#29 |
Okay OP, so if I lift with the pinch welds in the front and carefully set up a jackstand on that spot you mentioned, that may work well.
What about the back? That is where I scratch my head.
#30 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2017 Camaro 1SS M6 Join Date: Apr 2015
That area is pretty thin sheet metal and seems marginal to use as a jacking point. I think that will cave in some with a jack stand there. Be careful!
#31 |
![]() ![]() ![]() ![]() ![]() Drives: '17 ZL1 Join Date: Jul 2016
That steel can crush when you lift the car up from it. It's thinner than it looks. Trust me. I have seen it crush.
The pinch welds are by far the best way to go. |
#32 | |
![]() ![]() Drives: '17 Red hot 2ss, 16 Focus RS Join Date: Aug 2015
#33 |
Custom Black FiFTY
Thanks for this....was considering dropping $60+ on them but I think I'll pass.
Wanted a F1FTY edition but decided to make my own
#34 |
Lethal Camaro
Drives: 16 2SS, 71 Std, Suburban RTS Join Date: Jun 2013
Using a 4 point lift you can pick the car up from the steel areas, but GM is quick to point out you should only lift the car from the pinch welds. I actually jacked my first car up from the place you put your bowl and watched it collapse. But that was jacking it from one corner, a 4 point lift evens out the weight and would avoid that issue.
Are jack pads or mag pads needed from ZL1addons, No. Do they make things easier? Yes. They also make me feel a hell of a lot safer when my car is lifted from thin pinch welds. I highly encourage you to myth bust the GM booklet telling you where to jack the car up from, as that point in not one of them and you will watch your car collapse that thin steel.
#35 |
![]() Drives: 2017 Camaro SS FIFTY Join Date: Dec 2016
For vert owners its even more fun with the cross braces taking away for of the pinch weld points.
#36 |
SABIO
Hey 00 Trans Am thanks for the honest opinion. There are other good places to lift your car as long as proper weight distribution is considered.
Do you need a donation or anything?
#37 |
![]() Drives: 2017 Camaro 2SS Conv A8 Arctic Blue Join Date: Feb 2017
#38 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
It's not just the heavy-gauge steel that you're fitting the jack pad up against that matters, there's whatever lighter-gauge metal that it is attached to as well. I realize that the body structure of your car differs from that for mine, but I found out the hard way that the footwell sheetmetal could be popped slightly out of shape by jacking on a similar heavy-gauge piece underneath it - with no visible indication whatsoever that anything had moved. The give-away was an oil-can popping sound (and I could feel the movement as well) when pressing weight on the floor with my foot to get out of the car that wasn't there before. I doubt that anything was structurally compromised to any great extent, but this was a real effect, where the floor had buckled just a tiny bit inward. Pay attention to any insignificant-seeming changes if you decide to continue using this procedure. Norm
'19 WRX 6M (the family sedan . . . seriously) |
#39 | |
![]() Drives: 2017 Camaro 1LT HBM Join Date: Sep 2016
#40 |
My 2 cents, sorry, I bought those bolt on things to lift my car, for the Jack a$$s that don't know how to lift it. I have jacked my car up with NO (no damage) problem.
I guess you gotta be a little smarter the the car...lol |
#41 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Wife's 14' IS 250 Join Date: Mar 2014
How about jacking from that bolt? Next to where the bowl is stuck to? In the other video he mentioned that it was also aluminum & would buckle?
-11% tint all around Ordered • 2/06/16 Built on • 3/22/16 Adopted • 4/07/16 Sold on 2/05/16: 2014 Camaro SW L99, 2SS, RS, NAV, Inferno Orange Interior: -Borla ATAK catback -Range AFM delete -15% tint all around -Red LED interior bulbs -55k white Cree LED fogs -License plate LED bulb swap -12" Sub Kit, BA amp swap -Oracle ghosted LED sidemarkers |
#42 |
Lethal Camaro
I have personally seen that bolt point buckle when jacked from that bolt point only.
