Old 02-04-2018, 03:36 PM   #29
GPz1100
Drives: 97 Z28 6MT, '12 G37 6MT
Can you lift the wipers up like the red car? I find that most useful when it's sleeting or freezing rain to keep the wiper from sticking to the glass.
GPz1100 is offline   Reply With Quote
Old 02-04-2018, 03:47 PM   #30
kodiakk
kodiakk's Avatar
Drives: 2017 Camaro SS FIFTY
I found that its not necessary my friend, with the side window indexing, I had to come up with a solution so I could open the door. The windows will freeze to the seals, so I use a non alcohol silicone spray and treat them. I do this as well to the windshield wipers and presto no problem. works great.
kodiakk is offline   Reply With Quote
Old 02-08-2018, 09:07 AM   #31
dmcmahan60
dmcmahan60's Avatar
Drives: 2017 SS
2017 SS Auto, Mine only flashes once and then goes away when I put it in Track Mode, and I have noticed it is charging 15 Volts down to 12 volts. should I be concerned?
dmcmahan60 is offline   Reply With Quote
Old 02-08-2018, 09:58 AM   #32
ctrlz
Originally Posted by JR91 View Post
That message began to appear for me when the weather started to get cold. It occurs occasionally when I blip the throttle while starting in first gear (M6).
The more I researched this the more I came to believe these untraceable Stabilitrak errors are caused by throttle body problems. I sold my Acadia before I got around to replacing the throttle body, but that was the direction I was heading in. So change in temperature and atmospheric conditions fits with this theory.
Old 02-08-2018, 10:04 AM   #33
2K16SummitSS
Resident Land Surveyor
2K16SummitSS's Avatar
Drives: 2016 Camaro 1SS - Summit White M6
Mine flashes about once a week or so, this has been happening to me for about the last 10k miles. I've had no issues other than the warning, so I'm sure it's just GM's really fun and random sensor problems.
2016 Summit 1SS 49th Anniversary Commemorative Limited Plutonium Edition - M6, Solo Axleback & !RearCats, Ultra-Rare Cloth Seats, Forgestar CF5V 19x10-285/35 19x11-325/30
2001 NBM Trans Am WS6, Wifey's Grocery Getter - Torquer V2 cam, Racetronix Fuel Pump, Yank 3000 Stall, Transgo 1-2 kit, TSP LTs, Magnaflow, Strano Springs/Koni STR.T shocks, 17x9.5/17x11 TTIIs, Ed Wright tuned
2K16SummitSS is offline   Reply With Quote
Old 02-08-2018, 11:13 AM   #34
Alanarchy
Alanarchy's Avatar
Drives: 2017 Camaro SS NGM, 2025 F150 XLT
Unless your resting your wrist on the center console near the switches. I was doing that for a while and was wondering why it was coming on only to realize the whole time that my wrist would tap the switch by accident.
Alanarchy is offline   Reply With Quote
Old 02-08-2018, 05:39 PM   #35
Kgoeb
Drives: 18 1LE, 12 Regal GS
My Regal does this every now and then. Usually when it's really wet outside. I choose not to bother. If there is a legitimate problem, the light will always be on, or at least be more frequent. It also doesn't help that 9/10 times there will be no trace in the computer as to a fault code or any clues as to why it comes on then goes off, so unless there is a TSB for a reflash of some kind the dealer will just give it back to you as no fault found. It's pretty well par for the course when it comes to GM and stabilitrak haha
Kgoeb is offline   Reply With Quote
Old 03-02-2018, 09:18 AM   #36
Jhoceva
Jhoceva's Avatar
Drives: 2016 Camaro 2SS, 2014 Equinox 1LT
I have had this same issue in my vehicle as well (also a manual 6). When it is below freezing and I blip the throttle, I will occasionally get this. Drove the car all the previous summer with no issues whatsoever. Took it out a few times this winter when the roads were decent and started getting this message. Now that the weather is warming up again, I dont get the message anymore. Im thinking that maybe a certain sensor in the vehicle is failing to function properly at certain temperatures. No weird engine issues or anything, car runs just as strong as day 1.
Jhoceva is offline   Reply With Quote
Old 06-28-2019, 03:55 PM   #37
Desertvet91
Drives: Chevrolet Camaro ss
16 camaro
Service Stabilitrak came on, started running rough rt after...any ideas?
Desertvet91 is offline   Reply With Quote
