#29 |
![]() Drives: Duramax Join Date: Jun 2015
The Coyote is an excellent engine, and so are the LS and new LT engines. Different ways to achieve the same result.
#30 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 20 1LE 2SS M6 Rally Green Join Date: Mar 2014
I had been thinking about the efficiency argument a while back and put this together to compare the LT1 SS and Coyote GT. Larger displacement spinning slower verses smaller displacement spinning fast. How much power/torque based on the volume of A/F being moved in their rated peak power RPM's.
1) LT1 makes 4.6% more power and 13.8 % more torque moving only 14.9% more A/F even though displacement is 24.5% greater. 2) GT is geared much higher. Wear and fuel economy loss 3) True measure of efficiency will be when we see the Federal MPG ratings. Large displacement allows low RPM around town and dropping to 3.1L with Active Fuel Management. I made this a weeks but don't believe anything has changed
"the trouble with our liberal friends is not that they're ignorant; it's just that they know so much that isn't so.” Ronald Reagan - Last edited by hotlap; 09-06-2015 at 01:09 PM. |
#31 | |
Moderator.ca
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
#32 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 16 Camaro SS, 15 Colorado Join Date: May 2009
I don't even know why there are complaints here. The LT1 rocks in the power department. Yes...TQ drops off a bit at a certain range, but the power curve is still much better than the LS3, and also much better than the 5.0 for my preference, not that I think the 5.0 is a bad engine at all. But its two much different ways to achieve an outcome. the HP per liter argument is completely irrelevant when it comes to comparing these two types of engines. Its apples and oranges. Stupid argument for sure. Also, its not like GM can't build a great DOHC engine...look at the V6 engines. Spectacular DOHC engines with as much or more tech in them than the 5.0. The LGX makes over 93hp/l. That's more power dense than the Coyote engine. We've all seen how great the LT1 performs in the Corvette, and if one does decide to modify it, it will push 500HP easily with some bolt ons and a tune. No complaints here.
2010 Camaro 1LT V6 (Sold. I will miss her!) |
#33 | |
![]() Drives: El camino Join Date: Nov 2014
As every gearhead knows, both engines are great. And different. And thats what so good about them. It's a matter of preference. I like simplicity. And low end grunt. Thats why i prefer GM's OHV to ford DOHC. If only blinded fanboys could understand this. |
#34 | |
![]() ![]() ![]() ![]() Drives: 99z28 with bolt-ons and a mwc fab 9 Join Date: Jul 2012
Yes sir!!!!
That's the math used by anyone with a small engine. They claim to not care about size yet alwasy try to brag about its ability for such a small engine. When truly they cant because Honda has owned that game for decades.
I like my woman like my milk shakes, THICK!!!!
#35 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 14 Silverado LTZ Z71, 16 Camaro SS Join Date: Nov 2009
I took my ls3 to redline damn near every time I drove it for 4 years. No problems. The last two years it had a g6x3 cam and a 7200 rpm rev limiter. Bounced it off that probably 2 or 3 times on accident. Took it to 7k constantly. Granted that's with aftermarket valve springs. Beat the piss out of an ls1 to redline constantly also. And it had a 6800 rpm redline when I put a cam in it. No issues. Does the lt1 have high rpm problems nowadays? If so that's a huge let down...I would think it should be even more stable...its an improved overall design (aside from simplicity) over the LS series. Im guessing the stock cam is to blame for the slight high rpm deficiency/sharper drop off. Some have said it is on the small side. But Im not sure haven't checked for myself... |
#36 | |
Moderator.ca
#37 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2015 SS 1LE Red Hot, 1970 Chevelle Join Date: Apr 2012
The LT1
200/207 .551/.524 116.5 LS3 204/211 .551/.525 117
#38 | |
Ive just had such good luck with these newer GM powerplants I guess im not scared to push them. My ls1 had 80k when I did the cam swap. And I was really not nice to that car. I was only 20 when I first bought it. Now don't get me wrong...I do all proper maintenance etc. Put in the right parts when I mod. (correct pushrod length you name it) Don't cut corners. But anyway...it is a greenline for me
#39 | |
GM repeat offender...
Drives: 16 2SS Join Date: Dec 2014
Yup. PRC Gold dual valvesprings, Comp pushrods, and a TSP MS3 cam. Shiftin@7200.
'16 2SS, Summit White. A8. MRC. NPP.
Ordered:09/03/15. Received 12/22/15 INCOMING: ‘22 ZL1, Satin Steel. A10. PDR. Ordered: 03/02/22. |
#40 | |
Lift and LSA almost identical.
Decent difference in duration though. No wonder cam only lt1s are getting over 500 rwhp so easily. Impressive that the lt1 makes as much power as it does with the same displacement with a smaller cam than the ls3. Quote:
My ls1 had a 228/230 .588/.592 112 custom grind. Used the comp 918 singles. Worked great. That cam with ported ls6 heads was falling quick past 65-6600 tuner set the limiter at 6800. But man it had torque everywhere. My rwtq was actually 428 IIRC... Higher than the hp lol. |
#41 | |
I bet that thing was a beast on the bottom! Are you saying that the LT1 is typically hitting 500+rwho w/cam? THIS is why I tried to get a performance section. Lol
#42 | |
I'm lucky I didn't get hurt. Put the car into a tree by the end of the same summer that I did the H/C swap. No option stripper with some minor weight reduction. Just under 3300 lbs with 1/3 tank of gas. I really think it was faster than my 2010. Yeah from the little searching I've done 500 rwhp is pretty easy to come by. Typed in cam only stingray on google this was the first hit. http://www.corvetteforum.com/forums/...ck-airbox.html 511 rwhp stock air intake and no crank pulley. Stock heads. I know dynos vary but that's more than my h/c ls3 with intake and pulley ( less torque though I had 464) |
