Old 03-21-2017, 03:27 PM   #29
Originally Posted by Snowblind View Post
MLEE according to my calculations and a 6500 rpm limit a 26.7 stock tire on the A10 (2.85 final) will have a speed of 101 in 4th and 119 in 5th. A 28.8 tire changes the speed in gears to 109 in 4th and 129 in 5th.
Factory setting is 6500
Thanks... so I'll be in 6th gear at 1/4 mile stock and 5th gear with 28.8 tires
Old 03-25-2017, 08:59 AM   #30
avacamaro
avacamaro
avacamaro's Avatar
Drives: 2016 silver SS
I also went the inexpensive route on wheels and used a C6 zo6 style wheel in a 18x10.5. I test fit the wheels they fit perfectly and look good for $130 each.
I had the same dilemma and ended up using 305-40-18 in the MT ET SS tire. I wanted the R's but the 305-40-18 is closer to stock size.
If you want to lower the effective gearing slightly, go with the 305/35, if you want a slightly taller effective gear go with the 305/45. Or chose to keep stock gearing and go with the 305/40.
You should be able to come out harder with the 305/35 if you have enough traction.
How about an offset for the wheels? What are you all running with the c6 Z06 rims.
Thanks
avacamaro is offline   Reply With Quote
Old 03-25-2017, 09:36 AM   #31
1LE Red Dragon
Train Driver
Drives: 2018 Summit White ZL1 1LE
I think it's a 56 offset. They only make one offset for the replica one wheels.
1LE Red Dragon is offline   Reply With Quote
Old 03-25-2017, 03:09 PM   #32
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
Got no lower than a 1.9 today, something is going on with my rear end, my car would not stay straight during burnout, i would get really sideways, dont know what was up. Anyways I picked up .2 tenths from my best, only made 2 passes it was so packed. First run was 12.00 second was 11.7
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 03-25-2017, 07:31 PM   #33
PRAY
PRAY's Avatar
Drives: 2016 2SS
Welcome to the rear end club brother. Sorry it isn't working out for you. The DA was +1,250 down here today. Not sure what it was up there but you weren't going to set the world on fire today. That's for sure.
Old 03-25-2017, 07:34 PM   #34
PRAY
PRAY's Avatar
Drives: 2016 2SS
Originally Posted by bhillakaiceberg View Post
Stock tires..
Front: 245/40/20
Rear: 275/35/20
I have gone back and forth with guys on this. The stock TCM/ECM is tracking the stock rear tire at 26.83". If you lay a straight edge on it with it on the car at proper air pressure it is 26.83". If you look at the scanner during shifts they coenside with the tire being 26.83" tall. Yes I understand what the calculator says but nothing lines up to that in the car.
Old 03-26-2017, 01:17 PM   #35
bybcous
bybcous's Avatar
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
