07-11-2016, 11:27 AM | #29 | |
K1SS MY SS
Drives: 2016 Chevy Camaro 1SS Join Date: Mar 2016
Chillin wit the Stangs
08-18-2016, 08:14 PM | #30 |
Drives: 2016 Summit White SS Join Date: Jun 2016
Has anyone replaced the 6x9 in the doors yet? Do they require an aftermarket bracket to hold them? I know on the older camaros you could cut out stock speaker and use the stock bracket.
08-20-2016, 12:15 PM | #31 |
Darth Martel
Drives: Black 1SS with 20% tinted windows Join Date: May 2009
I have not done this yet though I do plan to in the future. I think there is a 2SS stereo upgrade thread where somebody showed replacing the door speakers. It wasn't long ago so should be within the first couple pages of the the audio section.
2016 Black 1SS w/ MRC, low-gloss black wheels, auto trans. Self-created custom Dark Knight Edition accents. Rotofab CAI with dry filter and sound tube delete, PRAY ported intake manifold and throttle body, Texas Speed cam, Stainless Works headers and exhaust, Skid Mark garage E85 kit, JMS fuel pump voltage booster, Circle D torque converter. Custom E85/mod tune by Jannetty Racing.
08-21-2016, 07:48 AM | #32 |
Drives: 2017 Camaro 50th Anniversary 2SS Join Date: May 2016
50th Anniversary Edition 2SS, NFG, BLACK, M6, MRC, NPP, BLACK BOWTIES
Build Date: July 21, 2016 Production Sequence: 934 |
08-23-2016, 05:16 PM | #33 |
Airborne Paratroopers!!!
Ok...stupid question: I'm pretty sure that there is NO room in the trunk for a sub in a vert, is that correct? Not even a slim one?
08-25-2016, 09:57 AM | #34 |
Darth Martel
There's always a way. Contact Steve at sub of thump. Although, he'd need a convertable to work with, take measurements, check how it fits, etc...
10-10-2016, 04:50 PM | #35 |
Drives: 2016 Camaro 1ss, nightfall metalic Join Date: Oct 2016
Hi guys, I'm new to the group. First I want to say thanks to the guys that posted the info and wiring schematics for hooking up a sub. I used this info to hook mine up. It works great. In regards to the exhaust sound coming through the amp, I found by clipping the green and the green/black wire from the black connector (the one to the left of the green connector) I eliminated the exhaust sound. The turn signal and all other functions work leaving the connector plugged in. hope this helps.
again, thanks guys for the sub instructions! |
10-11-2016, 05:28 PM | #36 |
Darth Martel
Excellent info... Hopefully we can get somebody to try this and confirm. Thank you for sharing.
10-26-2016, 12:10 AM | #37 |
Drives: White LT, V6, Auto, RS Join Date: Oct 2016
I can confirm the LT wiring schematic is the same but there is no amp. I cut in at the speaker locations and found the same color scheme. I did not want to get deep into the dash to get to head unit.
Curious if anyone has experience getting to the head unit. |
10-29-2016, 07:31 PM | #38 |
Drives: 2016 Hyper Blue Metallic 1SS M6 NPP Join Date: Jan 2016
Just wondering if you have made any new upgrades to your system? Also how are things holding up with tapping into the factory amp? Getting ready to take mine apart this winter while the Camaro is in storage to do my upgrades. I am going to order sub of thumps dual 12" box. I thought by now they would have their plug-n-play audio connector for adding a aftermarket sub.
2016 Hyper Blue Metallic 1SS M6 with body color hood vents, Silver broken 5 spoke wheels, NPP dual exhaust, Dark Night Interior Spectrum Lighting, Illuminated door sills plates. Upgrades include: Roto-Fab intake, Mishimoto catch can, MBRP cat-back Race exhaust, TSP 1 7/8 headers, EFI E85 Flex Fuel, MRR M017 graphite wheels with Nitto N555 G2 tires, Goodridge stainless steel brake lines, Powder coated Brembo calipers, BMR suspension, Eibach sport springs, Emblempros fender badges Order ID: TDHQMS 1100 on 01/07/2016 at Penske Chevrolet 6000 on 02/23/2016 Delivered to customer |
10-29-2016, 10:18 PM | #39 |
Darth Martel
I haven't upgraded anything else as of yet. The wire taps are holding up nicely and I haven't had any issues whatsoever with the system. Everything sounds great which is why I haven't had much drive to upgrade the front speakers. I think it helped that I switched from Iphone to Android phones because I'm now using FLAC audio files instead of MP3s and they are much higher quality so what's getting amplified isn't garbage. I'll probably just hold off until there's a decent guide to getting the dash apart and access to the tweets.
10-30-2016, 02:02 PM | #40 | ||
Drives: Jeep Join Date: Oct 2016
Also is your box sealed? |
10-30-2016, 02:23 PM | #41 |
Drives: 2020 Camaro 2SS Join Date: Aug 2009
10-30-2016, 02:59 PM | #42 | |
