Old 01-24-2017, 12:45 PM   #29
sub_ETCS_ret
sub_ETCS_ret's Avatar
Drives: 2019 Dodge Challenger Scat Pack
You hearing anything from the dealer yet?
"Submariners are a bunch of intelligent misfits that somehow seem to get along, understand each other and work well together." - overheard from a surface officer explaining to another sailor about Submariners
sub_ETCS_ret is offline   Reply With Quote
Old 01-24-2017, 05:52 PM   #30
BowtieRocket
BowtieRocket's Avatar
Drives: 2016 Camaro 2SS- M6
Just got a call. They believe it is rod knock, but have to send a request to GM to see if they will cover it. But...they said there may be an issue because I have CAI intake, mishimoto catch can and VTC modifications...
2016 Camaro 2SS M6- Garage
BowtieRocket is offline   Reply With Quote
Old 01-24-2017, 05:55 PM   #31
BowtieRocket
Originally Posted by camaromatt.s View Post
Damn, sorry to hear that. How many miles do you have on it?
10k, but I bought it used with 6k
Old 01-24-2017, 05:58 PM   #32
BowtieRocket
Now I am worried that they won't warranty the work because of those modifications...
Old 01-24-2017, 06:01 PM   #33
Michigan1LTRS
Blessed ❤️
Michigan1LTRS's Avatar
Drives: 2017 1LT RS I4
Rod knock?? No way is that what stranded you. That is unbelievable.
Old 01-24-2017, 06:06 PM   #34
BowtieRocket
Even though, if it is rod knock, those mods wouldn't contribute to the damage...
Old 01-24-2017, 06:08 PM   #35
Michigan1LTRS
Blessed ❤️
Yep. I agree with you.
Old 01-24-2017, 06:11 PM   #36
Michigan1LTRS
Blessed ❤️
I would ask them how rod knock killed your power. Love to hear that explanation.
Old 01-24-2017, 06:12 PM   #37
stook2001
Drives: 99 M3, 04 STi, 16 2SS
rod knock, didnt see that coming as an explanation. how does that have anything to do with a dead battery. whole story is puzzling to me. interested in updates.
stook2001 is offline   Reply With Quote
Old 01-24-2017, 06:13 PM   #38
Richard0nee
Richard0nee's Avatar
Drives: 2016 SS M6, NPP
Sorry to hear man! A rod knock shouldn't be caused by a CAI unless it caused a really lean condition. VTC has nothing to do with it either neither does the catch can.
As long as you're not tuned you should be fine so think positively!
Also, see this thread for advice if GM wants to pin the mods against you
http://www.camaro6.com/forums/showthread.php?t=471953
Keep us posted
Richard0nee is offline   Reply With Quote
Old 01-24-2017, 06:24 PM   #39
sub_ETCS_ret
They should prove to you how those mods would have caused the problem. Be positive.
Sent from my SM-G920V using Tapatalk
Old 01-24-2017, 06:24 PM   #40
BowtieRocket
Thanks for the replies. They said they did a charging cycle test and that came back fine. Battery alternator etc. So while they left if run idling and shutting it off, then it wouldn't start again. IDK if it was due to low compression from the failed rod or not.
Old 01-24-2017, 06:26 PM   #41
BowtieRocket
I agree, there is no way my mods would cause rod knock. Not even a valve train failure...guess we'll see what they say...
Old 01-24-2017, 06:53 PM   #42
Sledgehammer70
Lethal Camaro
Sledgehammer70's Avatar
Drives: 16 2SS, 71 Std, Suburban RTS
Well they do have to prove that your mods caused it before being able to decline the claim. If GM is looking at it I have heard they are not fans of Catch Cans and can void it on that specifically.
Might need to get a lawyer if this goes south.
Sledgehammer70 is offline   Reply With Quote
