#29 |
Blessed ❤️
Drives: 2017 1LT RS I4 Join Date: Sep 2016
Lol
Kindness and compassion #OthersFirst |
#30 | |
A Heartbeat Away.........
Drives: Not As Fast As I Would Like To Join Date: Mar 2016
I'm glad I was able to delete that tube. Totally unnecessary. Between the exhaust & the noisy a$$ run-flat tires I could hardly hear the music unless I cranked it up.
2016 Hyper Blue Metallic 2SS | A8 | MRC | Sunroof | Nav | Mishimoto Catch Can | GM CAI | Hurst Shifter | Borla S-Type Exhaust | Body Color Splash Guards | 1LE Splitter | GM Dark Tail Lights | ZL1 Third Brake Light | Custom Fuel Door, Badges & Bowties | Oracle Side Markers | Blacked Out Stuff | Opti-Coat Pro+ The problem with this world is stupidity. I'm not saying there should be penalties for stupidity, but why don't we just take the warning labels off everything and let the problem solve itself. |
#31 |
![]() ![]() Drives: 2016 2SS Hyper Blue Join Date: Oct 2015
I remember early threads before the car was released saying we didn't have this stupid shit. We actually do have it then... great
#32 |
Yeah. Really there. It is the tube that you can see between the red hoses connected to the catch-can. This was taken when the CAI was off for replacement but before the sound tube assembly was removed.
Black tube running from behind catch-can and curving around to the bottom of the CAI inlet. That entire assembly, including the tube poking it's head out like a submarine (pointing right). Hey suzook ...... here ya go. ![]()
2016 Hyper Blue Metallic 2SS | A8 | MRC | Sunroof | Nav | Mishimoto Catch Can | GM CAI | Hurst Shifter | Borla S-Type Exhaust | Body Color Splash Guards | 1LE Splitter | GM Dark Tail Lights | ZL1 Third Brake Light | Custom Fuel Door, Badges & Bowties | Oracle Side Markers | Blacked Out Stuff | Opti-Coat Pro+ The problem with this world is stupidity. I'm not saying there should be penalties for stupidity, but why don't we just take the warning labels off everything and let the problem solve itself. Last edited by Hyper16; 11-05-2016 at 09:41 PM. |
#33 |
![]() Drives: 2016 1LT M6 Join Date: Sep 2016
I am not following why this tube is such a bad thing.
It's my understanding that intake sound enhancement takes three forms: 1. Simulated/recorded sound through the stereo speakers (e.g., turbo BMW, EB Mustang): I can see why people have a problem with this, as it feels like a "punt". The actual mechanical noise of the car was effectively deemed inadequate for the driving experience that the designers wanted 2. Structure-born sound caused some type of tactical transducer (e.g., VW Soundaktor): Arguably still "cheating", as an artificial sound is still being added 3. Piped in sound from the car's actual intake, a la gen 6 Camaro and 2016 Holden Commodore/SS: this is the sound of the actual intake being piped into the car. No electronics or artificially generated sound, just the natural sound of the car channeled into the cabin. I had a four cylinder car that had this and it sounded like crap. Not so with my current LGX, which many journalists have complimented, and I can only imagine the LT1/LS3 versions must sound that much better. If the tube is piping in the natural sound of the car, why is it any worse than installing a louder exhaust, going with NPP, or a non-resonated intake? Aren't these other forms of increasing the desirable natural tones of the car for driving enjoyment? Also not sure why it would be a source of angst. It's just a pipe that can be closed off without affecting anything. It's not adding weight, affecting performance, cooling, and hardly even aesthetics since it's small and mounted low. If you suspect you don't like what it does, the solution is simple. I'm not sure why anyone would dislike this just on principle though. ![]() What also puzzles me is, if you didn't know it was there...why worry about it?
#34 | |
#35 | |
What I am not following is the position of not liking this device just on principle. Like it? Leave it. Don't like it? Bypass it temporarily and see if you like the sound more. Not sure if you like it or not? Drive on and be happy--no need to find stuff to worry about. |
#36 | |
Stick around a while and you'll see how much stuff gets bitched and moaned about. Some necessary, some not. Some real, some imagined. Everyone does it at one time or another. No worries. Just have fun.
#37 | |
![]() ![]() Drives: 22 ZL1, 18 RS3, 22 M3P Join Date: Oct 2016
Power Handling Braking Comfort MPG Safety Style The sound enhancer contributes nothing to any of the above. It's unnecessary. I'll remove any and everything unnecessary that I can from the car to make it faster, handle better, and brake better - but really, this shouldnt be my job. Chevy did a great job cutting weight from this car, so why keep something like this in place?
2022 ZL1 - M6, Wrapped, Tinted, Rotofab intake, MBRP AxleBack, Lots of BMR rear suspension components
2024 Audi RS3 2022 Tesla Model 3 Performance 2018 Audi RS3 - Many mods & e85 Instagram - @JBsCars |
#38 | |
Regarding your list though, I would add excitement/satisfaction. For many enthusiasts, the following things generally contribute in this regard: - Exhaust noise via NPP or aftermarket system - Intake noise via this pipe and/or aftermarket system - Rolling down the window when driving through a tunnel to hear your intake or exhaust--via far more complex hardware than the aforementioned pipe How much does the pipe weigh? It looks like it's less than 5 pounds, maybe less than 3. It's visible enough if you know what to look for, though some in the community didn't realize it was there or are not sure where it is. Having said all that, removing or bypassing it is simple enough that it's not worth losing sleep over. When I did this on my old car, it was necessary to buy a $160 delete kit, and in that case it was totally worth it. The stock noise pipe made that car sound like a Sea-doo ![]() In any case, best of luck with your solution. For what it's worth, I believe the heater/weatherizing plug should be a good solution for the hole on the intake tract, and it might not matter what you do with the hole going into the firewall, as it probably (hopefully) doesn't open into the cabin. As much as my previous post talked about not finding things to worry about, it's also not worth letting a small thing prevent you from enjoying your car. |
#39 |
![]() Drives: S197 Mustang Join Date: Jul 2016
I was told by a Chevy representative that the 6th gen has noise-cancelling technology for the cabin at play in Tour mode, which deactivates in Sport or Track. Could this be related?
#40 | |
You can only YOLO once.
Drives: '16 2SS & '15 Subaru Forester Join Date: Jan 2016
I forget at this point. The metal one in the intake sounds about right...I would still plug the hole to the stupid sound tube as well or take the tube out and plug the hole going to the firewall.
2016 Camaro 2ss
-Summit White / Ceramic White -8A, NPP, MRC, Ceramic White package plus knee pads, black bowties. -1st Car to have the "full" SEMA High Performance Graphics kit from 6LEDesigns. -1st Car to have the 6LEDesigns Blade Spoiler. -Borla S-Type w/ custom H-Pipe -Procharger P-1X Stage 2 |
#41 |
You were misinformed. It does not deactivate in Sport or Track mode. It is just a tube. There is no valve to control it. It is always "ON".
#42 | |
corner barstool sitter
Drives: 08 Mustang GT, 19 WRX Join Date: Jul 2012
Basically, you're being "gamed", manipulated to the mfr's advantage by trickery, been taken advantage of, suckered even. Norm
'19 WRX 6M (the family sedan . . . seriously) |
