#29 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 2011 1LT Join Date: Mar 2012
Okay, one more observation (I'm a little slow)... one of the objects has the mill grooves... the OTHER one seems to be chromed, making the mill grooves almost impossible to see (but, yes, they are evident, under the coating of chrome). This gives me the impression that the chromed one (which appears to be older, more worn) may have been the original, and that somebody tried to mill/ make a replacement.
But, then, thinking it out even further, I don't know why both would have manufacturing stamps "F.M.K. Denmark") on them... |
#30 |
7 year Cancer Survivor!
Drives: 17 Cruze RS, 07 G6 GT, 99 Astro Join Date: Dec 2007
They are just Henway calibration inserts. You need one to keep your Henway in alignment.
The Bird is the word! |
#31 |
#32 |
One more observation regarding how the two are different from each other: I can drop a U.S. nickel through both of the crossdrilled holes on the non- chromed one... but that same nickel will not fit into either of the crossdrilled holes on the other.
#33 |
What's the matter? Did ya just Chicken out?
#34 |
#35 |
Well I was just egging you on a little...
#36 |
As long as no one uses any "fowl" language...
Nice car bro!
#37 |
May have to give you the Bird on that one...
#38 |
Drives: 2010 Camaro Join Date: May 2014
Now they look like solid bushings for a shifter.
#39 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: Black '13 2SS/RS/1LE w/NPP/NAV Join Date: Oct 2012
What was this thread about?
Sent from my QTAQZ3 using Tapatalk
My Build Thread... http://www.camaro5.com/forums/showthread.php?t=285054
#40 |
...not a marine biologist
Drives: 2012 Camaro RY SS LS3 Join Date: Mar 2013
they look maritime
Forged 416 stroker Turbocharged with Huron Speed with Cam Motion custom grind,Tuned by Vengeance, 8psi, 25% PowerBond UDP, Ported TB, shaved heads, LS9 gaskets, chromoly pushrods, BT trunnions & dual valve springs, IWIS, Might Mouse CC, SJM Line Lock,, MSD 2-Step, ZL1 Rear End, ZL1 spoiler, Strut Brace, ARP bolts, Skip shift elim, A-Pillar Gauges, FR Style 41 20X10, 3 inch exhaust, blackouts, Lowered, Custom badges, Hines vents,RPI fender vents, Technostalgia Tail Lights, Metra Kit, Pioneer stereo, Morimoto RGB Halos,
"The Great Awakening" on gab.com |
#41 |
Google searching "FMK" has brought me to a possibility of the "Fredericia Motor Klub," in Denmark (since these ate tool- stamped, "F.M.K. Denmark").
I don't read Danish, I only like them with my coffee. However, It appears that this is some sort of motorcycle- related club, perhaps youth- oriented (judging from pictures of the club I see online). Anybody know motorcycle parts well enough to tell if these are bike parts? |
#42 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: "Kara Zor-El" 2017 2SS HBM Join Date: Jul 2014
Oh, and the cheese are the best!!
Lead me not into temptation. I already know the way.
Lana? Lana? LANA! LAAANAAAA!!!! What? Dangerzoooooone. |
