Old 12-30-2016, 01:53 PM   #29
KILLA BEE
Black lightning
KILLA BEE's Avatar
Drives: 2021 ZL1 1LE A10
Originally Posted by StateOfMind415 View Post
Here is a video of my car during cold start in Ice/Snow mode (stealth mode) vs Sport mode on different mornings. Without starting the car, holding the push start button for 5 seconds will take you into 'accessory mode', so you can start up in any mode. Only mods, rotofab cai and 2nd cat delete borla xpipe to stock NPP muffler. Starting up in stealth mode definitely makes a difference during cold start.
Sport Mode (valves open): https://youtu.be/NMNsV45pDYE
Ice/Snow Mode (valves closed):
https://youtu.be/txXMU9SUDkM
Not hs buddy.
[ 2021 Camaro ZLE 10 speed
KILLA BEE is offline   Reply With Quote
Old 12-30-2016, 02:17 PM   #30
StateOfMind415
StateOfMind415's Avatar
Drives: 2016 Camaro 2SS NFG M6 MRC NPP
Originally Posted by KILLA BEE View Post
Not hs buddy.
StateOfMind415 is offline   Reply With Quote
Old 12-30-2016, 02:50 PM   #31
EFI Tuning
EFI Tuning's Avatar
Drives: 2016 Camaro SS
Here is a cold start on my car (primary cat deletes and NPP in Sport mode). This was tamed down via tuning.
Tim
EFI Tuning is offline   Reply With Quote
Old 12-30-2016, 03:52 PM   #32
KILLA BEE
Black lightning
KILLA BEE's Avatar
In other words that might work for him But not for the OP that started the thread. Hes gone need that special plug and play from EFI.
Old 12-30-2016, 04:20 PM   #33
Megahurtz
Snackbar Tuning
Megahurtz's Avatar
Drives: 2023 SGM ZL1
The OP is cammed with LT's.....not even tuning is going to quiet it down much on cold start. Even in stealth mode it's going to be loud.
Old 12-30-2016, 05:07 PM   #34
Fraxum
Fraxum's Avatar
I moved to stealth in all modes and the startup is quieter for sure on my SS. With my setup (LTs. cats, NPP) Stealth full time is the way to go for me..
Old 12-30-2016, 06:08 PM   #35
bybcous
bybcous's Avatar
Drives: 2016 Hyper Blue 1SS
The car is actually silent in stealth mode, i had sound manager defaulted to sport mode and didn't realize it.
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 12-31-2016, 08:48 AM   #36
Dfelux
Drives: 2016 SS Hyper Blue
You don't need to buy anything to do this, it's all in your settings. Press home and go to settings. Go into the vehicle options and you can change everything individually (exhaust, steering, suspension with Mag ride). The only thing with this is you have to set this BEFORE you turn off your engine the time before (so set yourself up for the next time you're gunna drive it).
Dfelux is offline   Reply With Quote
Old 12-31-2016, 10:51 AM   #37
G Fo12ce
G Fo12ce's Avatar
Drives: '16 2SS
I too leave the house around 5AM and I know my neighbors have to be bummed lol. I did what was mentioned before and held the start button for 5 sec to get the my link to launch and set it to Stealth before start up. Made a noticeable difference.
I just had a question though. If I leave it in Stealth at that point and drive away, then I use the switch on the console to change it into Sport for example, does the exhaust portion stay in Stealth and only the steering and suspension only go to Sport?
After driving it away should I set it back to auto? I think the answer is yes but I just want to confirm.
Thanks!
My Intro Post | My Order | My Ordering Guide
TJCR2Q | 2SS Red Hot|Adrenaline Red|MX0 A8|56R Wheels|5ZU Blade Spoiler|NPP Exhaust|F55 MRC|IO6 Nav
• 4/06/16 1100 Ordered (waiting for 5ZU acceptance)
• 4/19/16 2000 Accepted with 5ZU
• 4/23/16 3000 TPW:5/16/16
• 5/06/16 3100
• 5/13/16 3400 Broadcast Sheet
• 5/24/16 3800 Vehicle Produced
• 5/25/16 4B00 Bayed
• 5/27/16 4300 Intermediate Delivery
• 7/9/16 Delivered!
G Fo12ce is offline   Reply With Quote
Old 12-31-2016, 12:32 PM   #38
bybcous
bybcous's Avatar
Thanks!
Yes when I get to the end of neighborhood, i turn it to default sport , track, or auto. If it's in the afternoon, i open cutouts open all the way.
1ss/Auto-Hyper Blue
DELIVERED 12/29/15
Old 12-31-2016, 10:54 PM   #39
Dfelux
Thanks!
Once you change it from the screen settings it'll be more a manual selector until you switch it back to the 'mode selector option' (which takes a matter of seconds to do all this btw). Works great for me though. Start up in stealth, get down the street a bit and track mode...never really use anything except those two modes to be honest
Old 01-01-2017, 11:29 AM   #40
KILLA BEE
Black lightning
KILLA BEE's Avatar
If you have your fuse pulled this means nothing right because valves stay open?
And when you cant remote start when its freezing out becsuse you have to hold in the start button first would suck
Old 01-01-2017, 05:40 PM   #41
G Fo12ce
G Fo12ce's Avatar
Drives: '16 2SS
Thanks guys. Now that's I've had a few mornings to play with it I agree. The menu stays up and it just takes a second to set it back to the auto mode. It's too bad you can't have a shortcut on the home screen that toggles these. That would be cool.
• 5/06/16 3100
• 7/9/16 Delivered!
Old 01-01-2017, 09:54 PM   #42
TimsZ28
Drives: '16 2SS, '14 Z71
I did not read every post in here, so forgive me if it has been said....
There is another way so you do not have to set yourself up for the next day. I know I would forget too dang many times. =)
When you get in your car do not touch the brake, press and hold the start button for several seconds...till everything lights up. This puts the car in demo mode so you can make setting changes before starting the car. Select drive mode / stealth then fire it up silently. I do this all the time to be kind in the morning if I am on the go early.
'16 2SS M6 & '14 Z71
TimsZ28 is offline   Reply With Quote
