#29 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
I think taking the LT1, adding CNC ported heads with higher compression, a better intake and exhaust, a hotter cam and revving it over 7k rpm could hit 520+ hp with probably 480+ tq. If they need to share it with a car, they could bring back the Corvette Grand Sport. They could share brakes as well.
#30 | |
Unless GM goes DOHC for the Z/28 engine, small displacement won't work. With the OHV set up, the single intake valve needs to be big to make power. To run a big intake valve, you need a big cylinder bore. I guess you can run a short stroke to bring up the rev limit but the valve train won't keep up. So to keep the valve train happy and to make the power they need, you add cubic inches. The Voodoo makes peak power at 7,500 rpm, 400 rpm over the redline of the LS7. The LS7 makes peak power at 6,300 rpm. The rpm limit to LS and LT engines will always be the valve train.
#31 | |
#32 | |
![]() Drives: '14 V6 RS, DM Exhaust, Sunroof Join Date: May 2015
http://gmauthority.com/blog/2015/11/...ined-corvette/ Nothing definitive, but definitely a lot more fuel for the fire!
#33 |
![]() ![]() ![]() Drives: Want a gen 6 Join Date: Jan 2013
LT1 ILE, LT4 Z/28, no zl1 (or LT4 zl1 no Z28). No bigger, badder N/A motor in the cards.
There's no market share, they'll let the gt350 have it. Z/28 sold like shit. |
#34 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Current Camaro-less Join Date: Jul 2014
A Z/28 without the DSSV dampers and CCB'S would likely have been about $15000 less A little lower performance? Yes...but a much easier price to pay. Maybe it could have been optioned with CCB'S and the dampers...Ala GT350/GT350R |
#35 | |
#36 | |
