#29 |
![]() Drives: 2017 2SS A8 FIFTY/2014 Silverado LT Join Date: Aug 2014
Ricardo, I am on yalls website looking at the race series cat back. There is no listing for the A8 17. So as stated above, do I just need to order the manual version and tune for the AFM light? I really like this exhaust, i am sure matched with the Roto Fab CAI, it will make this car really growl.
#30 | |
![]() Drives: 2016 Camaro 2ss Join Date: Feb 2016
#31 | |
![]() Drives: 2017 Camaro 2SS Join Date: Dec 2016
I looked at this exhaust for quite some time, however, I ordered the Borla S-Type yesterday. Hoping the S-Type will be loud enough paired with Rotofab's intake. |
#32 |
I have been looking at exhausts since we ordered the car. I was hooked on the borla ATAK until I saw this video. Efituning makes the error eliminator pigtails to solve the AFM code. There's a link on the previous page. But for future mods and tunes, I want a catback as the car will get longtubes and full exhaust and possible cam swap.
#33 | |
#34 |
![]() Drives: 2016 Nightfall Grey Metallic 1SS Join Date: Nov 2016
I have the NPP on my 16 and with the valves being deleted from the exhaust function will there be an error code?
#35 | |
The BEAST
Drives: '16 2SS, '89 Wife Join Date: May 2015
http://www.rangetechnology.com/pages/v8 From their page: "The Range AFM Disabler Device keeps your vehicle in 8 cylinder mode 100%, preventing the Active Fuel Management system from dropping cylinders. This is the only product that will disable Active Fuel Management without reprogramming the factory ECU. Full power delivery all the time without factory warranty concerns." There are at least two people I've seen here with it on. Check the amazon listing here to read reviews and decide for yourself. https://www.amazon.com/Range-Technol.../dp/B00BR1R8N8
#36 | |
![]() Drives: 2016 Bright Yellow 2SS A8 Join Date: Jul 2014
If I'm not mistaken the ECM only controls what's going on inside the engine. The CCM controls the valves so at some point in time you will get a code. Tim from EFI tuning has addressed this with a AFM delete Module. You can find it on his site. http://efi-tuning.net/efi-tuning-201...module-set-v2/ There are two parts to the picture. The first part is the engine management side. The ECM directly controls what is going on inside the engine as it pertains to AFM. The CCM controls the AFM and NPP valves. Because the CCM controls these entities we do not have a way to tune out the codes related to on them. If the CCM doesn't see what it is expecting to regarding the valves it will set the CEL. If you disconnect them you will definitely set a CEL. If you keep them plugged in but tie them out of the way you may set a CEL at some point. Below is his explanation on it: The EFI Tuning module addresses the CCM side of the picture. The module replaces the valve actuator and keeps the CCM happy. The version currently sold on our website requires that AFM be disabled all together in the ECM. Anyone using a non-AFM camshaft or wanting to go to a non-AFM aftermarket exhaust system will fall into this category. The next version I'm completing the layout on today will allow you to keep AFM active in the ECM but not need an AFM compliant exhaust system. This use case was requested by some of the C7 guys. I prototyped it early on so it is just a simple PCB and firmware change to accommodate. Please let me know if I've managed to confuse anyone Depending on which exhaust supplier you look at you may save yourself a considerable amount of money going with this solution. Thank you, Tim |
#37 |
18 ZL1 A10 Convertible
Drives: White ZL1 Convertible Join Date: Oct 2016
I have the MBRP Cat back and it's awesome just saying....
I did not have NPP to start with and only the single outlets... Now Dual with Quad tips sounds amazing....no drone ... |
#38 |
![]() Drives: 2016 Camaro 2SS Summit White Join Date: Jan 2017
I absolutely did. You guys are awesome. I contacted customer support and they rerouted the package back to the warehouse before it got to me. The have been extremely helpful and great to deal with. I'm getting store credit for it(which was the option that I chose). So, I will definitely be making a better researched purchase(s) soon. Ha!
#39 | ||||
#40 |
If you have HP tuners you can turn it off. Getting ready to tune mine and turn it off.
#41 | |
![]() ![]() Drives: New : 2017 SS 1LE Old: 2012 TTRS M6 Join Date: Oct 2015
The process of aluminum corrosion actually protects the rest of the aluminum...the oxidization process actually stops further corrosion.... forms a protective layer.... if you dont scrape off the aluminum oxide it will be fine...
. https://www.wheelwell.com/profile/56...ed9c3a/garage/ . . Project 1LE Wraith: http://www.camaro6.com/forums/showthread.php?t=474068 |
#42 |
![]() ![]() Drives: 2016 Hyper Blue Metallic 1SS M6 NPP Join Date: Jan 2016
Since you have had some time with the exhaust what do you think of it overall? I am trying to decide weather to go with this or Borla Atak and keep my NPP function.
2016 Hyper Blue Metallic 1SS M6 with body color hood vents, Silver broken 5 spoke wheels, NPP dual exhaust, Dark Night Interior Spectrum Lighting, Illuminated door sills plates. Upgrades include: Roto-Fab intake, Mishimoto catch can, MBRP cat-back Race exhaust, TSP 1 7/8 headers, EFI E85 Flex Fuel, MRR M017 graphite wheels with Nitto N555 G2 tires, Goodridge stainless steel brake lines, Powder coated Brembo calipers, BMR suspension, Eibach sport springs, Emblempros fender badges Order ID: TDHQMS 1100 on 01/07/2016 at Penske Chevrolet 6000 on 02/23/2016 Delivered to customer |
