#29 |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
So took the car out tonight and did a handful of short pulls. Did high rpm (5500-6000) 1-2 and 2-3 shifts. Car pulls great, but this exhaust noise kinda annoys and baffles me with it's randomness. Like on maybe half of those 1-2 shifts I would get the noise I was talking about, what I would describe as a single, loud pop/backfire/gunshot sound just as I come off the gas to shift. I see some say this is clutch fuel cut off CFCO, which makes sense, but why doesn't it always do it? And I thought that was only for no lift shift? It's kinda loud and annoying when it does it, like it makes you think your tunes wack. I've owned multiple manuals, with even more open exhausts, none did anything quite like this. Not sure I like it very much at this point...but I guess a tune is the only way to remove this? Don't have any desire to do that at this time...guess I'll have to just get used to it.
#30 |
![]() Drives: 2017 2SS 50th Anniversary Join Date: Jan 2017
My A8 does it reliably, but it pretty much has to be floored and it will pop in between gears. I agree with others, it is intentional - same type fuel management tricks that other euro car compainies do to make their v8's sound and look cool. I bought the car partially because of how bad ass it sounds! Problem is sometimes not enough room to wind this thing out, I try to get one pop on the way home every day - it's like therapy!
#31 | |
マスタング = 遅い
#32 | |
![]() ![]() ![]() Drives: 16 2SS 6MT NPP MRC / 15 K1300S Join Date: Mar 2016
Reminds me of turning the ignition off for for a few secs and then back on as a kid when passing somebody walking along a backroad.
![]() Rohana RFX-5 10/11, M/T 275/305, Eibachs, Hellwigs, Hurst SS, DMS LT4 SC 596HP/589TQ, DMS Low-side, Kooks 2LTs, MBRP Race, Rotofab, MMS CC |
#33 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2016 Hyper Blue 1SS Join Date: Jul 2015
Mine too sounds like a gun shot, i always look around and see if people think someone is shooting.
1ss/Auto-Hyper Blue
acs carbon flash spoiler, bmr springs, gm clear tails. Texas speed cam, 223/227 .635/.635 116 LSA, Kooks Long Tube Headers with green cats, MSD Atomic Air Force Intake, CAI Cold Air Intake, QTP cutouts. 503 hp Best so far 11.5 at 123 with a 1.83 60ft. BMR lower and upper trailing arms and upper control arms,E85 DELIVERED 12/29/15 http://youtube.com/bybcous " no talking only racing on my youtube" |
#34 | |
![]() Drives: 16 2SS Join Date: Jun 2016
Definitely happens on the Autos. It's the fuel cut off backfire at shift that cause the pop. In an A8 with pedal to the floor the yell of the NPP and the pop when it shifts is like a the best woody I've ever gotten haha. Sounds like flames spitting out like they did in my old EvoX Sent from my iPhone using Tapatalk |
#35 |
![]() ![]() Drives: 2016 Camaro 2SS Join Date: Dec 2015
@SS 1LE try to do a no-lift shift... keep your right foot planted as you shift quickly near redline. It takes a bit of mental gymnastics at first, because you're so used to lifting, but you'll see what we're all talking about. The car will cut spark and RPMs will drop very quickly to where they need to be for the next gear (accompanied by that awesome backfire). Yes it does sound like a gunshot and it's pretty rad
#36 | |
マスタング = 遅い
#37 |
Yes, it's because you start lifting off the gas a fraction of a second after you touch the clutch... by that point the ECU thinks you're trying to do a no lift shift and does it's thing. I trained myself to do that all the time, I still lift because I think it's easier on the drivetrain to re-engage without instant power, but the spark cut helps drop the RPM faster and produce a smoother shift.
#38 | |
マスタング = 遅い
Thanks! |
#39 | |
#40 | |
マスタング = 遅い
So as a practice you don't do a full on no lift shift, you just make sure you touch the clutch before you lift so you "partially" use no lift shift? And this will give you the loud gunshot like sound when doing a high rpm shift? Do you ever get the gunshot like sound when you do the same procedure on a 2-3 shift, or just on the 1-2 shift? I appreciate the feedback bud. |
#41 | |
![]() To answer your question, the car should no lift shift into every gear.
#42 |
![]() Drives: 17 Camaro 2SS Join Date: Jan 2017
Mine tends to do it on cold morning starts. and definitely as I'm shifting and letting go of the gas. It reminds of my old sti I used to make it backfire on command. All it really is. Is a rich fuel mixture being cut of as you lift off the throttle. I leave for work at 5am. So I'm sure the neighbors hate me. But they are they drive mustangs so it's ok
