Old 03-24-2017, 08:34 PM   #29
PK Auto Design
PK Auto Design's Avatar
Drives: 2017 Chevrolet SS 1LE
Originally Posted by cwebster View Post
Seems like I'm doomed to wait for a heat wave. What about these BC Forged RS40 wheels? They come in 18x20. Can I get a 43mm offset with high clearance for the Brembos? How much would those set me back for a pair?
http://www.bcforged-na.com/monoblock/rs40/
--Cal
You can get those created yes and they clear brembos like a charm.
PK Auto Design is offline   Reply With Quote
Old 03-31-2017, 01:10 PM   #30
SR 33
SR 33's Avatar
Drives: 2016 1LT - SIM
Is there a limit to tire size difference from front to rear?
I'm likely going snag a set of 20" wheels off a 5th gen, which have the taller sidewall. I did a test fitment and didn't see any clearance issues. However, the rear tires are fairly new and the fronts are toast. I'm tempted to get the smaller 6th gen size for the fronts, and then do the same with the rears when they wear out. Just worried about possible TCS, ABS, and stabilitrak issues
I forget which site I pulled this off of, but I found this to see the circumference difference
SR 33 is offline   Reply With Quote
Old 03-31-2017, 01:55 PM   #31
PK Auto Design
I recommend it just to be safe. Putting a 275/40 upfront will cause rubbing
Old 03-31-2017, 02:27 PM   #32
SR 33
SR 33's Avatar
Sorry, didn't explain he chart well. The 275/40 is the rear size, which I'll likely be keeping.
I'm between 245/40 and 245/45 for the front.
I'd like to go with the 245/40, which is the original 2016 size, but the front wheel would be constant 3.5% faster until i get smaller rears.
But if that 3.5% difference will confuse the computer, 245/45s would keep the front and rear wheel speeds the same but the car sits a half inch higher
Old 03-31-2017, 02:58 PM   #33
truesoul313
truesoul313's Avatar
Drives: 2019 Shadow Grey 2SS, A10 Borla
Can I get a quote/PM for 20x10 front and 20x11 rear FS02 in gloss black please!
truesoul313 is offline   Reply With Quote
Old 04-01-2017, 11:35 AM   #34
PK Auto Design
My apologies sir.
The issue I see is that when we compare to the widest front that members put 275/35/20 ( in height) it is a 1" shorter difference then the 245/45/20 so you could possibly and most likely rub the spring perch.
Now this may be confusing but allow me to compare
245/40/20 27.7" OD
275/40/20 is 28.7" OD
Thats a 1" OD difference
Compare this to a setup I have done before
275/35/20 27.6" OD
305/35/20 28.4" OD
.8" OD difference
I believe you can get away with it being an additional .2" difference
You got it.
Old 04-02-2017, 03:57 PM   #35
SR 33
SR 33's Avatar
245/40/20 27.7" OD
275/35/20 27.6" OD
305/35/20 28.4" OD
.8" OD difference
Sounds good, thanks
Old 04-02-2017, 09:38 PM   #36
PK Auto Design
Your welcome !
Old 04-29-2017, 02:35 PM   #37
PK Auto Design
BC Forged Wheels in and ready to get the PKAD treatment.
Old 05-16-2017, 12:45 PM   #38
PK Auto Design
Ready to tear up some asphalt !
BC Forged RS40 Wheels
Old 05-16-2017, 01:57 PM   #39
cwebster
Cal
Drives: 2017 6th Gen Camaro ZL1 Coupe M6
Those look like my wheels. Please tell me they're my wheels... YESSSS!
Did you inspect them to ensure they have the knurled bead seats?
How long will it take to get the TPMS sensors and Mickey's installed? How long after that will I get them?
Can't wait to slip into my new running shoes and test them out.
--Cal
cwebster is offline   Reply With Quote
Old 05-16-2017, 02:13 PM   #40
PK Auto Design
--Cal
Sent you a email sir.
Old 05-24-2017, 07:09 PM   #41
cwebster
Cal
Here's a thread where I describe the installation of my new BC Forged wheels and MT DRs: Installed BC Forged Rims & MT DRs
I've included photos and links to my research leading up to this purchase.
--Cal
Old 06-19-2017, 03:41 PM   #42
PK Auto Design
Little known fact all full packages through PK Auto Design get the works treament.
Full inspection of wheels
Full inspection of tires
Full inspection of TPMS
True Touchless Mounting
True Road Force laser balancing with readout
Mounting Hardware
Fully packaged and shipped fully insured for your assurance and comfort of mind.
Its the PKAD pledge to make sure our clients and members are always taken care of.
pkautodesign, question and answer, wheel information, wheels
