#29 |
![]() Drives: 2017 2SS Join Date: Jun 2014
Yeah, I heard that all the time. Never replaced a stud, never replaced a wheel bearing. And I pushed the absolute FiretrUCK out of that car!
#30 | |
Hot Dog
Drives: '17 1SS 1LE Join Date: Feb 2016
#31 | |
![]() Drives: 2017 1SS Stock - Brand New Join Date: Jan 2017
I agree. The 140 lb/ft is extremely high. This is most-likely because of the high lateral g's this car is capable of. If you drive close to the limit of adhesion, then I would torque to 140 lb/ft on the track. If you drive your car on the street only and drive it somewhat safe, you will never reach those loads. |
#32 | |
Hot Dog
A sanity check is "what do actual racecars torque their lugs to?" It's nothing special. A Spec Miata is still torquing it's 4 lugs to 77-82 LbFt.
#33 | |
![]() ![]() ![]() ![]() Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ! Join Date: Sep 2015
#34 |
Hot Dog
Honestly I can't think of a good reason to knowingly approach the yield strength of the fastener. The difference in feel between a torque-to-yield fastener and a normal to-torque fastener is obvious. Lug hardware is not going to be TTY. Once you feel it stretch, it's ruined.
#35 |
Retired from Car mfrs....
I don't have a problem with the 140, I'll continue to use the spec. It's just another easy push on my Torque wrench.
#36 | |
Second set of Info indicates 177ft lbs: http://electronicfilters.tpub.com/TM...37-13P_105.htm For 10.9 M14 x1.5 160 ft lbs http://www.ntractorclub.com/howtos/p...Bolt-Sizes.pdf Unless you find that our bolts are not 12.9 then I think this can be put to rest? |
#37 |
![]() Drives: 24 2SS 1LE V8 6M Join Date: Aug 2023
With my new 204% [sic] accuracy Harbor Freight torque wrench, the FACTORY TIGHTENED lug nuts on my 485 mile old 2024 Camaro 1LE consistently broke loose between 100-105ft/bs on driver side and 105-110ft/lbs on the passenger side. Factory lug nut tightening machine did vary from side to side so they must use two on the line? Since I didn’t have a “6” point 22 socket (read not to use a 12pt), I bought this (CMMT16085) off Amazon for $7.98 and wrapped in 3 rounds of black masking tape to avoid bumps. Fits nice and night.
#38 | |
This is also my personal experience, by the way; I have excellent McGard lug nuts and definitely clamp these things down to 140 lb-ft and always double-check every one, yet breaking them away is always easier (fastener corrosion is not a factor in my case, I strive to keep the car rust free as much as possible, there is obviously some on the hub, but the lugs and lug nuts are 100% clean).
#39 |
![]() Drives: 2020 Chevrolet Camaro Coupe 2SS 1LE Join Date: Feb 2020
The 6th gen SS 1LE wheel torque is 140 foot pounds. And the oil pan drain plug is 18 ft pounds.
#40 | |
Now tell me I’m wrong to not torque (or rather try to torque) my oil filter to 22ft lbs? I spun until gasket touched base, marked with sharpie, and hand tightened 1 rev and that’s where my instincts told me to stop. I couldn’t even get a 10ft/bs click using two different torque wrenches though. First time trying to tool torque a filter but hey, trying to baby the new Camaro. These tests rotated about another 1/4 turn which I’m fine with. She’s tight. I read about someone breaking the housing trying to meet factory torque. Others said hand tight is fine and 22 would be way to tight. I’m strong and “my” hand tight is exactly the tooless max I’ve ever done a filter ever and I’ve done all but 2 oil changes on my vehicles in last 30 years. Just thought I’d ask your opinion and see if I can get more enlightened. |
#41 | |
Shadow Gray '19 ZLE M6
PPF | Paint Correction | ZL1 Addons Rock Guards | ZL1 Addons Lift Pads | ZL1 Addons Feather Lite Tow Hook | JWM Smoked Sidemarkers | Wildhammer Smoked Rear Reflectors | JWM License Plate LEDs | RotoFab CAI | ADM IC Reservoir v2 | BC Forged RZ05 | SPL Toe Arms | BW Brake Deflectors | CMS Roll Bar | Schroth Profi II ASM Harnesses . Sold: '99 Trans Am (bolt-ons & cam) | '00 WS6 (bolt-ons, heads, cam, 12 bolt) | '05 CTS-V (bolt-ons, short throw) | '10 SS/RS M6 (short throw, CAI, coilovers, LTs, catback, JRE tune) | '01 WS6 YouTube |
#42 | |
