Old 06-02-2016, 02:59 PM   #29
Lisa@Borla
Lisa@Borla's Avatar
Drives: -
Originally Posted by AbsolutHank View Post
Just looking for some clarification. It clearly states in the instructions that these X pipes are not designed to work with the factory NPP system, I assume because of the different pipe diameters?
So, unless I'm missing something, are we still not looking at a proper X pipe option for NPP cars?
Hi there,
Good question!
These are the proper X-Pipes, we just designed them to work directly with our rear sections for the 2016 Camaros, however you can use them with your stock mufflers, it will just take a little more effort on your part... Our X-Pipes won't directly bolt onto your stock mufflers so you'll have to either:
1) cut your stock exhaust, expand the pipes, then clamp our x-pipe on
- OR - 2) cut your stock exhaust and weld our x-pipe on.
Any muffler shop can do this for you or you can do it yourself if you have the proper tools and knowledge to do so.
I hope that helps! Please let me know if you have any more questions.
Lisa@Borla is offline   Reply With Quote
Old 06-02-2016, 03:04 PM   #30
david borla
david borla's Avatar
Drives: Ford GT
Originally Posted by Lisa@Borla View Post
Hi there,
Good question!
Keep in mind the factory exhaust is one piece, meaning there is no connection point between the factory rear section and the factory X-Pipe.
As a result, you have to cut and clamp, or cut and weld, if you want to add ANY aftermarket X-Pipe to the stock rear mufflers on the 2016 Camaro SS with NPP.
david borla is offline   Reply With Quote
Old 06-02-2016, 03:10 PM   #31
Lisa@Borla
Lisa@Borla's Avatar
Drives: -
Originally Posted by KyleL View Post
Hi, Lisa. I have a few questions:
Will I be able to use the X pipe for LT's in the future?
What is the difference between the X pipe that's street legal and the one that isn't? I see it says it's smog legal, but what is the difference in the two?
Also, for the X pipe w/o afm valve, will that cause any cel to come on if it is not hooked up?
Hi Kyle,
-We will actually be releasing our Long Tube Headers and our 3" exhaust systems specifically designed to go with our Long Tube Headers soon. We will also be offering an adapter that will enable you to use our X-Pipes that are out now with our Long Tube Headers as well, so yes.
-Our competition/racing only X-Pipes delete the secondary cats and the street/smog legal X-Pipes keep the factory cats.
-Yes, you will get a CEL if you delete the AFM valves. We usually don't recommend that you get our x-pipe without AFM valves unless you are going to be highly modifying your vehicle with Long Tube Headers, etc... but if you do decide to get Long Tube Headers, then you will get a CEL also because Long Tube Headers require you to remove the factory cats. This is why this set up is also considered competition/racing only or NOT street/smog legal.
Old 06-02-2016, 03:49 PM   #32
KyleL
Drives: Slow
Hi Kyle,
Thanks for the response. I do plan on going with LTs in the future, so I will definitely need a tune. Can the tune remove any cel caused by not hooking up the afm valves?
2016 Toyota 4Runner
2017 Camaro ZL1
KyleL is offline   Reply With Quote
Old 06-02-2016, 05:32 PM   #33
Tazz3069
Tazz3069's Avatar
Hi Kyle,
Thanx Lisa.
That clarifies everything. I will be placing my order soon.
2016 Camaro 2SS "Black Widow"
Tazz3069 is offline   Reply With Quote
Old 06-03-2016, 10:05 AM   #34
mjgocamaro_girl
mjgocamaro_girl's Avatar
Drives: 2016 Camaro 2SS mosaic black
Will there be a video for the axle back ATAK non npp? If not will it sound the same as the npp? My husband is ready to buy but would like to have an idea of the sound. He is comparing it to the Flowmaster outlaw axle back. Is there much difference between the axle back & the rear, xpipes as shown on the video? Thanks
2016 2SS MOSAIC BLACK, SILVER RALLY STRIPES, ADRENALINE RED, NPP, MRC, 56F WHEELS
mjgocamaro_girl is offline   Reply With Quote
Old 06-03-2016, 12:27 PM   #35
david borla
Drives: Ford GT
Sound is very similar to the NPP with valves open.
