Old 12-30-2016, 07:14 AM   #29
classicrockr
Pills are for Pansies
classicrockr's Avatar
Drives: 2023 2SS Red Hot Vert Camaro
Only issue with my vert is when I'm going over rougher roads, I hear a rattling noise from the rear area (right side I think). When I'm on smooth roads though, I don't hear it. Things I've checked so far:
- Rear seat belt mounting bolts are tight
- Took everything out of the trunk that I could, (including the carpeted floor board that has the flap you secure so the top can come down) & Styrofoam pieces. Noise was still there.
- Checked everything that was mounted in the frame/well area of the trunk. It's all tightly mounted.
The main thing I noticed is that when I go behind the car & push inwards on the rear fascia near the license plate, the fascia hits the frame as soon as I press on it. Looking under the car, the rear cross-brace has no room between it & the rear fascia. I think THIS is what's causing the noise. I'm also wondering if the tube that goes from the gas fill port to the gas tank is loose somewhere between the body panels.
Dealer has to mount some kind of sensors because they've heard it, but can't figure out where it's coming from.
classicrockr is offline   Reply With Quote
Old 12-30-2016, 07:37 AM   #30
HyperBlueX2
Here is mine....
Old 12-30-2016, 07:51 AM   #31
classicrockr
I've thought about adding white stripes to mine....just don't know how it would look with the black top. I probably will end up doing it at some point.
Old 12-30-2016, 08:00 AM   #32
HyperBlueX2
Top up.....
Old 12-30-2016, 08:02 AM   #33
HyperBlueX2
Top down......
Old 12-30-2016, 01:45 PM   #34
vidkidZ
Mobile/Embedded Architect
vidkidZ's Avatar
Drives: '16 2SS white convertible
IMO... The stripes make the car. Combined with the seats... Great choice!
vidkidZ is offline   Reply With Quote
Old 12-30-2016, 03:40 PM   #35
MANNAXMAN
MANNAXMAN's Avatar
Ask and ye shall receive!
So who's going to be the first to post in our forum?
1996 Camaro Z28 with T-Tops (Sold 10.22.16)
1986 Camaro IROC-Z with T-Tops (Sold)
1961 Volkswagen Beetle with Sliding Ragtop Sunroof (2009-Present)
1964 Volkswagen Beetle with aftermarket Sliding Ragtop Sunroof (Sold)
Follow me on Instagram - @gen6_2ss_vert
MANNAXMAN is offline   Reply With Quote
Old 12-30-2016, 03:48 PM   #36
mlee is online now   Reply With Quote
Old 12-30-2016, 04:28 PM   #37
CyberGuyPR
CyberGuyPR's Avatar
Drives: '16 vert 2LT RS NPP
CyberGuyPR is offline   Reply With Quote
Old 12-30-2016, 05:50 PM   #38
mekirk2
mekirk2's Avatar
Drives: 2016 2SS Ragtop Garnet Red
Let me know what you find - Ive heard the same noise just this week.
mekirk2 is offline   Reply With Quote
Old 12-30-2016, 06:34 PM   #39
richm
richm's Avatar
Drives: 2016 Camaro Turbo4 RS Convertible
Red Vert
Here is mine!
Actually, I had issues right off the bat on Day 1 right after arriving home. While putting the top up, it started crunching on the plastic upper trim pieces and then started cannabiizing the interior plastic moldings in one of the backseat side areas.
But after getting everything repaired, it's been good as new with none of the reported problems that others have mentioned about.
Name:  New Red Camaro.jpg
richm is offline   Reply With Quote
Old 01-03-2017, 05:20 PM   #40
Garion1076
IG: @velveteen_camaro
Garion1076's Avatar
Top down......
Gorgeous!!!
Garion1076 is offline   Reply With Quote
Old 01-03-2017, 05:22 PM   #41
Garion1076
Garion1076's Avatar
No Convertible Forum?
Sweet!
[QUOTE=MANNAXMAN;9479060]Ask and ye shall receive!
