Old 04-03-2017, 11:18 PM   #29
Vintage
Drives: 2017 SS 1LE
Originally Posted by AZ_1LE View Post
My previous car was an RS4, which had DI.
When I can hear the ticking sound bouncing off of walls and cars, it's not normal.
take in in ASAP - better safe than sorry
Vintage is offline   Reply With Quote
Old 04-04-2017, 04:38 PM   #30
AZ_1LE
Drives: 2019 ZL1 1LE
Not sure if you saw my other reply, but I did take it in and they basically shrugged it off.
Thing is, I'm annoyed at either of the two prospects.
1 - The noise gets worse and they eventually have to replace the heads.
2 - It makes this noise for the rest of its life.
Either of those, suck. I'd rather have them just fix it, but I know I'd be without the car for weeks. But for now, I hear the noise all the time since that rev range (1600-2000) is right where I run it a lot just cruising around, to/from work, etc.
Old: 2017 SS 1LE
Old: 2017 ZL1
Current: 2019 ZL1 1LE
AZ_1LE is offline   Reply With Quote
Old 04-04-2017, 04:48 PM   #31
AZ_1LE
Here's a new video I got today. I'm starting to hear it between 2000-2400 rpm now.
Old: 2017 SS 1LE
Old: 2017 ZL1
Old 04-04-2017, 04:59 PM   #32
WhyUMad1LE
Drives: 17 SS 1LE
Try a 0W40 synthetic oil.
Old 04-04-2017, 05:07 PM   #33
AZ_1LE
I did for a little while, didn't make a difference :(
Old: 2017 SS 1LE
Old: 2017 ZL1
Old 04-04-2017, 05:14 PM   #34
SSDan
SSDan's Avatar
Drives: 2016 1SS 6MT NPP
I hear it and I would agree that it sure sounds like valve train noise more so than injectors. I'm not saying it is or isn't normal but its your car and you know better than anyone else when it sounds and runs right and when it doesn't
FWIW - my fifth gen was a cam bolt-on car and it started making the same sounds as yours at only certain rpms. I was concerned and everyone else including the shop who did the cam install said - don't worry - the valve train noise is normal for a cam/header car. I decided to just live with it as maybe I was just paranoid for no reason. Well, 17 K miles after the cam swap the lifters and cam started eating each other, a lifter turned and the roller tip started skidding over the cam lobe instead of rolling over it. Bottom line - I had to rebuild the whole top end. I wish I had not ignored the situation and taken the car to another shop to have the valve train fully inspected to rule out what my gut was telling me.
I wish you the best and keep us posted.
476 rwhp/440 rwtq (sold)
Old 06-22-2017, 12:49 PM   #35
AZ_1LE
Update - 1,000 miles later, it's still making the same noises, unfortunately. I switched to Pennzoil's Euro L 5w-30 Dexos2 oil about 500 miles ago which hasn't helped the noise at all.
I think i'm going to schedule an appointment with the dealer to have them really investigate this and also have them take care of some other things while I'm there. I have a feeling the noise is going to get worse and worse until something major happens. In the meantime, it's actually a little embarrassing as I've had some friends ask what the noise is.
Old: 2017 SS 1LE
Old: 2017 ZL1
Old 04-24-2018, 05:18 PM   #36
soloknight6
SoCal HT5! SD
soloknight6's Avatar
Drives: 2016 red hot 2ss M6
Mine has sounded 100% identical for the last 10k miles. @19k now. Many LT1 SS's Ive seen in my car club also sound the same. I think its a combination of a noisy valve train (as mine seems to have gotten slightly worse with mileage) and the high pressure injectors. If the dealership finds anything, please keep us posted.
On a side note, if you've switched oil weights and noticed no change in the noise, then its likely just the injectors. European brands (especially luxury brands) do a lot to hide the injector noise on DI engines. Frankly, they are on another planet when it comes to build quality and comfort (ever listen to a diesel audi?)
My mini cooper had quite a bit of sound insulation integrated in parts around the engine to quiet the noise.
EDIT: Holy necro batman! How'd I do that?! Well, I guess the OP's car is normal.
soloknight6 is offline   Reply With Quote
Old 04-24-2018, 10:42 PM   #37
R3ctivision
1LE Convert
R3ctivision's Avatar
Drives: 2018 ZLE
My car sounds the same, I don't worry about it.
R3ctivision is offline   Reply With Quote
Old 04-25-2018, 12:36 AM   #38
AZ_1LE
Actually, after doing an oil change and putting in some Valvoline MST 5w-40 dexos2 for a track day a few weekends ago, I almost immediately noticed a lot less noise. The lifter tick at 1700 and 2500 rpm went way down, but it is definitely still there. I'm still running the oil.
It's annoying/distracting, but I'm just keeping my dealer updated and reminding them whenever I take it in for service.
Old: 2017 SS 1LE
Old: 2017 ZL1
Old 04-25-2018, 12:47 AM   #39
soloknight6
SoCal HT5! SD
Awesome news then. Maybe this is why GM engineers changed the Oil spec on the LT1's a couple months ago to the new 0w40 from mobil 1. I have been running 5w30 mobil 1 every oil change. Im hoping the new spec will quiet down the car.
Old 04-29-2018, 11:56 PM   #40
Cgocifer
Cgocifer's Avatar
Drives: 2018 1SS 1LE, 2015 RAM Ecodiesel
Mine sounds similar, kinda embarrassing.
Wait, what? The oil is now supposed to be 0w-40 for all time use? I thought that was just for dry sump vettes.
I just changed the oil and put in 5w 30.
Is there a copy of the bulletin for Camaros somewhere?
Cgocifer is offline   Reply With Quote
Old 04-30-2018, 09:00 AM   #41
Eldi Z
Drives: 17' 1SS 1LE GBA-Black
Here you go...
Old 04-30-2018, 09:08 AM   #42
Eldi Z
Basically, any of the oils (and oil grades / viscosities) which are on the Dexos2 certified list are approved for our motors. There are a number of W40 oils in there as well, which are perfectly safe to use:
https://www.centerforqa.com/dexos-brand2/
