#29 | |
![]() Drives: 2016 1SS D1SC Methfed Lowered Wrapd Join Date: Apr 2016
#30 | ||
Drives: Many C7's Join Date: Apr 2014
2) I don't run catch cans on these cars that I tune, because they have a factory catch can stock, and I haven't seen a reason to use something different. LT motors don't have consistent ring gaps. And are very right motors. The last motor I pulled apart had (2) pistons with rings at 9 thousandths. And the other (6) pistons were at 12 thousandths.... If you run over ~600 HP, and do a LONG highway pull (something more then a 1/4 mile) with that kinda tight ring gap... I can tell you what happens. The piston gets hot, the rings get hot... and the rings will "butt" together. When that happens, kiss that pistons middle ring area goodbye, And say "Hello" to loads of blow by. (and a set of replacement pistons) There is NOTHING in a tune that can prevent that kinda damage. To tight of rings = kiss of death for a high HP motor. |
#31 |
Drives: Audi S6 V8TT, Volvos XC60 & S60R Join Date: Feb 2016
#32 |
#33 | |
![]() Drives: 2016 Camaro 2SS M6 Join Date: Mar 2017
Thanks for this info!!
715whp/665tq
#34 |
![]() Drives: 16SS-A8-Magnuson-SW-Gforce Join Date: Nov 2016
I think you need some dyno pulls with everything monitored. Those are crazy IATs. Im in Denver with 15psi from a magnuson and I see 100 to 115. DA is usually 6500ft
#35 |
He has done many dyno pulls, checking everything and has not yet seen temps like those on the highway. That Dyno is a Dynojet, I believe it does not put the same load on the engine as a good uphill WOT run does.
#36 |
How bout taking a laptop with hp tuner on it to log the WOT run?
#37 |
#38 |
Has anyone installed a second IAT sensor and if so, how?
I am considering putting a small temp reader in the charge air pipe, any ideas? Thanks to all. |
#39 |
#40 | |
![]() Drives: 17 Camaro SS2, 93 C1500 Silverado Join Date: Jun 2016
Something like this? and for testing I would just stick it in the IC outlet pipe and clamp over the cable with the silicon hose, 10ft cord should be enough? Perhaps this way you can be 100% sure temps are real
17 SS2, Nightfall/Kalahari, M6, muffler delete, skip shift delete, wideband O2, Flex fuel sensor
#41 | |
![]() ![]() Drives: 2001 Audi TT, 2016 Camaro Join Date: May 2016
Look for one that gives you some confidence that it will respond quick enough to see temperature transients. |
#42 |
Camaro´s VS Mustang´s Procharger I.C. Sizing
The LT1 is 6.2 L, the Coyote is 5.0 L., so even with a higher redline, the Camaro should flow more air. Now about the I.C. Sizing, this is the Cooling Core Size from Procharger:
Mustangs: stage I 630 cu in., stage II 1,103 cu in. Camaro's: stage I 432 cu in., stage II 756 cu in. That makes both stages I.C.'s 32% smaller for the larger engine Camaro. W.T.F.? No wonder at elevation with lesser density air cooling the I.C., there are heating problems even below 7 psi. I wonder if Procharger will step up and build us an even larger I.C. for the Camaro. I supose that is why Girly changed the I.C. in her higher boost setup. |
