Old 04-13-2017, 04:18 PM   #29
CCS71
LFX to LT1
CCS71's Avatar
Drives: 2017 Camaro Fifty 2SS M6
Originally Posted by Glen e View Post
You might polish the car with carpro essence. It says that it you can use it over coating.
http://www.autogeek.net/carpro-essence-xtreme.html
Wax will cause spots. I would run as far away as I could from the guy that told you to acid wash the car
But yeah, once you do a rinseless you will be amazed.
I thank you and my Camaro thanks you. Will get up to date with DIY detailing and research the products listed in this thread. But, I'm not as old school as I originally thought because someone today asked me if I used a chamois to dry my car.....(insert shrill horror movie scream).
2013 Rally Yellow 1LT - Traded
2017 Camaro Fifty 2SS; Sequence #270 - Sunroof/Nav/NPP/MRC/6speed
CCS71 is offline   Reply With Quote
Old 04-13-2017, 06:45 PM   #30
Joe M 2012 2SS
Joe M 2012 2SS's Avatar
Drives: 2012 2SS
Originally Posted by CCS71 View Post
I appreciate the suggestions. In summary, RINSELESS is the overwhelming favorite.
Okay, maybe this is the area I need more guidance on. I did not use any product over my ceramic coating for 8 whole months, then got annoyed with water spots. The recommendation was to wax the car after giving it an acid wash. I played it safe. What should I have done differently?
If your coating needs a "boost", Carpro has a newer product out called Essence Plus. Unlike Essence, it contains no abrasives, but will fix minor imperfections in your coating.
The regular Essence is used under the coating, the Essence Plus on top of it.
https://www.carpro-us.com/compounds-...oss-agent-8oz/
Roto-Fab intake, SW 1 7/8" LT w/hi flow cats, Flowmaster outlaw exhaust, UDP, 160* stat, Circle D 3200, Moroso catch can, TCI line lock, Zex Nitrous 125 shot, 3.91 gear, Eaton True-trac, DSS 1000hp axles.
Joe M 2012 2SS is offline   Reply With Quote
Old 04-13-2017, 07:25 PM   #31
Glen e
Retired from Car mfrs....
Glen e's Avatar
Drives: 2LT RS/HR-V
Excellent, I stand corrected....essence plus it is..../
Old 04-13-2017, 07:57 PM   #32
Joe M 2012 2SS
Drives: 2012 2SS
Easy oversight, no big deal.
Old 04-14-2017, 01:24 PM   #33
Nor Cal ZL1
Nor Cal ZL1's Avatar
Drives: 2013 ZL1 M6
Coatings are subseptible to spotting and there are a couple of ways to handle them. One is to use this, or simular product dedicated to this specific task.
http://www.autogeek.net/gyeon-water-spot.html
http://www.autogeek.net/carpro-spotl...t-remover.html
The other is a quick polish with this.
http://www.autogeek.net/carpro-essence-plus.html
If severe a very light polish with this will leave the coating intact. This is the last resort method. And very light. Using this it is best to apply another layer of coating, or a topper of choice such as essence plus, and detailing mixtue as needed.
Start with the dedicated spot remover.
Nor Cal ZL1 is offline   Reply With Quote
