Old 02-03-2017, 10:28 AM   #29
Eric SS
#becauseracecar
Eric SS's Avatar
Drives: 2016 SS Sedan, 2016 Camaro SS
I'm having trouble visualizing this so would really like a photo of the 1LE set up vs the SS track set up as well. I have the SS track set up on mine and just leave it there but will probably be purchasing the FE4 suspension kit.
Eric SS is offline   Reply With Quote
Old 02-05-2017, 08:31 PM   #30
Tomiboy
Drives: 2017 Hyper Blue 1LE
That's not true. The air coming under the LED driving light is directed to the fender lip to blow an air curtain over the turbulent spinning wheel. There are visible brake ducts in the main opening of the grille. You can see them in the picture below. They sit between the main radiator and the AUX radiators. Also notice the notches in the outside edge of the front wheel well liners. That is where the air curtain air exhausts from under the LED "Fog" lights.
Great pic! definately worth a thousand words!
Tomiboy is offline   Reply With Quote
Old 02-05-2017, 08:38 PM   #31
SkipNWis
SkipNWis's Avatar
Drives: 2016/SS Has had 4 Gen 5's
Yea Might also what to know your CAR didn't come with DOT4 installed. You might want to get that changed :0 They aren't truely track ready in my world........
SnoWhite
SkipNWis is offline   Reply With Quote
Old 03-13-2017, 08:21 AM   #32
bubbajan21
Drives: 2016 2SS
Does anyone have photos or part numbers of the 1le brake cooling?
bubbajan21 is offline   Reply With Quote
Old 03-15-2017, 10:20 PM   #33
DenverTaco07
DenverTaco07's Avatar
Ok, so just to clarify, I should not call my dealer and yell at them for not including the deflectors....right?
Old 03-16-2017, 12:28 AM   #34
7stringtheory
Drives: 2017 Camaro 1SS 1LE
If you have a 1LE you should not have received the deflectors. The 1LE is setup already with brake cooling integrated from factory. It is designed to function on the track and on the street as opposed to the SS method that is supposed to require switching to go to the track and vice versa.
7stringtheory is offline   Reply With Quote
Old 03-31-2017, 01:10 PM   #35
TheRealJA105
TheRealJA105's Avatar
Drives: 2013 C6Z06
Does anyone have a picture of the disc backing plate on the 1LE? I have an SS with the 6 pistons and wondering what I should do about my backing plates for track days. I will be installing the tall track deflectors, but I assume that the small backing plate that is provided with the SS is for the smaller 4 piston brakes. This would lead me to believe that it won't cover any of the disc at all and I may as well not install any backing plate at the track. If the 1LE has a backing plate with coverage in between the tiny track SS ones and the full 6 piston ones I think I would like to do some trimming on them or try to buy 1LE ones.
Old 04-03-2017, 11:58 AM   #36
TheRealJA105
Drives: 2013 C6Z06
Nobody can help me out with this?
Old 04-03-2017, 11:59 AM   #37
mjk3888
"M1SS1LE"
mjk3888's Avatar
Drives: 2017 SS 1LE
pretty sure the backing plate is exactly the same. The deflectors is where the difference is.
