Old 10-29-2009, 08:09 AM   #29
CamaroSpike23
Truth Enforcer
CamaroSpike23's Avatar
Originally Posted by 7CAMARO7 View Post
and I think the ls1 takes up less space in the engine bay. I've worked around both and I'd seriously hate to long tube an lt car. They were bad enough on my ls1 but doable.
depends on the LT's you go with and how worn the motor mounts are. my hooker LT's went in just fine. a lot easier than the LT's I helped install on my buddy's 01 t/a.
if the motor mounts are worn and the engine is sitting low it does make things dificult. and since most LT1 cars are 13+ years old now, most have saggy mounts that make header installs a pain.
I helped my buddy do his on his lt1 and neither he or I know that while the radiator looked full that his car could still over heat. We were waiting for the coolant level to drop to add to the radiator and his car was just idling like normal the whole time. A few min later the coolant was still at the top and we looked at the temp and the mfer was like at 300*!!! it was idling perfect too, but we knew the guage was saying shut it down.
the LT1 has those nice bleeder screws that you have to open to bleed down the system. but that's awesome that it was still running fine.... a testament to the LT1.
point is we had no other indication it was over heating besides the guage inside the car. It continued to run perfect.
remember that there are two water temp sensors for the LT1, one on the w/p and one on the head. and one sends a signal to the pcm (which will pull timing and modify operating parameters) while the other sends the signal to the dash. so even if the dash is saying its hot, it might still be w/in safe limits.
an ls1 or l36 car will start missing badly and eventually turn itself off instead of screwing around with your head gaskets which can be costly to replace.
head gaskests are like 40 bucks...
And back to the oil analysis. Yea an oil analysis will tell you of things that can be a problem down the road if you do not catch it soon enough. But when something is broken it is broken. And yes, you are seeing where and tear in an oil analysis as far as what is going on in the engine, otherwise it would be pointless to do.
If your engine is still stock, you've got nothing to worry about when getting on it... It'll take it. If you've got a 6spd just upgrade your pushrods, maintain excellent maintenance, and have a blast... you won't twist your crank, I promise... Even if you do dead hook with a stock engine.
what do you mean by upgrade your pushrods? meaning swap to hardened?
Originally Posted by MrCool View Post
I like rough, raw MUSCLE! That why I've never like small little rubber band cars (ie. rice rockets). Just pure numbers.
I always forget about weight...it makes a big difference too.
wHEW! I hope you guys don't mind these, lol:
Like drag strip racing, track racing, street racing, or...?
So what would be an example of Spinning/Hooking?
spinning is just that, spinning the wheels. watch some drag race vids where the car is basically doing a burnout out of the hole.
hooking.... when the light turns green.... the car goes.
What does it mean to twist a crank?
just what it sounds like. your crankshaft rotates in the engine. and instead of it turning uniformly, one end of it rotates at a different speed than the other end, twisting it. hard to do with stock power levels.
Outlawz was saying there is not a ltx block which is truly badass like there is the lsx block. The lsx block is rated to like 2400-2500hp and the ltx just does not exist for those power levels
that used to be true
however, Dart has been finalizing an LTX block that will be similar to the LSX block in that it can be bored and stroked all to hell and back, accept any OEM or aftermarket LTX head and provide us LTX guys with a decently priced aftermarket block that we can beat the piss out of.
and there are 1000+hp LT1's out there, most of them have filled or half filled blocks tho.
I piss excellence
and fart awesomeness
Old 10-29-2009, 08:57 AM   #30
coolman
Guest
Howdy All,
I don't know if this is a dumb question, but oh well:
What kind of damage happens to the engine (Camaro or a regular car) when you accelorate hard, and how would you spot this damage?
You know, like
Just Curious...
This can be hard on any motor,but some more than others. Some stock motors don't oil the top end of the motor all that great which can cause the top end to be starved at higher Rpms. The rpms is what will kill the motor the quickest.
coolman is offline   Reply With Quote
Old 10-29-2009, 06:45 PM   #31
7CAMARO7
7CAMARO7's Avatar
Drives: Slow 4th gen
camarospike23, yes hardend push rods... the chromoloy part too.
I hear the 6spd cars can mechanically over rev and bend push rods that way. I've mechanically overrevved quite a few times by accident in the past but I decided to upgrade them for insurance.
7CAMARO7 is offline   Reply With Quote
Old 10-30-2009, 06:57 AM   #32
CamaroSpike23
Truth Enforcer
hardened pushrods arent what you want. unless they have a thicker sidewall than stock. hardening is really only good for if you are running guideplates to reduce pushrod shaving.
I piss excellence
Old 10-30-2009, 12:28 PM   #33
7CAMARO7
7CAMARO7's Avatar
My oil analysis indicated that everything is better than it is in the average ls1. Everything is within or way better than spec
Old 10-30-2009, 12:31 PM   #34
CamaroSpike23
Truth Enforcer
oil analysis wont tell you if you bent a rod...
I piss excellence
Old 10-30-2009, 12:35 PM   #35
7CAMARO7
7CAMARO7's Avatar
you must know from experience. Anyway most people will know if an important metal part of their engine fails. The oil analysis will show problems from using cheap oil, oil filters, air filters, or if a slight problem exists that could get worse from negligence.
Old 10-31-2009, 06:44 AM   #36
CamaroSpike23
Truth Enforcer
oh yeah. I was just saying that ive seen too many people "upgrade" to hardened pushrods cus they think they'll be more resistant to bending without making sure they increased the wall thickness of the rods themselves.
I piss excellence
acceloration, camaro, ls1, lt1, z28
Drum brakes hard to beat KILLER74Z28 General Automotive + Other Cars Discussion 17 02-16-2012 12:40 PM
How hard is it. . . 09fathomgreen Off-topic Discussions 7 10-13-2010 11:03 PM
power convertible hard tonneau cover? odie23 Camaro Convertible Forum 1 09-09-2009 08:50 PM
Coupe, Vert, Hard Top Vert, T-Tops, or Removable Roof Panel? TAG UR IT 5th Gen Camaro SS LS LT General Discussions 42 08-02-2007 10:46 AM
Camaro pulls a Z06 hard on the highway. onilmaruri General Automotive + Other Cars Discussion 6 03-28-2007 06:19 AM
