Old 05-20-2015, 09:32 PM   #29
jbarnett1221
jbarnett1221's Avatar
Drives: 2014 Camaro 2LT/RS
You have to remember there is a 4 cyl coming. That would be lighter than the others. Could be where the 200 plus pounds come from. I work for a Chevy dealer and have access to some of the specs. I'll find out what I can tomorrow and let you guys know
2014 2LT R.S.
jbarnett1221 is offline   Reply With Quote
Old 05-21-2015, 01:12 PM   #30
DevilsReject97
Nightmare
DevilsReject97's Avatar
Drives: Your mom crazy in bed
I can promise you, that the 200lbs weight drop has zero to do with the 4 banger. In fact, I'd wager the weight difference between the 4 cylinder and the V6 won't be all that much different. Maybe 50lbs..
The CTS-V coupe was a Camaro chassis, motor, transmission, blah blah blah blah interior blah blah etc... They were and are the same car except for some designer looks and body panels. It was the same with the Firebird for years too....outside looks mostly werent the same...but underneath...they were...
The ATS coupe is the exact car to expect when the new Camaro debuts for the weights. I'll wager most of the specs will be very similar in fact... with the exception of the V8 model, as I expect that will be about 250lbs heavier than the 3450lbs of the ATS....which still puts us around 3700lbs.
The outgoing 2015 SS Camaro weighs 3900lbs....you're telling me there's no way GM can trim 200lbs from that car? Are you kidding me?
Old 05-22-2015, 06:03 AM   #31
2010SSRSM6
2010SSRSM6's Avatar
Drives: My wife crazy with my C5 usage.
Better rims (smaller/lighter) would cut 50 pounds on their own. 5th generation RS wheels and tires are 60#'s each. Get a good set of 18's on it and that drops to 40-45#'s each. Little cuts here and there will get the 200# reduction.
That said, there is no way in hell the stock 6th Gen runs faster than 12.5 in the 1/4.
UNDER CONSTRUCTION......again......
2010SSRSM6 is offline   Reply With Quote
Old 05-22-2015, 11:05 AM   #32
DevilsReject97
Nightmare
I had hoped GM would listen to common sense like that...but the 6th Gen RS and V8 will keep the 20" wheel....which is just ridiculous..
Old 05-22-2015, 04:25 PM   #33
strykerg8gt
Drives: 2009 Pontiac G8 GT
6sp/7sp manual 12.8
8sp auto 12.6 maybe high 12.5 IF enough weight is lost.
strykerg8gt is offline   Reply With Quote
Old 06-24-2015, 03:32 PM   #34
evolve
evolve's Avatar
Drives: 03 Cobra
Originally Posted by z28guy30 View Post
No matter what it is...the 2016 Camaro SS could easily put 5-6 car lengths in the 1/4 mile on the new GT.
Exaggeration is present here...
Originally Posted by matt55 View Post
Thr manual should trap about 3-4 mph and .3-.4 quicker more vs a ls3 .
The auto should have about same trap speed as manual but quicker by .2-.3 second.
So lets used a baseline of 12.9@110 mph magazine time for the 5th gen .
Manual would run a 12.6@114 and the auto 12.4@113 is my guess.
I would say this is pretty spot on. Based on power/weight and suspension/tires there shouldn't be too much deviation IMO.
Less rotating mass is HUGE in this case. Talk about a difference maker!
2003 Cobra (Stock Motor/Boost Only)
640rwhp/ 550rwtq on 93...
Well over 700rwhp on CORN
evolve is offline   Reply With Quote
Old 06-24-2015, 04:51 PM   #35
rebelyell22
rebelyell22's Avatar
Drives: 2011 SIM 2SS/RS LS3
Originally Posted by DevilsReject97 View Post
Ummm...even with 200lbs weight drop and a 30hp increase, you arent going from 13.0 in the quarter to 12.2....its just not happening...
The Vette has a lower drag coefficient, better aero, it's lighter, and most importantly, it's got tires the size of Texas on the back for grip...
The 5th gen record is 12.58... No reason this car wont hit 12.1-12.2 with someone that can drive. Lighter, better aero, more power, and better suspension.
2011 2SS/RS built 8/24/10
rebelyell22 is offline   Reply With Quote
Old 06-24-2015, 05:02 PM   #36
PoorMansCamaro
PoorMansCamaro's Avatar
Drives: Really Slow
general rule of thumb, 100lbs is about .1 second increase in a 1/4 mile run. so if the car is at least 200lbs lighter, you can guess the car will be at least .2 seconds faster in the 1/4 mile. add the fact that the car has more hp/tq, and you can probably guess it's going to be more than .2 seconds faster. if I were to guess, i'd say the new Camaro will be around .25-.35 seconds faster in the 1/4 mile.
Old 06-26-2015, 04:20 PM   #37
LimaCharlie
LimaCharlie's Avatar
Drives: 2011 Camaro SS/RS - 2004 Silverado
Consistent 12.7 with drivers who have a general idea of how to launch/shift correctly.
12.3 with driver mod.
2011 Summit White Camaro 1SS/RS
-6.2 LS3, TR6060, 3.45, G80
2004 Black Silverado 1500 2WD Regular Cab, Short Bed
-5.3 LM7, 4L60E, 3.42, G80
2014 White Caprice PPV
-6.0 L77, 6L80E, 2.92, G80
LimaCharlie is offline   Reply With Quote
Old 06-26-2015, 06:47 PM   #38
Obsessed 17
Drives: 2016 Chevy Colorado Z71
12.3-12.4
Obsessed 17 is offline   Reply With Quote
Old 06-26-2015, 11:47 PM   #39
Jeffro19
Jeffro19's Avatar
I'm calling 12.5 at 114.
Old 06-27-2015, 12:16 AM   #40
crysalis_01
Iron fist, lead foot
crysalis_01's Avatar
Drives: 2003 Mustang Cobra
How is it that this thread popped up before a "Predict the 455 hp 2016 Camaro SS Laguna Seca and VIR lap times" thread?
crysalis_01 is offline   Reply With Quote
Old 06-27-2015, 12:30 AM   #41
IOMike
Drives: 2022 F150, 87 Monte Carlo
Originally Posted by ztwentypoop View Post
No doubt, at least one model of the Alpha Camaro models WILL be 200lbs lighter than one of the 5thGen Camaro models. They have already said that. But that doesn't mean EVERY model lost 200lbs between the 5thGen and the 6thGen. Why is that so hard to comprehend or accept?
They have said model for model the 6th gen is more than 200lbs lighter. Almost 300lbs lighter comparing the turbo 4 vs the old 6 cylinder.
The question is really, why is THAT so hard to comprehend???
IOMike is offline   Reply With Quote
Old 06-27-2015, 12:36 AM   #42
IOMike
Mags will see 12.3-12.4 at 115-116 for autos. 12.1 to 12.2 @ 116-117 will be a common great time with hero runs in the 11s.
The ls3 was never in a auto camaro, so we have a gain of 56hp, better torque curve, 200+ less lbs and a lightning fast 8 speed over the 5th gen autos that ran 12.9-13.0.
