#29 |
A person can do a lot of studying on the "best" motor oil and still remain confused on the subject. Admittedly, I've spent a lot of internet time trying to figure out what oil to use in my new ZL1, and I'm still not certain. I think most oils focusing on balancing cost, environmental concerns, and wear protection. I'm most interested in wear protection. Unfortunately, it's difficult to know what additive packages each oil formulation has and for the most part the manufacturer's aren't telling!
The owner's manual tells us to use a dexos1 oil for daily use. The Supplemental Performance Manual tells us to switch oil to a dexos2 formulation prior to racing. Dexos2 is typically a diesel engine oil. The additive package in dexos2 (I believe) contains more anti-wear additives than dexos1 (ZDDP). However, ZDDP is a poison for our catalytic converters, so it can't be used permanently. I haven't found any single oil that meets both dexos 1 & 2 certification (anyone else)? I plan to continue studying the issue (frustrating as it is), and hopefully glean some insight into what oil to use day in and day out. I'm sure I'll put preference on whatever brand I believe is uperior in terms of wear protection, regardless of whether it meets dexos1 standards; but even that is difficult as the dexos page I posted earlier lists many oils meeting the standards, however most of those oils don't list themselves as dexos1 certified on their packaging. Confusing to say the least! Would appreciate hearing where any of my assumptions are in error.
Clear Bra, Tint, Splash Guards, Ceramic Coating, Painted Spoiler and Rear Views
#30 | |
![]() ![]() ![]() ![]() ![]() Drives: 2017 1SS/1LE Join Date: Sep 2016
"100% synthetic engine oil, specially designed for Diesel Particulate Filters (DPF) and Three Way Catalytic converters. Any car powered by turbo Diesel direct injection or gasoline engines, EURO IV and EURO V emission regulation compliant, requiring an ACEA C3 engine lubricant, high HTHS viscosity and (Mid-SAPS)." I'll be running Motul X-Clean 5W-40 year round (already did my first oil change 2500 miles ago). |
#31 |
![]() Drives: 17 white 1LE Join Date: Feb 2017
#32 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 SS 1LE Join Date: Dec 2015
From what I can tell, the main difference between dexos1 and dexos2, aside from the oil weight, is that dexos2 requires medium to low levels of SAPS. SAPS are sulfated ash, phosphorus and sulfur which are detrimental to diesel catalytic converters.
However, the standard oil calls for dexos1 which can be full SAPS, which makes me ask how the car is affected by this figure. Most Camaros will see over 100k miles with nothing but dexos1. The only two reasons I can see dexos2 being specified are: 1) The engine needs the extra protection of a 40 weight oil, and dexos2 is the only GM certification available for that. 2) At high load of track events, the emissions equipment is more affected by SAPS. However this doesn't make sense as they also recommend Mobil 1 15W50 which is full SAPS. Some discussion on the subject: https://bobistheoilguy.com/forums/ub...opics/4224569/ |
#33 |
![]() Drives: 2017 A10 ZL1 KG Join Date: Oct 2014
Being in the oil production business, racing at higher temps require or recommended the use of higher Viscosity lubricants. I would switch to M1 15w-50 for racing.
#34 |
Dexos 1 is basically US spec oil and dexos 2 is Europe spec oil which have difference of course because we can't all just get along.
#35 |
ZL1Black
Drives: 2017 ZL1 1973 Camaro Audi A8L 4.0 Join Date: Mar 2017
I used Mobil 1 in my Z06 prior to the ZL1 without issue. WalMart sells at a very good price and plan to stay with Mobil 1. Use Royal Purple in the 73 Camaro. Who knows what is best.
#36 |
![]() Drives: 2022 2SS A10 NPP MRC Red Hot Join Date: Aug 2016
FWIW..... Used Redline 5w30 in my Bimmer for a few years. Seemed to be the quietest oil in that DOHC 3.0L N52 High Perf Engine. The bottle says Exceeds Dexos 1 but no green logo. Guess they didn't pay the fees to play. Still have 10 qts; probably will use up on an oil change.
Went with dealer AC Delco syn blend on 1st oil change last fall. Researched oil specs over the winter and made a list to go shop at Walmart. - Pennzoil Ultra Platinum Plus 5w30 - Quaker State Ultimate Durability Full Synthetic 5w30 - Pennzoil Platinum Plus 5w30 - Mobil 1 Advanced Synthetic 5w30 - Valvoline Syntec Full Synthetic 5w30 The last oil change last week (24% OLM), Walmart didnt have Penn Ultra on the shelf, so went with QuakerState UD FS. Read a lot of good opinions about the oil, so for $40 for 2 qt jugs, had to try the stuff out.
[SIGPIC][/SIGPIC]
#37 |
I used to be Dragoneye...
Good News!!
The manual stated to use a Dexos2 5w-40 oil for track use...OR...Valvoline SynPower MST 5w-40...well guess what?! The Valvoline 5w-40 is now Dexos2! (And currently 5.19/qt at NAPA) Didn't realize till I picked up the bottles, today! |
#38 |
![]() Drives: 2017 SS 1LE Join Date: Feb 2013
Nice! Definitely snagging some this weekend!
2017 SS 1LE (sold)
Nightfall Gray |
#39 | |
![]() Drives: 1967 RS 327 Muncie, 2017 ZL1 6spd Join Date: Jan 2017
#40 |
Credit to mbar for giving a heads up on the sale!
#41 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 Silverado Z71 6.2L A10 Join Date: Mar 2017
Current ride
2019 Silverado Z71 LTZ 6.2L L87 425hp A10, 4 inch BDS Lift with Fox Factory Race 2.5 Coilovers, Borla Cat back (15HP bump), BFG KM3's 33's. Past Rides 2017 M6 Camaro ZL1 Hyper Blue 2016 M6 GT350 White with blue strips 2014 M6 Mustang GT Premium Track Pack Ruby Red 2012 M6 M3 Melbourne Red Metallic |
#42 | |
They recommend, as an alternative a Mobil 1 15w-50...but they also state explicitly to change it out asap after a track event... |
