Old 04-26-2016, 10:20 AM   #29
HumanWiki
Drives: Car
Those are ports to generate something they're calling an "air curtain"...The LT and SS bodies have it...to reduce turbulence, and therefore drag around the spinning wheel.
The ZL1 does not have this port, however. The slight expansion of the fenders and wider tires must have rendered that unnecessary.
Ah, ok.. Cool.. I missed that air curtain part.. They really did do their homework when designing the Gen 6 and seem to have really paid attention to the issues that needed correcting from Gen 5.
HumanWiki is offline   Reply With Quote
Old 04-26-2016, 10:44 AM   #30
Camaroguy555
Drives: SUMMIT WHITE 2016 1SS NPP 6MT MRC
Originally Posted by Hellobatman View Post
How is the install/take-off on the deflectors? Time to put on take off? Relative ease? I saw them in the trunk on an SS I test drove, wasn't sure what they were. Now I know.
I did it at the shop and it took me 45 minutes. Remove the wheel, caliper, and rotor. Pull the rotor backing plate. Use two of the backing plate bolts to install the ball joint heat shield. Remove the small air guide on the control arm by taking off the three bolts holding it on and replace with larger air guide (be careful with these, they are more like screws and don't thread in very easily). Reverse order when putting everything back on. Remove tire deflectors (toward front of bumper) before track use by removing 5 bolts behind them. Leave them on for city driving, they will help with fuel economy. And don't forget our wheels torque to 140 ft/lbs!!!
Camaroguy555 is offline   Reply With Quote
Old 04-26-2016, 11:05 AM   #31
Hellobatman
Hellobatman's Avatar
Drives: 2017 Ford F250, 2019 Lincoln Navi
Man that's a high TQ value for wheels!
Hellobatman is offline   Reply With Quote
Old 04-26-2016, 12:59 PM   #32
ssrs2lt
ssrs2lt's Avatar
Drives: too many
Go Becky! Awesome video no matter how many times watch it.
