#29 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 17 Camaro SS 1LE & 16 Sierra AT CC Join Date: Nov 2016
Ok, so this is only for the A8 cars, the M6 cars don't have the AFM system I take it.
#30 |
Drives: 2016 Camaro SS Join Date: Oct 2016
For the Camaro that is correct.
Tim Last edited by EFI Tuning; 11-18-2016 at 10:17 AM. |
#31 |
![]() ![]() ![]() ![]() ![]() Drives: 17 SS a8 Join Date: Feb 2010
i removed these sections of my exhaust awhile back and promptly got several codes and a cel. Tim sent me a couple of pre final production simulators. i plugged them in and drove around for about 10 minutes and all the codes cleared. they work exactly as advertised.
great job Tim!! I cant wait to see what other cool stuff you come up with. |
#32 |
Parish8,
I'm glad to hear the modules are working for you. Thank you for the supportive feedback! As soon as this design has reached final production status I will be working on something that should really interest those that are in the "no tune" camp. It will be pretty slick in how it works and how the user interfaces with it. But that is all I can say. I may be going for a patent on this one. Tim Last edited by EFI Tuning; 11-19-2016 at 07:34 AM. |
#33 | |
#34 | |
![]() Drives: 13 ZL1 SIM, 99 Z28 Black Join Date: Feb 2013
2018 C7 Z06 - WGG, M7. / 2013 ZL1 - SIM, 6 spd, RotoFab CAI, Can. / 1999 Z28 - Black, 6 spd, K&N, Subframe. / More Fun Stuff - www.inlandspeed.com
#35 |
Here is a picture of the first production set. These are fully potted with electronics epoxy so moisture will not be an issue.
Thank you, Tim Last edited by EFI Tuning; 11-22-2016 at 11:58 PM. |
#36 |
I have over 200 miles on my car and all is well. codes are gone.
after I removed my valves my dod still worked for a couple of days. you could barely hear the difference when it kicked in and out. the tire noise and wind noise are louder than the exhaust noise. this is with the stock npp exhaust and the valves closed. I can see wanting to keep the dod active, why not. |
#37 | |
Tim |
#38 |
![]() Drives: ´18 ZL1 A10 Red Hot 😍 Join Date: Jan 2016
Hello Tim,
Nice work! Just a question: is there a possibility to burn the valves racing a Camaro (with NPP exhaust, non aftermarket) as Corvette owners complaint? If yes, will be a solution to plug your module when racing with the car, and unplug it the rest of time? (here the AFM solution is not useless due to gas prices). Thank you! |
#39 |
I have not heard of any Camaros having the issue the C7 guys do. The actuators are the same part number. Either there just aren't enough Camaros racing or the placement on the Camaro is better. Even if that issue is not a concern for the Camaro these modules will allow you to utilize any aftermarket exhaust system even if the manufacturer does not support the AFM valves. AFM support is a very pricey option. Simply grounding the actuators on a dummy mount will not prevent CELs.
The upcoming revision will allow operation when AFM is active so no need to unplug if that were your use case. Ideally it would have been just a software change in the existing module but I had to add additional circuity that forced a PCB change. Thank you, Tim Last edited by EFI Tuning; 11-21-2016 at 06:53 AM. |
#40 |
![]() Drives: 2016 Camaro 2SS Join Date: Jul 2017
Hello Tim, I have an A8 2SS and decided to go with a full system. I went with the Stainless Works catback (npp) but I didn't get the $400 option that includes AFM valves. So I have a P069E code being thrown. Do you know if these Valve Delete Module Set's will fix this issue?
#41 | |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
Yes these modules will fix your code issues, We stock them for anyone who is interested, great product. Ted.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#42 |
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2019 Camaro 1LE Shock Candy Join Date: Mar 2016
Save your money.
Just unbolt the 3 bolts from the black electronic portion of the values. Zip tie them up in a secure location after reconnecting them and your codes will go away.
LT4 1.7 Supercharger snout ported & 100% Meth
103 Katech TB, KATECH Custom Heads, DSX In-line fuel TSP Headers, Spec P Super Twin Clutch, TSP EL C7 CAM Diamond Piston & Manley Rods, Roto Fab Big Gulp BTR Push Rods,LS7 Lifters, ARP, FI Chiller, Kirkey Seats SJM Line Lock, Hurst Pistol Grip. 747/739 RWHP street tune - 821/794 RWHP track tune 101 octane. 2014 Mini Cooper countryman S All4 M6 daily driver |
