08-23-2016, 10:19 AM | #29 |
Drives: 2016 Camaro 2SS Join Date: Aug 2009
He had a slight rubbing issue on the front before the car was lowered. When the wheels were spaced out the steering arc changes and the very edge of the tire just touched the inner fender. It was so slight it made a mark but didn't even make a hole.
Now that it's lowered, it's very close to the fender lip, but to my knowledge the owner hasn't had any rub issues there. |
08-23-2016, 10:31 AM | #30 |
Drives: 2017 2SS Convertible European Vers. Join Date: Aug 2016
08-23-2016, 11:33 AM | #31 |
Drives: 2016 Camaro 2SS, Black Join Date: Apr 2016
Putting wheel spacers on a 3700 lb car that puts down 455HP/450 ft-lbs of torque, capable of 1.0 lateral G and has a top speed of over 170MPH sounds like a very bad idea to me. Might be OK on an old ricer Honda Civic but not on a high performance car. I've seen "high quality" wheel spacers break on autocross courses and on the dragstrip. The results were very ugly! Please guys, if you just gotta have that flush look on your new Camaro, save your pennies until you can afford to buy a good set of aftermarket wheels.
08-23-2016, 11:43 AM | #32 | |
Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
2010 Camaro 1LT V6 (Sold. I will miss her!) |
08-23-2016, 07:07 PM | #33 | |
Drives: 2017 Summit White Chevy Camaro 2SS Join Date: Jul 2016
08-23-2016, 07:11 PM | #34 |
08-23-2016, 07:16 PM | #35 | |
08-23-2016, 07:21 PM | #36 | |
Drives: 2016 SS M6, NPP Join Date: Apr 2016
Spacers is like a tune, it has to be done correctly. It's not for everyone and I have always said if one is going to install spacers, do it right and spend the money on a quality set. These probably won't be permanent but since I don't drag or auto x the wear on the wheel hub, spacer, lugs won't be as drastic. If the fail rate was really that high, then H&R, Eibach will be sued and out of business for spacers already. Thanks for the warning tho.. maybe wheels down the road for sure. |
08-23-2016, 07:22 PM | #37 |
08-23-2016, 07:23 PM | #38 |
Drives: '16 2SS GD1 MX0 NPP F55 IO6 Join Date: Jun 2013
He was probably thinking over his alignment when he posted that and had eccentric bolts stuck in his head.
08-23-2016, 07:30 PM | #39 |
hahaha, see I thought he might have been doing a cam also and was hyped up on that (i know I would be)!
08-23-2016, 07:47 PM | #40 | |
Drives: Varies Join Date: Dec 2009
Personally I have tracked my SS at ACS in Fontana, with 15mm Eibach spacers on the front, going 120 mph in the banking with no issue. I check my wheel torque before every session. Custom fitted wheels can cost a pretty penny and sometimes there isn't even the wheel you want available in the exact fitment you need for your vehicle. I don't know the exact circumstances in the scenarios you mention, but I am thinking something was not checked and nor at the proper spec when the incident happened. Joe@STILLEN |
08-24-2016, 09:34 AM | #41 | |
マスタング = 遅い
Drives: 2017 Chevrolet Camaro SS 1LE Join Date: Aug 2015
08-24-2016, 12:59 PM | #42 |
Drives: 2017 Summit White 2SS Join Date: Apr 2016
So does anyone know the negative impact, if any, to adding lowering springs to cars with MRC?
