#29 | |
Lethal Camaro
Drives: 16 2SS, 71 Std, Suburban RTS Join Date: Jun 2013
Overall from the seat of your pants feel. I want to believe the system is providing more power int he upper RPM ranges. Can it all be in my head? Probably. I will not know until I get the car on the dyno. Overall I will be doing closed hood testing and bring back the other systems again to see how they fair in a cooler morning dyno day. Overall I think I have proven the ECU also doesn't need that much time to adjust. But again, will be looking at all factors once we get it on the dyno. My new Vacuum meter has been fun to play with
#30 | |
![]() Drives: 2016 Camaro 2SS, 6spd M Join Date: Aug 2016
#31 | |
![]() ![]() Drives: 2016 Camaro SS Join Date: Jan 2016
MAF is only semi useful. You can't take the readings from the aftermarket CAIs and infer less or more air. The turbulence could cause higher/lower readings and the actual be the complete opposite. Tim |
#32 |
![]() Drives: 2016 camaro 1SS Join Date: Jun 2015
Love your videos. I've been watching them for a few months now, even before I got mine.
#33 | |
![]() Drives: 2007 335i Join Date: May 2016
I prefer the nostalgia of shounen, like DBZ, and OPM, but I've seen a few that were described as such. |
#34 |
I can tell you that my SC G8GT picked up 1lb of boost with an 11" filter compared to the 8" I originally started with on the dyno.
#35 | |
Lethal Camaro
#36 |
If they can hook up EFILive or HPT it would be extremely valuable information.
#37 |
![]() Drives: 16 Camaro SS w/ Roto-fab CAI Join Date: May 2009
For anyone concerned about the MAF changes when switching to our CAI,
A very knowledgeable forum member purchased our CAI and did extensive data logging over the weekend. He had this to say about the Roto-fab system: "Quick update... I will post specifics later tonite. So I would like to say great job to Rotofab. I am very impressed with not only the construction quality of their intake I am impressed at how accurate they kept the MAF output. The variation on AFR was sub 1% across the RPM band. This was data collected in MAF only mode in the ECM which really isolates the AFR from being influenced by other variables. I did 3rd gear runs (A8) from 1500 RPMs up to redline. The stock vs RF runs were within a couple hours of each other with minimal weather variation. On the power front I was not on a dyno today but the one area that hints at a definite improvement is the MAP. I stays about 1 kPa higher across the RPM range over the stock intake. So as of right now I do expect to see a power increase of some level on the dyno." Link to Tsloper's review thread here:http://www.camaro6.com/forums/showthread.php?t=465449 Michael |
