Old 05-07-2022, 01:23 PM   #29
Tim M
Tim M's Avatar
Drives: 2018 Camaro SS 1LE
I have no issues with OEM oil cooler setup...
Tim M is offline   Reply With Quote
Old 05-07-2022, 01:42 PM   #30
5.M0NSTER
5.M0NSTER's Avatar
Drives: 2018 Camaro 1SS 1LE
I think I'm in the "don't worry about it" camp. As long as you have good full synthetic oil 20min @280F wouldn't bug me.
Plus according to the temp gauges 305F is still ok for Oil, but not so much for Trans fluid, which according to the gauge is too hoy at 260F.
5.M0NSTER is offline   Reply With Quote
Old 05-07-2022, 06:26 PM   #31
Timbo-1LE
Timbo-1LE's Avatar
Drives: 2017 SS 1LE
I do run 15W50 and change it every two events.. Yes, your correct it's in the safe zone, was wondering if anyone came up with options. Thx for feedback.
Timbo-1LE is offline   Reply With Quote
Old 05-07-2022, 07:32 PM   #32
5.M0NSTER
5.M0NSTER's Avatar
I did some digging for S&Gs and found some interesting info:
From Mobil themselves:
"Mobil 1 advanced synthetic motor oil provides outstanding high-temperature performance and is proven to protect at engine temperatures up to 500 degrees Fahrenheit."
Source: https://www.mobil.com/en/lubricants/...oil-protection
And from a AAA affiliated provider:
"Superior temperature resistance. Synthetics can safely handle higher operating temperatures without oxidizing (burning) or breaking down. The upper limit for most mineral-based oils is about 250 to 300 degrees F. Synthetics can take up to 450 degrees F. or higher (some as much as 700 degrees F). This makes it well suited for vehicles that are operated in hot climates as well as heavy-duty, turbocharged or hard-use applications."
Source: https://www.waynesgarage.com/tips/mo...%20degrees%20F).
So if the oil itself is not the limiting factor, I'm sure OEMs pick the next weakest link is setting their operating temperature limits. I'm sure gasket and sealing and pressures are the next limiting factors.
