Old 08-27-2015, 01:12 PM   #29
ULTRAZLS1
ULTRAZLS1's Avatar
Originally Posted by KMPrenger View Post
Why do you hate this car?
If the stock 5th gen is capable of doing 12.6 - 12.7 stock at its max potential and optimal conditions, I just don't see any logical reason why less weight, more power and superior torque curve, and an 8-speed can't shave AT LEAST 2 or three tenths off that.
I don't know what the GM advertised 1/4 mile times are on the 5th gen SS, but I'm guessing they are 12.9 - 13 flat? So for this car I can see their advertised times as mid 12s at least, and in the hands of owners we will see low 12s....100%.
The ONLY negative I can see, are the run flats on the SS, which likely have a stiffer sidewall which will equate to more difficult launches.
GM advertises 12.9@113mph for the ls3 ss.
I believe 12.7 for the 1le. It is on the website.
They will advertise mid 12s at least. 115+ mph. Let the haters hate who cares. Most of the time it's just jealousy. If they truly didn't care why even comment? Go enjoy your own car instead lol
Old 08-27-2015, 02:49 PM   #30
ilirg
ilirg's Avatar
Drives: 2011 Camaro 2ss
Looks more like stupidity then hate
ilirg is offline   Reply With Quote
Old 08-27-2015, 03:09 PM   #31
ULTRAZLS1
ULTRAZLS1's Avatar
mix and match...either could apply here.
it is obvious this car will run mid 12's with the a8 worst case scenario with any decent traction and DA.
Anyone who disagrees just doesnt know cars/and or being a hater.
Old 08-30-2015, 05:57 PM   #32
Blackdevil77
Blackdevil77's Avatar
Drives: 2008 Pontiac G8 GT, Shelby GT500
Originally Posted by ztwentypoop View Post
Agree, only I suspect lateral G's to be less spectacular than what you're guessing.
Maybe I missed something, but why is everyone thinking the lateral G's are gonna be that much less than 1g?
Reason I was guessing around 1g, give or take, was because of what my current car is capable of with lateral G's. With crappy Goodyear tires, about the same size in the rear and slightly bigger in the front (285 in the rear and 265 in the front), the car was able to get .98g's from Motor Trends tests. And that's with a solid rear axle and more weight than what the SS is supposed to weigh.
I figured the 2016 Camaro SS, with the weight reduction, independent rear suspension, more rigid chassis and magnetic ride control, should be able to obtain around a G of lateral grip if my current car was able to.
I'm not looking to argue, I'm just wondering if I missed something. Is my logic messed up?
Blackdevil77 is offline   Reply With Quote
Old 08-30-2015, 06:04 PM   #33
FINALLYSATISFIED
Est.1775
FINALLYSATISFIED's Avatar
Drives: '15 Challenger Hellcat (sold)
All I know is I'm anxious to see them on the road. Times better beat 10.5-10.8 proven with the Hellcat.
FINALLYSATISFIED is offline   Reply With Quote
Old 08-30-2015, 06:28 PM   #34
jaymsu
Yeti's Daddy
jaymsu's Avatar
Drives: ATS-V, Prowler, M6 V10
Originally Posted by SUMMIT WHITE SS View Post
You are like that annoying girl in grade school that complains about anything and everything.
jaymsu is offline   Reply With Quote
Old 08-30-2015, 06:58 PM   #35
cyberbro
cyberbro's Avatar
Drives: Not a Camaro at this time
A little off topic but in keeping with the tire talk above, the 20" tires that come on the V6 with RS package are they also run flats and are they also summer only?
Order Status:
2000 8/27/15
3000 9/3/15
2000 9/22/15 (Order changed)
2016 2SS With Auto, NPP, MRC, Nav, Split 5 Spoke Bright Aluminum.
cyberbro is offline   Reply With Quote
Old 08-30-2015, 07:19 PM   #36
laborsmith
Drives: 1969 Corvair, 2018 Camaro T4 RS
They are all season run flats.
Laborsmith
laborsmith is offline   Reply With Quote
Old 08-31-2015, 11:18 AM   #37
Blackdevil77
bump on this one. I don't know, I feel like 1g of grip is possible with the listed improvements they said they have made and judging from other platforms that aren't even as advanced as this one.
Old 08-31-2015, 11:14 PM   #38
1sspat
Tampa Gulf Coast Family
1sspat's Avatar
Drives: 2016 2SS, 6SP, NPP, MRC, NAV
SS M6
1/4 mile-12.6 seconds @ 113 mph
0-60 in 4.7 seconds
SS A8
1/4 mile - 12.4 seconds @ 112 mph
0-60 in 4.6 seconds
1sspat is offline   Reply With Quote
Old 09-01-2015, 09:37 AM   #39
LesserO2Evils
GM repeat offender...
Drives: 16 2SS
Auto SS:
12.3 QT and 4.1 0-60
Advertised.
I should add, that is assuming the 200lb weightloss and the car@3700ish.
'16 2SS, Summit White. A8. MRC. NPP.
Ordered:09/03/15. Received 12/22/15
INCOMING: ‘22 ZL1, Satin Steel. A10. PDR.
Ordered: 03/02/22.
LesserO2Evils is offline   Reply With Quote
Old 09-01-2015, 01:08 PM   #40
doc7000
Drives: 2004 Pontiac Grand Prix
My predictions based on 8 speed auto
2.0T 0-60: 5.5
3.6L 0-60: 4.9
6.2L 0-60: 3.9
doc7000 is offline   Reply With Quote
Old 09-01-2015, 01:24 PM   #41
titanfan
Drives: Several in a big garage
A G8 GT does NOT pull .98 in lateral G's, more like .88. Maybe you mistyped.
The reason I do not see the 1SS or 2SS pulling more than .94-.95, at best, is easy. The cars are engineered for ride comfort geared toward the non-enthusiast buyer. Now, if you get the MRC option, I could see better numbers, but in base form, I think not.
titanfan is offline   Reply With Quote
Old 09-01-2015, 01:42 PM   #42
jaymsu
Yeti's Daddy
jaymsu's Avatar
Even without the MRC and runflat tires, I think it can probably pull about 0.97.
I'll try to pull over 1G with some sticky non-runflat tires on 2SS w/ MRC, and let you know.
With my C6 Vette on summer tires, I got around 1.2G on track, per G-meter on my HUD. With Hoosier A6, I got over 1.3.
