Old 06-30-2016, 04:10 PM   #29
pjz1082
pjz1082's Avatar
Drives: 2016 Camaro 1LT
Originally Posted by PolynesianPowerhouse View Post
You can do it there but on the 2013, there was a pcv line on top of the manifold. I'd disconnect it and spray directly into the manifold hose as you have someone Rev and keep the rpms at 2000. Once done with the whole can, Rev it a few times and turn off for an hour to soak in.
Start up and go drive on the highway for a few minutes and your good
Awesome! How often would you do that?
pjz1082 is offline   Reply With Quote
Old 06-30-2016, 04:25 PM   #30
GTIanZ28
Drives: 2016 V6 RS Camaro 6MT
I'd imagine that either of these 2 spots would be good for that spray. I was thinking that the sound tube one (circled on the right) would be easiest.
Summit White 2LT RS V6 ZN2 NPP m6 khalihari interior. Order placed 9/26/15 - Picked up 12/17/15!
GTIanZ28 is offline   Reply With Quote
Old 06-30-2016, 04:48 PM   #31
Big Samoan ina little car
PolynesianPowerhouse's Avatar
Drives: 2016 camaro
the oil I run I change ever 10-13k under normal/spirited driving. so I'd do it every oil change.
on the months when the car saw track time, i'd change the oil around 6-7.5K and do it every other oil change.
If I snoozed on emptying the catch can, and I was driving around with it filled, I would do it right after emptying the can. that wasn't too many times, but there were times I'd forget to empty it at an oil change, then 2-3K into new oil, i'd empty it and run a can of the CRC.
runs about 9-11$.... I usually got mine from the local napa.
is that the sound tube? I thought the sound tube was the one under the bottom? I just disassembled that whole area last night for a part, and had to take all the hoses off.
the one on the left is a good possibility. I didn't pay much attention to see where they all ran. on the LFX, it was right on top and front of the manifold.
When I see posts asking "whats the best intake, exhaust, etc" .... the answer to that is like a grandfather telling his grandkids "if you put salt on a birds tail, it'll let you catch it" #ThinkAboutIt
"Winning Tip: Don't take my (or anyone else's) word for it. GO TEST IT!" - Dennis Grant
PolynesianPowerhouse is offline   Reply With Quote
Old 06-30-2016, 04:55 PM   #32
cellsafemode
cellsafemode's Avatar
Originally Posted by cellsafemode View Post
Not what I saw on mine. Where would the catch can be installed? I've yet to see or hear of anyone installing one on the v6.
Bought one assuming I'd have to use it months ago but the complete lack of evidence up until now and the absence of anyone actually installing one has lead me to leave mine on the shelf.
Edit, and what is that a picture of? Doesn't look like the lgx from the pics jacfab took of the lgx intake manifold
Ok, so this is a picture of a V8 intake manifold. Not a V6. in case anyone cared.
Old 06-30-2016, 08:52 PM   #33
The_Driver
Drives: 2015 Camaro 1LS M6
Originally Posted by bballr4567 View Post
On the LGX there is just no need for it. It is not the LLX or the LFX. It's a completely brand new motor that was designed to run on 87. Until someone comes out with absolute concrete evidence that the LGX will run better on 93, my car will use 87.
It may be a completely new motor, but that's only because of the increased bore centers in the block which I'm sure is for a future planned displacement increase to up the power in the future. However, the engine is almost a faithful copy of the previous LFX (except for the AFM feature) down to the integrated exhaust manifolds in the heads and 11.5:1 compression ratio.
As for the fuel octane argument, running at least 89 mid-grade will give you much better drivability at least with the fuel we have around here. Remember, the LGX has 11.5:1 compression. I don't know exactly what makes the LGX different in this regard, but with the LFX I can detect a difference between running 87 regular and 89 midgrade or above.
Having the computer switch into the lower octane fuel tables for spark advance timing will reduce drivability and performance. Running a higher octane fuel will enable the computer to switch into the higher octane fuel tables and spark adaptive cells which will increase spark timing providing slightly better performance and drivability. If that's the case with the LGX, then why not run the higher grade fuel if you can?
Just from a pure drivability perspective, I don't see why you wouldn't want to do that with these engines.
The_Driver is offline   Reply With Quote
Old 07-01-2016, 11:46 AM   #34
ZKJR88
Drives: 2017 CAMARO RS
I'm an idiot. I made my order thinking it was a naturally aspirated V6. My brother has been dead against direct injection and he's telling me to back out.
ZKJR88 is offline   Reply With Quote
Old 07-01-2016, 11:48 AM   #35
bballr4567
Drives: 2016 Camaro 1LT M6
You need to find jac fabs thread on all the different part numbers etc. It is not a copy of the LFX at all. Do they have the same methods? Yes, but not even close to being a copy.
bballr4567 is offline   Reply With Quote
Old 07-01-2016, 12:06 PM   #36
Boilermaker128
Drives: 2010 CobaltSSTC
Dont get too excited about DI coking it's not a massive sell your car problem. My DI LNF has 240,000+ km never an engine problem yet. Some people walnut blast and it's about $100 and 3-5 hours of your time. I am considering walnut blasting my engine but then again I have no lost mpg or driveability so I might not even bother until symptoms show. Maybe my car has lost 10 crank horsepower from the coking, no one knows it happens so gradually the butt Dyno doesn't work.
Boilermaker128 is offline   Reply With Quote
Old 07-01-2016, 12:42 PM   #37
keysersoze
keysersoze's Avatar
Drives: 16 Camaro
the v6 is N/A. Also direct injection is better for fuel economy. Why does your brother hate it?
keysersoze is offline   Reply With Quote
Old 07-01-2016, 03:07 PM   #38
ZKJR88
is it? i checked all over and the fuel delivery method is DI. i havent been paying attention.
he works in a shop
Old 07-01-2016, 05:26 PM   #39
Drives: 2016 camaro
its naturally aspirated.... its just direct injection, as in the fuel is directly injected into the combustion chamber. carbureted, or other forms of injection that isn't direct, the gas mixes with the air at the runners on the manifold, mix and then flow into the combustion chamber together. Direct injection is just a more accurate and efficient way to meter fuel in the combustion chamber.
any car that takes in air through the 4 cycles, most gear heads know as "suck, squish, bang, blow" or intake, compression, ignition, exhaust.... will be called naturally aspirated.
a carbureted car is naturally asprirated, electronic fuel injection, sequential fuel injection, gasonline direct injection (GDI is what the LFX and LGX are called), etc... they are all naturally aspirated.
it just means the engine receives air by sucking it in, on its own. turbos and superchargers would be considered FORCED INDUCTION, to where the air is compressed and more or less STUFFED into the engine. but the engine itself is essentially a giant air pump, fueled by combustion.
Old 07-01-2016, 09:12 PM   #40
b4z
Drives: '06 Pontiac GTO M6, '19 F150 2.7TT
DI is good. It makes more tq and hp and better mpg. On the 3.6L about 15- 20 hp/tq more. It's noticeable.
b4z is offline   Reply With Quote
Old 07-01-2016, 10:01 PM   #41
Drives: 2016 camaro
Here's the bigger problem.... so which company is keen to making a catch can for us?��
Old 07-01-2016, 10:15 PM   #42
cellsafemode
Catch cans are not motor specific. I don't think there is a pcv tube on the lgx to splice into. Everything I've seen and read seem to indicate a direct block to manifold connection.... But i could be wrong. I think the lack of any manufacturers stepping up with a plug and play kit or anyone doing a diy is telling though
