#29 |
GM repeat offender...
Drives: 16 2SS Join Date: Dec 2014
Ugh... Well, that helps determine my build direction! FI, it is! Thanksguys.
'16 2SS, Summit White. A8. MRC. NPP.
Ordered:09/03/15. Received 12/22/15 INCOMING: ‘22 ZL1, Satin Steel. A10. PDR. Ordered: 03/02/22. |
#30 |
![]() Drives: BLUE CAMARO ZL1 1LE M6 Join Date: Jun 2009
DYNO SHEET ADDED
Bone stock vs ARH 1 7/8 LT headers w Cats
NO Tuning Stock Air box.
www.jannettyracing.com
Celebrating 39 years Performance parts, Installation, Fabrication, Dyno tuning, Remote custom tuning, and alignments. 203-753-7223 Waterbury CT. 06705 email tedj@jannettyracing.com |
#31 | |
#32 |
SABIO
Nothing like 400ft lbs hitting you at 2400rpm.
Thats 1000rpm sooner than stock. Nice. |
#33 |
![]() ![]() ![]() ![]() Drives: 2022 F150, 87 Monte Carlo Join Date: Mar 2015
#34 |
#35 | |
Awesome! its crazy to see how fast these parts are being developed for these cars. I haven't even seen one yet. Keep it up!
#36 |
145lb Powerlifter
Drives: 2013 Camaro 2SS RS LS3 Join Date: Jan 2014
Hmmm. Interesting. Only 16rwhp/16rwtq from swapping out the stock manifolds and four-catalytic converter system to full longtubes and high flow cats speak VERY WELL to the design of the Camaro's tri-y style stock manifolds. People have been wondering why the Camaro 6 is dynoing so much higher than the Stingray. Maybe the stock manifolds on the Camaro are really good.
Considering simply adding Solo HFC's on the 5th Gen was good for 15rwhp with no tune, I find it really impressive that converting over to an entire new longtube system is only worth 16rwhp on a 6th Gen. That's awesome.
#37 | |
Currently the stock air box is a pretty good Choke on air flow. The headers are doing a great job of getting it out but there is still a restriction on getting air in. Ted.
#38 |
![]() ![]() ![]() ![]() Drives: 2015 Tiger XCX,2016 Camaro 1SS,LBZ! Join Date: Sep 2015
Thank you for your research! Will be interesting to see this with a CAI and a tune what it puts down. It would be very impressive seeing another 50 ft lbs to the rear wheels. Optimistic I know but 500 lb ft of torque from a mostly stock DD camaro is bad ass!
#39 | |
I expect another 10-15 with the Air box freeing up some restriction. Ted.
#40 |
SABIO
#41 |
Not just an air filter but the tune to tie in the exhaust and restrictive air intake. This is putting down close to 450 wheel ft lbs torque with just a header. Look at the graph. I do not think I am so far off the numbers. Throw in a new cam and I think it is possible. Either way you look at it just doing those mods will be impressive numbers out of a NA engine.
#42 |
![]() ![]() ![]() ![]() Drives: 99z28 with bolt-ons and a mwc fab 9 Join Date: Jul 2012
And so many guys said there would be nothing left to gain with long tubes because of the better manifold on the camaro. I guess this ends that debate. I'd like to see what it could do with an off-road pipe instead of cats. Maybe it could hit 20hp/20lbft. We're you able to get a weight difference between stock and aftermarket?
I like my woman like my milk shakes, THICK!!!!
