12-28-2016, 05:17 PM | #29 |
Drives: 2012 2SSRS Vert, Black w/M6 Join Date: Jan 2013
Finally got them knocked out! Should be on the website tomorrow!
12-28-2016, 06:52 PM | #30 |
Drives: 11 2SS 6spd, 77 Trans Am, 13Audi Q7 Join Date: Apr 2010
Looks perfect.
2011 Black 2SS, 6 speed, AR long tubes, Borla S type full exhaust, Roto fab, prothane full bushing kit, Fe4 swap and 1le bars, 3.91s and a ton of other little stuff you can't see! No bling, wings, stickers, cool lights or junk without a purpose.
12-28-2016, 06:59 PM | #31 |
Thanks, and price was under target for once, lol!
12-29-2016, 12:43 PM | #32 |
Drives: 2010 2SS-RS, IOM, M6 Join Date: Mar 2012
Just placed order, thanks for stepping up to provide something like this for those which retain the factory shifter. Will update once its installed.
2SS/RS, Inferno Orange, 6sp, Eibach lowering springs, Eibach adjustable sway bar, Exhaust 2.5" dumps before axle, New ERA OTR intake, TSP LS3 225/230 .617/.612 on a 112LSA cam,
Rocker arm trunion kit, ported/polished heads, JRE Tune, ARH Headers, G-Force Axles, 3.91 Gears, Eaton Detroit Truetrac /w Billet Caps, MGW Shifter, DynoTech Driveshaft, E2X Catch Can . |
12-29-2016, 01:15 PM | #33 |
12-29-2016, 02:20 PM | #34 |
The new rear bushing mount is to reduce deflection (added stability with the mounting), appears similar to me at lease what MGW did.
12-29-2016, 03:45 PM | #35 |
If you just have the handle/lever replacement, you still have the soft rubber mount on the rear of the shifter contributing to the sloppy feel of the stock shifter. See in the pics how much it is allowed to move.
12-30-2016, 10:27 AM | #36 |
Just ordered mine!!!!
Orange Krush II
12-30-2016, 10:52 AM | #37 |
Thanks for the orders! Sorry for the delay on getting them done, but they are in stock ready to ship!
12-30-2016, 11:30 AM | #38 |
Drives: 2012 RS/SS LS3 Join Date: Jun 2012
I guess I need to search what hardware came with my factory hurst shifter upgrade to see if these will work for me.
12-30-2016, 12:46 PM | #39 |
All OEM short throw/Hurst shifters use the soft rubber mount. All lever replacements also use the stock mount. The only way to upgrade further prior to these mounts was a full billet type shifter replacement.
01-04-2017, 01:00 AM | #40 |
Drives: cars Join Date: May 2011
How painful is the install? I assume it happens from below versus through the dust boot.
01-04-2017, 07:27 AM | #41 |
yes, similar to a full shifter install but not quite as bad. i was able to get mine in with exhaust and all in place but results may vary.
01-04-2017, 05:56 PM | #42 |
Got mine
Got mine this evening very nice work!!!
Orange Krush II
