Old 01-25-2016, 02:07 PM   #29
Bassment
Drives: 2016 Red Hot 2SS M6
I get skip shift indicator all the time, mainly when turning at a light from a stop. I never have been locked out of 2nd or 3rd though. I just gives me a warning on the HUD/dash to shift 1-4. Is there a way stop it from being on the HUD/dash?
Bassment is offline   Reply With Quote
Old 01-25-2016, 02:09 PM   #30
BESTPL8
Drives: Hyper Blue 1SS Manual - SOLD
I plugged a SLP skip shift eliminator P/N 21008 into my 2016 1SS and it worked like a charm, but anything that works on a 2015 TREMEC TR6060 should work on a 2016.
BESTPL8 is offline   Reply With Quote
Old 01-25-2016, 02:10 PM   #31
63falcondude
63falcondude's Avatar
Drives: 16 Camaro, 11 Stryker, 00 Explorer
Good news! Thanks!
NGM, 2SS, 6MT, NPP, MRC, Nav, Kalahari, Grey Wheels
1100 12/14/2015
3000 1/8/2016 (TPW 2/1)
3800 2/1/2016
5000 3/5/2016
63falcondude is offline   Reply With Quote
Old 01-25-2016, 02:43 PM   #32
fastball
Drives: 2017 Camaro 2SS 6MT
Originally Posted by priusowners View Post
I agree, but since I want to make Mods easy & reversible for those
here who've not been born undernearh a car:
The CAGS harness is easily accessible and completely plug and play. If you've plugged a mouse into your computer at any time in your life you can install the harness. It installs in less than a minute, and you can remove any time you want in under a minute.
You only have to go under the car because, well, it's under the car.
fastball is offline   Reply With Quote
Old 01-25-2016, 02:51 PM   #33
63falcondude
Will this work? http://www.ebay.com/itm/like/2515378...chn=ps&lpid=82
1100 12/14/2015
3800 2/1/2016
5000 3/5/2016
Old 01-25-2016, 03:47 PM   #34
jaymsu
Yeti's Daddy
jaymsu's Avatar
Drives: ATS-V, Prowler, M6 V10
Originally Posted by 63falcondude View Post
http://www.camaro6.com/forums/showth...69#post8863069
Gen5DIY guys posted on tech section.
http://www.gen5diy.com/P-P-Harness5/...Shift-Harness/
This is the link to their CAGS bypass. I'm ordering now!!!
FREEDOM~~~~ (of shifting....)
2SS Nightfall Grey /Adrenaline red interior
NPP / MRC / Nav / 6 Spd
1100: 7/27/15 <SSWNNN>
3000: 9/04/15 <TPW:10/19/15>
3800: 10/19/15 <VIN: 117740>
6000: 12/16/15
jaymsu is offline   Reply With Quote
Old 01-25-2016, 06:16 PM   #35
63falcondude
Thank you!
1100 12/14/2015
3800 2/1/2016
5000 3/5/2016
Old 03-09-2016, 09:07 PM   #36
Camaro36
Drives: Camaro 2SS
Did you install it and did it work fine?
Camaro36 is offline   Reply With Quote
Old 03-10-2016, 08:34 AM   #37
LesBaer
FMPG
LesBaer's Avatar
Drives: 2016 2SS
I ordered one from Phastek yesterday after speaking to them over the phone. They confirmed that it worked if that helps you at all.
ARH 1 7/8" ceramic coated full sys w/NPP; Maggie 9.2psi (85mm); Jannetty rough idle cam(TSP), tune and LT4 fuel system; Forgeline VX1 Black PVD (20x10,11); R88R 315's; ALPriority; BMR rear arms, bushings, DS loop; RF intake (red); nGauge
93 octane: 712rwhp, 654rwtq / E85 (E66 mix): 734rwhp, 674rwtq (SuperFlow Dyno)
LesBaer is offline   Reply With Quote
Old 03-13-2016, 08:00 PM   #38
Camaro36
Drives: Camaro 2SS
Anyone that has already installed these on, does it also eliminate the warning message as well or just lets you shift into 2nd gear regardless?
Hopefully it doesn't show you the warning message after installing it cause that would be annoying
Old 03-13-2016, 09:21 PM   #39
Stex
Drives: 67 goat, 69 goat ram air III
Thank your local epa for the light...that would be the gov....t..That would be the gas qus tax ...that would be the gov....t...most have said the light stays? good luck...
Stex is offline   Reply With Quote
Old 03-13-2016, 09:31 PM   #40
fastball
Yes the light stays. The harness just kills the power to the actuator that slides the pin. The car's ECM still thinks it's activating CAGS and will display it.
To disable the display you need to reprogram the ECM.
Old 03-14-2016, 09:26 AM   #41
63falcondude
It will still show the message.
1100 12/14/2015
3800 2/1/2016
5000 3/5/2016
Old 03-15-2016, 03:04 PM   #42
Camaro36
Drives: Camaro 2SS
Thanks guys.
