#29 | |
![]() Drives: 2015 Z/28 #397 2022 ZL1 #1799 Join Date: Jul 2009
#30 | |
![]() ![]() ![]() ![]() Drives: 1SS, A8, MRC, NPP, Blade Spoiler Join Date: Jun 2010
If low end torque is the goal, just buy an LT1. 315 lbft at 1000 RPM is amazing. 455 HP at 6000 RPM is awesome, and 28 highway MPG's make it better in every metric. The SS produces more power, performs slightly better in a straight line, and gets significantly better MPG's than the M4. And it has more torque at low RPMs than the BMW's turbo engine. And then there is the turbo lag (while minimized, it is still there) and shitty exhaust note. Most things in life are a trade-off. You usually trade performance for MPGs for example. I can't really think of an advantage of the BMW engine at all. What did you get by going I6 Turbo instead of N/A V8? I am guessing it's a bit lighter, but apparently not enough to help out in terms of performance. Of course, if you mod your cars, turbos are easier and cheaper to get significant HP gains, but then you are back to big turbo lag, and even worse MPGs. |
#31 | |
![]() ![]() ![]() Drives: RS Join Date: Jan 2013
Torque at lower RPM may become more of an advantage with the new 10 speed transmissions. |
#32 |
SABIO
MPG concerns with a Track Car? I don't think anyone would care as long as it was a Beast on the Track.
#33 |
Moderator.ca
Are you talking about acceleration or fuel economy?
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
#34 |
#35 |
![]() ![]() ![]() Drives: Want a gen 6 Join Date: Jan 2013
The winged beast from the ring videos has an LT-4 in it to my ear.
#36 |
I hope not! LT5 does not indicate in any way a 427...which is sad...but it DOES possibly indicate a 302 like the original. so...maybe nostalgic.
#37 | |
SABIO
maybe if it comes with a Warp Coil.
#38 | |
Moderator.ca
Well, for acceleration the entire point of adding more gears is to keep the rpms higher. Smaller steps between gears means less of a drop when upshifting, keeping the engine closer to peak power for longer. Making more low rpm torque doesn't improve this by much, if at all.
I don't know enough about the fuel economy side to say whether or not having more low rpm torque would help or not. Quote:
The LS1 was not a 1L The LS2 was not a 2L The LS3 was not a 3L The LS4 was not a 4L The LS6 was not a 6L (though it was close at 5.7) The LS7 was a 7L The LS9 was not a 9L The LT1 is not a 1L The LT4 is not a 4L Based on that history, there is more reason to think that an LT5 won't be a 5L than to think it will be.
#39 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2018 1SS M6 Join Date: Nov 2014
Which is why I wouldn't be overly surprised, only a little surprised, if the z/28 had a derivative of this engine with a very sophisticated suspension, whatever that might be. I do think it would take a lot of guts for GM to not put a V8 in the Z/28 though. If they make a Z/28 |
#40 |
![]() Drives: KIA Forte GT2 Join Date: Jul 2010
4.125 bore x 3.622 stroke. 6.3L. 388ci. Similar cam to LS7 for Gen V LT1 engine. 520-540hp 7000-7500 rpm
#41 |
![]() ![]() Drives: 2004 Pontiac Grand Prix Join Date: Oct 2010
#42 |
We know nothing about the LT5 engine and we know next to nothing about the Z/28 Camaro so people shouldn't get their hopes up based on what they read in here.
