Old 04-27-2017, 11:39 AM   #29
glamcem
glamcem's Avatar
Drives: '19 RivrsdBlu 1LE ('17 1LE HB sold)
Originally Posted by Evolvedx27 View Post
so you can reuse the hats from 1LE/ZL1? or buy new?
I was able to install them on OEM hats so I will be using them, yes. Not sure about the ZL1 though since rotor size is different.
glamcem is offline   Reply With Quote
Old 04-27-2017, 05:56 PM   #30
TrackReady1LE
Drives: 2017 Camaro SS 1LE
So you just decided to ditch the oem rings or are you keeping them around? I am really curious how these will do at the track. I realize that these are a few pounds lighter and thus the unsprung weight benefit is four fold vs sprung weight; but with the loss of mass that would also decrease thermal capacity. I know the brake cooling on these cars is excellent, so I'm curious how the loss of thermal capacity will impact braking across a session. Will you be running this setup with the same pad at the same track to do some direct comparison between these and oem rotors. Also curious what the thermal paint on the rotors will tell you. Really looking forward to your results.
TrackReady1LE is offline   Reply With Quote
Old 04-30-2017, 09:43 PM   #31
glamcem
glamcem's Avatar
very good points. I also thought about that too but noticed that the OEM pin points were a bit different and thicker than the DBA rotors so part of that 1.3 lbs weight difference might be coming from there. In addition to that, material and cooling differences between the rotors may also be a factor. I heard nothing but good things about the DBAs but until comparing the two at the track it will be hard to say anything just yet. I will be using the same exact pads (I always use ST43s) and do my tests at the same tracks.
I still have the OEMs and am planning to use the DBAs once the fronts need to be changed since I don't want to change them back and forth. I never used thermal paint before but it may be a good idea.
Old 04-30-2017, 09:54 PM   #32
TrackReady1LE
From what I saw on the website those rotors should come with thermal paint on them from DBA, which should be a nice indicator for everything.
Old 04-30-2017, 10:03 PM   #33
glamcem
glamcem's Avatar
hmm good to know, thanks
Old 05-02-2017, 12:23 PM   #34
glamcem
glamcem's Avatar
How the OEM rotors look after three events (or maybe I should say two since the first two was not full event with many hiccups):
Plenty of life on ST43s as expected
Old 05-02-2017, 12:45 PM   #35
TrackClub
TrackClub's Avatar
Not too many heat check cracks eh?
Hard to tell from the pix exactly but are those GROVES on the rotors?
Old 05-02-2017, 12:59 PM   #36
glamcem
glamcem's Avatar
Nothing besides some hair cracks
I couldn't feel anything on the surface I believe it's just the coloring
Old 05-02-2017, 01:01 PM   #37
TrackClub
TrackClub's Avatar
Awesome Really impressed this car can be beat up on at a track with everything "stock". Impressive!
Old 05-02-2017, 01:06 PM   #38
glamcem
glamcem's Avatar
exactly, it's bone stock except the Motul RBF600 and ST43s and a bit more aggressive track alignment.
Old 05-02-2017, 02:34 PM   #39
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
For comparison:
Spidery cracks in rotors by Ryephile, on Flickr
This is 3 full days with the Power Stop pads. Mine looked similar to Glamcem's after the 2nd full track day.
Old 05-02-2017, 03:19 PM   #40
Th3Beast
Th3Beast's Avatar
Drives: 2017 SS 1LE
Originally Posted by Ryephile View Post
For comparison:
The Power Stop Track Day pads? If so, how did you like them? I bought a set and have them in my garage ready to go in.
2017 SS 1LE (sold)
Nightfall Gray
Th3Beast is offline   Reply With Quote
Old 05-02-2017, 03:38 PM   #41
Ryephile
Hot Dog
Ryephile's Avatar
Drives: '17 1SS 1LE
They're good, I recommend them, and for the price they're a steal. Roughly equivalent mu to a Carbotech XP12, though it feels like their peak decel is in the middle of the heat range. Once I get them cooking the mu drops off a bit. Given the IR gun temps I saw in the paddock last weekend, the car needs better brake ducting regardless of what pad you run.
Old 05-02-2017, 03:44 PM   #42
MatthewAMEL
MatthewAMEL's Avatar
What temps where you seeing?
2017 HBM SS 1LE
Sold
2023 Wave Metallic
CT5-V Blackwing M6
2025 Hysteria Purple
C8 Z07
