View Poll Results: Rear Diff groan by the numbers
I have NEVER had the groan 135 27.22%
I have the groan and need to take the car to the dealer 211 42.54%
I have changed the diff fluid and do not have the groan 39 7.86%
I have changed the diff fluid and the groan returned 53 10.69%
I have changed the rear diff completely and do not have the groan 11 2.22%
I have changed the rear diff completely and HAVE the groan 26 5.24%
I have changed the diff fluid more than once and do not have the groan 5 1.01%
I have changed the diff fluid more than once and have the groan 8 1.61%
I have changed the rear diff completely more than once and do not have the groan 3 0.60%
I have changed the rear diff completely more than once and HAVE the groan 5 1.01%
Voters: 496. You may not vote on this poll
Old 01-12-2017, 06:59 AM   #29
jls
jls's Avatar
Drives: 2016 1SS
Originally Posted by jls View Post
Going in for oil change next week. Hoping for cold weather. This will be the second time trying to get something done about the rear end groan.
Dealer ordered the rear end fluid for my car.
jls is offline   Reply With Quote
Old 01-12-2017, 08:32 AM   #30
nancygrl
雪の玉
nancygrl's Avatar
Drives: '22 Z71 RST Silverado
Had diff fluid changed out last week on the 3rd. Hadn't noticed any noise the following day, and haven't been able to drive because of the snow and extreme cold this past weekend. Took it into work today, and had no diff noise/groan while making any turns. But the noise didn't surface until around 6-7k miles...So I'll reserve judgment on whether or not the fluid change really did fix it or not. Right now it's good, but only time will tell
nancygrl is offline   Reply With Quote
Old 01-12-2017, 11:05 AM   #31
wrankin
Camaros Of Northwest Ohio
Drives: 2023 Red Hot 2SS 1LE
The dealership changed the fluid once, and I still have the problem. Heard the noise and think it was less severe. Did the figure 8 break-in procedure. Still heard the noise and called the dealership and they told me I needed more miles on it before they look at it again. Car is now in winter storage, so we'll get back at it in March/April.
Build Date: 2/27/2016
Current Mileage: 14,800
wrankin is offline   Reply With Quote
Old 01-12-2017, 10:53 PM   #32
cryssm
cryssm's Avatar
Drives: Car
Originally Posted by Antista1974 View Post
Actually I would think its V8 issues only because these have limited slip and I doubt the v6 has this.
V6 and I4 models equipped with the manual transmission have limited-slip differentials, as well.
the one and only
cryssm is offline   Reply With Quote
Old 01-13-2017, 07:05 AM   #33
jls
jls's Avatar
Drives: 2016 1SS
Two days this week the temperature was 10 degrees F and lower, driving away thru turns that normally produce the groan, the groan was not present. A day later the temperature was above 30 degrees F the groan returned. I have not had the fluid changed yet.
Old 01-13-2017, 08:52 AM   #34
Bobfly
OspreyTech
Bobfly's Avatar
Mine had it since new but it was just barely noticeable. Got worse as the miles piled up. When winter hit with sub freezing temps it got very noticeable and I took it in for a check up. The dealership saiif the clutches were heavily worn and ordered a new diff. I have about 750 miles on the new diff with no noise. I'll be changing the fluid here soon. Hope it's fixed for good. Car has 26,xxx on it now.
2SS Nightfall Grey Metallic w/Ash Grey Interior, Silver Rally Stripes, 6M, MRC, DPP, Nav, Sunroof & Black Bowties
Bobfly is offline   Reply With Quote
Old 01-13-2017, 09:25 AM   #35
oneredry
HYPER SS
oneredry's Avatar
Drives: 2016 Supercharged 2SS
I changed the fluid once, the dealer did it twice (per the bulliten) and the 4th time they didn't question. They just ended up replacing the carrier. keep in mind that my car had about 1500 miles when it all started. replaced at 2215 miles. I'm now at 2340.
Ordered: 1/15/2016
2000 status 02/01/16
3000 status 02/29/16
3400 status 03/07/16 TPW of 03/14/16
4200 status 03/17/16 in transit!
Delivered 03/23/16
2SS Hyper Blue | 6M | NPP | Mag ride | ceramic white Int. | Black out bow ties | P3 Gauge| Front splitter. | 6 pot upgraded brembo brakes. | Magnuson Supercharger/95MM pulley | Rotofab Intake | ZL1 side skirts | HRE FF04 wheels - Michelin PSS4 | ZL1 add ons rock guards and lift points.
| AWE touring - resinated catback with link pipes.
oneredry is offline   Reply With Quote
Old 01-13-2017, 02:04 PM   #36
Mad Mike
Drives: 2016 Chevy Camaro SS
11100 miles on my early 2016 1SS A8
Just got my car back after 3way Chevy replaced the rear diff. We will soon see if the noise comes back. My guess is that it will come back in another 5k miles.
Mad Mike is offline   Reply With Quote
Old 01-17-2017, 09:09 AM   #37
That1SS
Drives: 2016 1SS
I recently had the rear diff fluid replaced on my 2016 1SS by the dealer due to the groan noise during slow turns on cold starts. The tech stated if the groan returns, theyll have to replace the whole differential. It's been over a week since taking it into th dealer, and not a peep so far. Fingers crossed this issue doesn't arise again
That1SS is offline   Reply With Quote
Old 01-17-2017, 10:54 AM   #38
Hardball
Hardball's Avatar
Rear Diff Groan
My 16 SS had the groan. Dealer replaced the rear diff. Groan went away for few months, now the groan is back only hear it in the am early. I'm sure it will get worse. Love the car!!!
Hardball is offline   Reply With Quote
Old 01-17-2017, 01:30 PM   #39
brutusvk
Drives: future 2016 SS
Dealerships are retarded. They 'couldn't duplicate the noise' and said the notices I showed them are simply repair notes. I said, screw it... it breaks you have to fix it anyway.
brutusvk is offline   Reply With Quote
Old 01-17-2017, 01:33 PM   #40
maverick112582
Drives: No Camaro yet
I'm looking to buy a 2017 1ss in the spring. Does this groan happen to the new models or just the 2016 model?
I'm also going to be getting an auto trans. Are there any problems with the torque convertor on the 2017 models?
maverick112582 is offline   Reply With Quote
Old 01-17-2017, 07:07 PM   #41
BlueThunder2SS
BlueThunder2SS's Avatar
Drives: 2016 HyperBlue 2SS
Need 2 more options:
1) Took to dealer and they said it was normal.
2) Differential actually physically failed and had to be replaced.
If the dealer is right, and it is normal, you should get 0 votes for "Differential failed".
BlueThunder2SS is offline   Reply With Quote
Old 01-17-2017, 09:06 PM   #42
stook2001
Drives: 99 M3, 04 STi, 16 2SS
I think the poll may require some guidance or mileage based mandate. I have about 1k on my car and I have been reluctant to participate in the poll because I don't want to skew the results since my mileage is lower than when this issue seems to most typically start. Maybe only participate if you have a min of 10k miles?
stook2001 is offline   Reply With Quote
