017 2SS M6
flow forged
Old 01-26-2018, 02:28 PM   #32
Carlos_MRRWheelsInc
Drives: camaro
flow forged
lol thats a whole other story
Old 06-25-2018, 09:23 AM   #33
ch_swat_89
Drives: Camaro 2SS, AT, 2012
Hi there
I'm trying to get these wheels testet here in switzerland. I'm looking for an official dokument from gm. Important is the allowed weight.
Does anyone can provide some official dokument?
GM23355790
GM23355801
Regards
ch_swat_89
ch_swat_89 is offline   Reply With Quote
Old 07-04-2018, 09:50 PM   #34
jeffs42885
Dunder Mifflin
Drives: 18 ZL1 / 13 SRX (Daily)
Not stock. But I have a set of z28 reps off my ZL1 for sale
jeffs42885 is offline   Reply With Quote
Old 04-23-2021, 03:54 PM   #35
Albert312
Drives: 2016 camaro ss
Your stability light didn’t turn on with different diameter tires? I have zl1 wheels and looking to up the tire size
Albert312 is offline   Reply With Quote
Old 05-12-2023, 09:19 AM   #36
Vdubz
Drives: 2022 LT1 Camaro
Resurrecting in case anyone wants to see ZL1 Wheels on a LT1.. also fits!
Vdubz is offline   Reply With Quote
Old 05-19-2023, 04:40 AM   #37
Wintermute
Wintermute's Avatar
Drives: 2020 LT1
ZL1 rims on my LT1. PS4's 285 front, 305 rear, no clearance issues so far. Installed the BMR carriage lockout kit at the same time. It's like a whole new car.
Too weird to live, too rare to die.
Wintermute is offline   Reply With Quote
Old 05-21-2023, 09:37 AM   #38
Plasar
Drives: 2017 ZL1 Vert M6
Originally Posted by cmeJATT View Post
1LE and ZL1 are the same size...
Jeez, this is complicated… the SS 1LE and base ZL1 are the same…. The ZL1 1LE is 19” rims and even wider - 305/30ZR19,325/30ZR19
Plasar is offline   Reply With Quote
Old 06-27-2023, 06:04 PM   #39
JBinSD
Drives: '23 LT Vert M6'16 Hyper 2SS Vert MT
Agreed. Has anyone put the ZLE (ZL1/1LE) 305's/315's on an LT1? Considering but concerned it will have rubbing or the wire relocation issues. Fender gap does seem to increase with the lower profile/wider wheels too.
JBinSD is offline   Reply With Quote
Old 11-29-2023, 07:15 PM   #40
Kevin76
https://www.instagram.com
Kevin76's Avatar
Drives: 2018 Camaro SS 1LE
I added the ZLE wheels to my SS 1LE running 305/325 tires. Instead of a spacer I did a clearance grind on the strut. You definitely need to relocate the wire harness on the rear drivers side.
Kevin76 is offline   Reply With Quote
