Old 12-08-2015, 10:27 AM   #29
JANNETTYRACING
JANNETTYRACING's Avatar
Looking over the data and the Air flow in LB. per minute is reaching 46.65.
We know engines make 10 HP per lb of air, so 466.5 Crank HP is realistic.
Somewhere around 12-13% drive train loss depending if your multiplying up or down.
Ted.
www.jannettyracing.com
email tedj@jannettyracing.com
Old 12-08-2015, 10:52 AM   #30
Originally Posted by SUMMIT WHITE SS View Post
Are these numbers SAE corrected?
My question as well
Old 12-08-2015, 10:57 AM   #31
Memphis43
Memphis43's Avatar
Drives: Chevy
My question as well
Said it was
Memphis43 is offline   Reply With Quote
Old 12-08-2015, 11:02 AM   #32
Originally Posted by Memphis43 View Post
Said it was
Old 12-08-2015, 12:02 PM   #33
JANNETTYRACING
Numbers are Standard Temp and Pressure.
corrects to 60 degree, dry air, 29.92 Barometric pressure.
I have the ability to print out SAE, STP, Actual (uncorrected) or dynojet numbers but stick to STP because it is repeatable at the track.
Everything is calculated from the measured number then the correction factor is applied to bring it back to what it would make on a standard day.
My correction factor for yesterday was 0.990 or 1% less than actual.
Where SAE would be 0.951 or about 4.9% less than actual
Actual numbers were 418 RWHP 435 RWTQ.
Ted.
Old 12-08-2015, 12:31 PM   #34
IOMike
Drives: 2022 F150, 87 Monte Carlo
Wouldn't that be std, not stp. Unless you have the Stone Temple Pilots hanging out at the shop.
STD explains the slightly higher numbers. Would have been 408-410 sae.
IOMike is offline   Reply With Quote
Old 12-08-2015, 12:38 PM   #35
JANNETTYRACING
No sir it is in fact, STP Standard Temperature and Pressure.
Ted.
Old 12-08-2015, 12:58 PM   #36
LOBBS
LOBBS's Avatar
Drives: 2010 Camaro 2SS/RS
Our R&D auto car put down 397 to the rear wheels on our stingy Mustang dyno. That'd be pretty much in line with 414 on a Dynojet or different correction methods.
LOBBS is offline   Reply With Quote
Old 12-08-2015, 01:26 PM   #37
huggercamaro21
Sales Manager for Chevy
huggercamaro21's Avatar
Drives: Tahoe RST
These cars are simply amazing guys.
huggercamaro21 is offline   Reply With Quote
Old 12-08-2015, 04:57 PM   #38
JANNETTYRACING
Got the Auto trans tuning software today
Old 12-08-2015, 04:59 PM   #39
huggercamaro21
Drives: Tahoe RST
Oh boy. Tune, stall, and trans tune with DRs maybe 11.5.....
Old 12-08-2015, 05:17 PM   #40
Memphis43
Memphis43's Avatar
Drives: Chevy
Probably faster than that.
Old 12-08-2015, 05:25 PM   #41
GMGP5X
GMGP5X's Avatar
Drives: 2011 2LT RS VR 2008 Silverado 2500
Awesome!
2LT RS VR / ARK DTS Cat back exhaust / Roto-Fab CAI / RPI stealth mud guards /Defender works billet chrome door sills/ DIY painted engine cover, trunk corners, and brake rotors / RX catch can / Team LLT badges. Team LLT
GMGP5X is offline   Reply With Quote
Old 12-08-2015, 05:46 PM   #42
huggercamaro21
Drives: Tahoe RST
That's nuts. Full bolt ones with stall, trans tune, and DRs are gonna be in the 10s.....Jebus
