Old 05-31-2016, 10:54 AM   #29
toohighpsi
Drives: 2015 C7 Z06 M7
Originally Posted by JoeAyalaM View Post
Are Meth pumps anywhere near reliable? I do not think so, at least not for my engine.
Not going to argue that! Meth is the lowest cost / highest risk solution of those listed, but it is effective at making good power - big question is - are the failsafe products that are available enough to prevent damage if a pump failure occurs. I don't have that answer yet.
Old 05-31-2016, 11:07 AM   #30
BlkReaper
Drives: 2016 2ss
Originally Posted by KyleL View Post
Might not have 93 where he's at...
Wasn't aware 93 wasn't at every pump....
BlkReaper is offline   Reply With Quote
Old 05-31-2016, 12:43 PM   #31
1KillerSS
Too much is never enough!
1KillerSS's Avatar
Drives: AGP TT SS [COTW] 4/20/15
Send a message via Skype™ to 1KillerSS
Actually the pumps are quite reliable, at least Alky Control pumps are. Plenty of people running around with no issues.
This is a very good point. Good tuners know how to put in failsafes within the tune, there are also mechanical things that can be done. Me personally like a combination of both.
A lot of people "think" they have failsafes, and that their failsafes will PREVENT them from blowing an engine. The truth is, an engine should never rely on meth, it should be a supplement. A meth dependent engine will have a catastrophic failure when it runs out of meth.
AGP TT kit, 54/57 Forged rotating assembly, Custom grind cam... Dual nozzle meth, ID850's, Livernois dual fuel pumps, ECS BAP, 25% UDP, 3 inch Magnaflow catback with X pipe, Mantic 9000 clutch, DSS 1000hp axles, DSS aluminum driveshaft, ZL1 rear end, solid subframe bushings, HE differential offset bushings, BMR Trailing arm, BMR toe rods, Lingenfelter LNC-2000,SJM Line Lock. 747 whp 714wtq
Build thread
http://www.camaro5.com/forums/showth...55#post8107855
1KillerSS is offline   Reply With Quote
Old 06-05-2016, 02:42 PM   #32
ender2664
Drives: 2016 2SS
Originally Posted by BlkReaper View Post
Why not 93
No 93 where I live :(
Closest station is 3-4hrs and across state lines.
ender2664 is offline   Reply With Quote
