#29 |
Darth Martel
Drives: Black 1SS with 20% tinted windows Join Date: May 2009
I brought mine in and they tried to tuck it back under and add a retention clip. Pulled back out in 2 days. Took it back in and they ordered a brand new seat cover and installed that with some extra clips. It's been fine since. I think, as already mentioned, the factory seat covers are cut too short and not installed with enough retention clips. It's either that or the way the install the seat covers at the OEM. Either way, your service center can fix it by installing a new seat cover with extra clips.
2016 Black 1SS w/ MRC, low-gloss black wheels, auto trans. Self-created custom Dark Knight Edition accents. Rotofab CAI with dry filter and sound tube delete, PRAY ported intake manifold and throttle body, Texas Speed cam, Stainless Works headers and exhaust, Skid Mark garage E85 kit, JMS fuel pump voltage booster, Circle D torque converter. Custom E85/mod tune by Jannetty Racing.
#30 |
![]() Drives: 2016 Camaro LT - Blue Velvet Join Date: May 2014
Glad to hear the dealerships are fixing this issue under warranty. I just noticed it on mine while cleaning it. I had JUST gotten home from picking it up from an overnight stay at the dealer to install parta to fix the fan connector recall amd apparently a rear toe link defect. Now I gotta deal with this?! Man, these little naggy issues are a pain in the ass. Never had any issues with my 2014 aside from the stupid bladekey recall and MyLink locking up but the latter is more to do with Apple screwing with iOS. CarPlay fixed that. But these new model bugs need to stop already.
#31 |
![]() Drives: 2016 Camaro 2SS Join Date: Oct 2016
I just wanted to post to confirm mine is having the same issue. I also noticed there is some gouging on my shifter, almost looks like grooves from pliers. I'll get some pictures later today. You can see the foam and seat latch mechanism under the cover.
Typical F-Body issues, but at least the interior overall is light years ahead of my 4th gens!
2016 Camaro 2SS Garnet Red 6 Speed
1990 Firebird Formula WS6 1989 Firbird Formula 350 WS6, LS Swapped |
#32 | |
#33 |
#becauseracecar
Drives: 2016 SS Sedan, 2016 Camaro SS Join Date: May 2015
I just looked at mine with 320 miles on the odometer and this is starting to happen. I'm going to wait until it's almost out of warranty probably (unless it gets much worse)but I'll take a photo now for documentation.
#34 |
![]() Drives: 16 Summit white, Ceramic white 2SS Join Date: Jan 2016
Can Confirm this is also happening on ss models with color option interiors. I have white seats and it also pulling out right there at the seat forward Handel. It does not annoy me enough to even mention it to the dealer tho
#35 |
Unless they redesigned the cover, from what I see it will just continue to happen. The cut out around the lever should (in a decent design) have a plastic buffer or retaining ring that the cover is sewn to and fits around the lever housing.
Without that to distribute tension and secure it to around the lever, it's going to pull out and eventually tear.
#36 |
![]() Drives: 2016 Camaro 2SS (on order) Join Date: Mar 2016
I rarely lean my seat backs forward, except to clean the back. Are those of you having this problem using the levers a lot or might this be caused just by merely sitting in the seats?
V8, Dual Exhaust, MRC, Nav, Sunroof, Loaded "Ahhh! Take care to get what you like or you will be forced to like what you get!" - Lyrics from a song from Scooter: "Apache Rock the Bottom!" Previously owned 1998 BMW 540 w/M-series package 1991 Trans Am GTA 1985 Saab 900 Turbo (Burned leaded fuel on the Autobahn) 1985 Firebird (R.I.P.) 1976 Camaro LT |
#37 |
Getting in and out cause it. I don't use the seat lever. What happens is you get in the car pulling the cover down, you are pulling that cover down sitting in it, scooting around, or getting out.
I'm not a big guy, but I guess 200lb is rough on these seats.
#38 | |
![]() Drives: 2019 Mustang GT Convertible Join Date: Oct 2016
Not to mention, the floor carpet is also coming out from under the molding, that was cut short too! Bear |
#39 |
Just got back from the dealer about this. I can confirm they'll do a warranty replacement of the entire seat cover.
#40 |
The first time they tried to fix it, that made it look like ******* will you get it have to take back next week so they can replace it, hope that helps.
#41 |
![]() ![]() ![]() Drives: 16 Camaro, 11 Stryker, 00 Explorer Join Date: Dec 2015
After reading through this thread I finally remembered to check mine today and luckily everything was still good. I'll have to keep an eye on it now to make sure that it doesn't start coming apart.
About 8k miles. I'm around 243 lbs if that makes a difference.
NGM, 2SS, 6MT, NPP, MRC, Nav, Kalahari, Grey Wheels
1100 12/14/2015 3000 1/8/2016 (TPW 2/1) 3800 2/1/2016 5000 3/5/2016 Last edited by 63falcondude; 12-14-2016 at 10:14 PM. |
#42 |
![]() Drives: 2016 SS Nightfall Gray Join Date: Oct 2016
Dealer replaced
Took mine to the dealer and he replaced both seat backs with no questions asked.
I asked him if the new ones will do the same thing, but he said they are revised to not pull away from the seat latch cover. |
