#29 |
![]() ![]() Drives: 2016 Camaro SS Join Date: Jan 2016
Current O2 delete changes
- disabled B1S2 and B2S2 O2 sensors - Engine Diag -> DTC's -> P0036: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P0037: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P0056: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P0057: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P0141: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P0161: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P0138: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P0158: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P0054: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P0060: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P0038: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P0058: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P0137: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P013A: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P013B: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P013C: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P013D: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P013E: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P013F: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P014A: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P014B: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P0157: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P0420: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P0430: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P2096: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P2097: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P2098: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P2099: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P2270: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P2271: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P2272: SES Enable -> unchecked, Error Mode -> No Error Reported - Engine Diag -> DTC's -> P2273: SES Enable -> unchecked, Error Mode -> No Error Reported Last edited by TSloper; 04-23-2016 at 02:59 PM. |
#30 | |
Best 300 ever, $30 per HP, no drawbacks and better sound...
#31 |
![]() Drives: 16 Camaro SS Join Date: Nov 2015
Can we get a video of the car and how it sounds?
#32 |
its pretty subtle with the standard exhaust. I highly doubt a plain vid would capture. Overall the sound with CAI CAI, MSD Intake and Cat delete is pretty good for a standard exhaust. I like the SS works bypass (side burner) for the Challenger and may do that if and when they produce a set for the 6th gen. Kind of like the OEM Boss setup but better...
http://stainlessworks.net/dodge-chal...odular-exhaust
#33 |
#34 |
![]() Drives: 2014 L86 Denali Join Date: Mar 2016
You put the stock intake back on?
#35 |
#36 |
I did mine in about 1/2 hour take-off.
1) spray liquid wrench on all bolts / nuts 2) remove front 02 3) use 3/8 breaker bar and whoble to loosen all nuts, 1 drivers side needed a u Joint cause I I don't have mid length 15mm and or could find my shorter wobble. 4) use electric wrench to remove all 5) drivers side clamp is a bear, it needs to be LOOSE, the front cat inserts into the rear exhaust and this clamp is welded to the front cat and goes OVER the lip of the rear exhaust. Basically the rear flange is sandwiched and if the front cat clamp ain't loose, it aint coming off. put on is about 20 minutes, I need a cheap and small 15mm wrench, one bolt both sides. Stubby a must IMO or just cut the $3 autozone one in half. also a shout out for TSloper for walking me thru the cat don't monitor function. No check engine! My car M6, base exhaust has a much more subdued sound vs TSloper. To my mind it sounds a little like my 440 dart with flowmasters, or like the sound track of bullet. It is most evident at start and low to midrange RPM at WOT. I'm completely happy with the product, the performance gain, the price, the sounds and more than happy about the quality. I may just weld O2 bungs in back of the second cats and see if there are any codes with the stock programmer, sheer laziness has kept me away from this project. Stock Header: This is a twinwalled header pipe in pipe just like the original LS1 manifolds, Unless you want to do a lot of cutting and welding you ain't getting the inside pipe out. The last collector is cast and it is 2.1" ID both sides. You maybe able to get 2.2 or 2.25 fully ported, you probably could port it right on the car....
#37 |
For those with NPP...
I pulled the fuse today and find this to be the best configuration for the cat delete from a sound perspective. I couldn't justify switching to another exhaust system until I do something significant power wise. It sounds good at all RPMs. |
#38 |
![]() Drives: 2016 Camaro 1SS A8 Join Date: Jan 2016
Thank you for the review TSloper! Glad you like them. We will look into including O2 plugs in the future.
2016 1SS A8
7.9 @ 90.79 Stock with a tire 7.20 @ 94.71 LBO getting kicked out Now tuned on E85, CA Performance Test pipes & Circle 4C 3800 stall shooting for low 7's next time out. |
#39 |
![]() Drives: 2016Camaro+1968Chevelle+1954BelAir Join Date: Feb 2013
Why does this only remove the primaries leaving the secondaries for what purpose? I would think the majority of new owners would want rather a unmonitored secondary delete leaving the primaries without O2 or warranty issues. Or a cat delete that removed them both. Please explain, thanks. I'm interested in doing this as well
"Lead me, follow me, or get out of my way." GGSP
#40 |
the primaries are IMO where the restriction is. The have many turns, heavily crimped and they are the hottest meaning the exhaust gas has the most volume and energy. So the most HP is to be gained. Plus it looks like the stock header can be ported form 2.1 to 2.25 ID on the exit, a perfect match.
The second 02 appear to be much bigger and are straight and run cooler, meaning less restriction. What you say is true, if warranty is an issue then 2nd CAT back is your ONLY option and it is not a true bolt on as it requires cutting up the stock H pipe. IMO it is far more costly and will yield less HP. Same goes for an even more costly after 1st CAT back a(a true Bolton), IMO it will cost a lot more and yield less HP. I have an M6 and the 1st gear really needs a lot of mid range torque so I opted to keep the tri-y factory header, run a longer runner and larger plenum intake, and tune. So far I'm happy. I'm still in the tuning process. BTW I can easily weld bungs in back of 2nd cat and run the 02 with no need to tune, sheer laziness prevents me from doing so.
#41 |
![]() Drives: 2016 SS Join Date: Jan 2016
i am surprise these delete pipes shows no gain or lost power under the curve from 3500 rpm up to 6k with stock tune.
#42 |
Thanks oldman I have the M6 as well, not sure what you meant by the H pipe? My x pipe is much further to the rear. Also are the round sections mid way on the exhaust resonators? and the hp benefits from removing both cats with a tune? Don't mind me I just rather ask first