Start with the rear section/axle back and then add an X-pipe later if you desire additional sound modification.
Our systems have NO DRONE, they are DRONE-FREE, and we stand behind them with a million mile warranty, including our exhaust tips (read the find print on other companies' warranty verbiage). We specifically warranty for rust because the material we use will never rust (again read the others' fine print).
Old 06-03-2016, 01:47 PM   #36
fsusmithc2
Emerald Coast Camaros
fsusmithc2's Avatar
Drives: 2017 2SS A8 50th Anniversary
I have a 2017 2SS on order and I'm getting my wish list in order and a full Borla cat-back setup sounds like a pretty good idea to me. Only issue is I specifically ordered the car to not have NPP because all loud all the time is fine by me. Any rough guess as to when the non-NPP rear section is expected? I'm probably taking delivery of my new ride around the end of July or early August and might be looking at exhaust pretty soon after that.
Current: 2017 2SS 50th Anniversary (#350)- 12.22 @ 115mph
- MX0 8-speed automatic, CF5 power sunroof
Former: 2012 1LT/RS A6 - 14.11 @ 99.75mph
Order: TMFF65
1100 - 5/19/16 | 2000 - 5/26/16 | 3000 - 6/1/16
3100 - 6/6/16 (TPW 6/20) | 3300 - 6/9/16
3400 - 6/10/16 | 4200 - 6/23/16 | 4300 - 6/28/16
5000 - 6/30/16 | 6000 - 7/1/16
Club F1FTY
fsusmithc2 is offline   Reply With Quote
Old 06-03-2016, 02:07 PM   #37
david borla
Drives: Ford GT
Already released! - Both S-Type and ATAK
S-Type - https://www.borla.com/products/camar...rt__11922.html
ATAK - https://www.borla.com/products/camar...rt__11923.html
Add an X-Pipe later if you want additional sound enhancements and the touring resonator if it's too loud.
Prices on our website are full retail. You can find them for a bit less at your favorite retailer.
Old 06-03-2016, 02:22 PM   #38
GreaseMonkey83
GreaseMonkey83's Avatar
Drives: 2016 Camaro
So from what I am gathering, for my factory NPP car I can buy the x-pipe first and install with some minor modification to the inlet tubes on the stock muffler (cut-spread-clamp). Then down the road I can ditch the stock muffler and buy an axle back from you guys and basically bolt it in. And then even further down the road I can buy your headers and bolt them in as well. Pretty cool idea, ill definitely be looking into buying an x-pipe as my next mod if this is how it works.
2016 Garnet Red 2SS M6 MRC NPP and Sunroof
100% Stock - 12.10 @ 115.6mph - 3620 lbs lookin' at it
GreaseMonkey83 is offline   Reply With Quote
Old 06-03-2016, 04:00 PM   #39
david borla
Drives: Ford GT
Yes!
Old 06-03-2016, 04:06 PM   #40
fsusmithc2
fsusmithc2's Avatar
Well then, that answers that question. I was basing my comment on the original post saying it was coming soon but soon must have been sooner than I thought. You guys are at the top of my list as of now.
Order: TMFF65
Club F1FTY
Old 06-06-2016, 06:50 PM   #41
brutusvk
Drives: future 2016 SS
Ordered the x pipe set up and ATAK rear section through a vendor today. Can't wait. Glad I finally have a lift in the shop. Should make it easier to install!
brutusvk is offline   Reply With Quote
Old 06-10-2016, 10:14 AM   #42
brutusvk
May be a dumb question but I am wondering if it is ok to install the rear section now and then install the x pipe set up later. (The x pipe isn't 't due to ship for several weeks.) will this complicate the install?
2016 camaro, borla, borla exhaust, borla performance industries, exhaust system
