Old 03-27-2017, 02:51 PM   #29
HyperBlueX2
Old 03-27-2017, 03:38 PM   #30
TECHTURTLE
TECHTURTLE's Avatar
So the belts are on and the pump is installed. It's a little tight getting the pump bracket bolts in and out so a 10mm gear wrench is your best friend here.
2016 2SS 6-Speed Manual... Magnetic Ride Control, Dual Mode Exhaust, Sunroof, Adrenaline Red Interior, Mylink W/Navigation
Added
Edelbrock E-Force Supercharger, GM 1LE Sway Bars, BMR Upper/Lower Trailing Arms, BMR Upper Control Arms. BMR Front/Rear Chassis Braces, BMR Tunnel Brace. GM Red knee Pads, GM Black Front Splitter, GM SEMA Concept Grille, GM Dark Taillights, GM Ground Effects package... Savini Di Forza BM-14 Gloss Black Wheels 9's front, 10's rear.
TECHTURTLE is offline   Reply With Quote
Old 03-27-2017, 04:10 PM   #31
nick_casper
nick_casper's Avatar
Drives: 16 2SS
Almost to the balancer bolt install. Thanks for the updates and let us know howit goes. This is the only part causing me concern.
2016 2SS, A8, Whipple 3.25 pulley, Mishimoto catch can, C7 Carbon fiber splitter and skirts, GM black brake and tail lights. PLX wideband O2/HP tuners. Apex VS-5RS in 19x11 and 19x12.
nick_casper is offline   Reply With Quote
Old 03-27-2017, 05:12 PM   #32
TECHTURTLE
TECHTURTLE's Avatar
Post #27 edited to include the bolt install.
Added
Old 03-27-2017, 05:17 PM   #33
nick_casper
Drives: 16 2SS
Nice. How did you keep the crank from spinning. In the old old SBC days I would use a prybar in the pulley opening to lock it against the block. The Whipple install calls for just a torque number, not degrees.
Old 03-27-2017, 05:17 PM   #34
TECHTURTLE
TECHTURTLE's Avatar
The tensioner bracket and all the pulleys are now installed. When installing the tensioner bracket be sure that the engine wire harness is loose and out of the way. The steps before have you deal with the harness but I took it all loose again to get the bracket in.
Added
Old 03-27-2017, 05:21 PM   #35
TECHTURTLE
TECHTURTLE's Avatar
Car in 6th gear with the parking brake on and the back wheels on the ground. The car did move forward just a little until all the slack came out of the drive train then it stopped. But that was just at the very top of the torque range.
Added
Old 03-27-2017, 05:30 PM   #36
brettman
Drives: 2016 Camaro SS
Sent PM.
brettman is offline   Reply With Quote
Old 03-27-2017, 05:49 PM   #37
toro1966
toro1966's Avatar
Drives: 2017 Camaro SS Convertible 50th
Originally Posted by brettman View Post
Some more food for thought. I'm installing my SC also, I downloaded and printed Elderbrock, Maggie and Whipples manuals. Some info is in one and not the others and vice versa. I'll just cross reference between them. Good luck on your install, I'll be watching.
Do you have the Whipple manual? I have been unable to locate it.
toro1966 is offline   Reply With Quote
Old 03-27-2017, 05:53 PM   #38
TECHTURTLE
TECHTURTLE's Avatar
Okay I'm done for the night. Again the directions did leave out a minor step or two but nothing you can't figure out as you go. The biggest problem of the day was that stupid AC stretchy belt. After messing with it for over an hour and trying to modify my install tool (Grinding and cutting) to no avail. I then called Jannetty Racing and Nick set me straight. 5 minutes later, it was done, a little information goes a long way. Lesson there is if you run into trouble don't go it alone call one of our vendors here on C6 these guys do this stuff every day and are full of useful tips. They will save your butt and it's much appreciated that they will take the time to help.
So after another day on the install, I'll still say that a home install is doable for anyone that can read directions and has some mechanical ability.
Added
Old 03-27-2017, 05:53 PM   #39
brettman
Yes, Contact Whipple, Ask for it, they will E-mail you the link.
Old 03-27-2017, 05:58 PM   #40
toro1966
toro1966's Avatar
Thanks!
Old 03-28-2017, 08:39 AM   #41
TECHTURTLE
TECHTURTLE's Avatar
Since I'm waiting on the fuel line extension, I'm going to have to skip a few steps today and head to the inter-cooler install. Looks pretty straight forward but we'll see how it goes.
Added
Old 03-28-2017, 09:15 AM   #42
MR 45TH
MR 45TH's Avatar
Drives: 2018 ZL1
I'm not doing an E-Force, but great write up for those that are
2018 ZL1…Many mods to come
MR 45TH is offline   Reply With Quote
