Old 03-29-2014, 06:25 PM   #29
RollaMo
RollaMo's Avatar
Drives: 2017 2SS
Originally Posted by Chevy_cowboy View Post
What I don't understand is how that results in fatal crashes, IMO knowing how to safely control a car that dies at highway speed should be part of learning to drive, either reach down and restart it, or coast to the side of the road. People are too quick to panic. This should be taught in drivers ed, along with skid recovery and other emergency training.
Yep, that is true.
Apparently when the ignition switch is in the "off" position when a front impact happens, the airbags fail to deploy.
They are blaming the "fatal" part of the crashes on that, since no airbags deployed.
As you mention, if the car dies most people should be able to safely access the situation and safely get the car to the side of the road.
But there are plenty of people out there, that can barely drive to begin with.
If it is proven that any type of mechanical defect was in play during a fatal crash, guess who is taking the brunt of the blame.
1996 Corvette - LT4
2017 Camaro 2SS
2019 GMC Sierra 2500 HD
2015 Harley Davidson Ultra Limited
RollaMo is offline   Reply With Quote
Old 03-29-2014, 06:39 PM   #30
jd10013
Drives: 2012 camaro
Originally Posted by Muscle Car Lover View Post
Just my 2 cents but as the bailout of GM is seen as a centerpiece of political economic "success" I doubt anything bad will happen to GM. The switches in question are from 2005-2009 I believe and not for the Camaro model line.
this won't be wrapped up for another 3 or 4 years. new administration. something is definitely going to happen. most likely a fine. who knows how much, but it will probably be a good chunk bigger than what Toyota got. especially since there is a very real possibility of criminal charges coming out of this.
but since there is so much wrong information in this thread about the issue, he's a link that summarizes it nicely
http://money.cnn.com/2014/03/14/autos/gm-recall-faq/
and one more
http://www.freep.com/article/2014032...uptcy-ignition
jd10013 is offline   Reply With Quote
Old 03-29-2014, 06:50 PM   #31
gpskinzhut
gpskinzhut's Avatar
Drives: 2020 Corvette Stingray Z51
Depends on the conditions present at the time of the accident really. Not always that simple.
2020 Corvette 2LT Z51
2017 ZL1 A10: (SOLD) ||
2017 2SS M6: (SOLD) || 2014 2LT Convertible: (SOLD) || 2010 2LT M6 Supercharged:(SOLD) || 1987 IROC-Z 5.0 M5: (SOLD)
gpskinzhut is offline   Reply With Quote
Old 03-29-2014, 06:55 PM   #32
Chevy_cowboy
Chevy_cowboy's Avatar
Drives: 2011 IOM 2SS/RS M6 Convertible
Yep, that is true.
Aint that the truth. I've had a couple really crappy cars over the years that randomly died when they felt like it. My reaction was usually "oh you piece of #%@!" not "gee my engine died, guess I'll run into that ditch over there"
This reminds me a bit of the toyota accelerator thing, yeah maybe there is an issue with the car that needs to be fixed, but its the drivers reaction (or lack there of) to it that makes the situation dangerous.
Chevy_cowboy is offline   Reply With Quote
Old 03-29-2014, 06:57 PM   #33
jd10013
Drives: 2012 camaro
not to mentions it's asinine to say it's not the manufactures fault for designing a faulty ignition, but the drivers fault for not being trained to drive in such a situation. if that's the case, then GM should be forced to put a disclaimer on all it's vehicles that if your not trained to operate a vehicle in adverse or unexpected mechanical failures then you shouldn't buy one of their cars or trucks.
Old 03-29-2014, 07:28 PM   #34
Chevy_cowboy
Nobody said the manufacturer doesn't share some blame, I just think drivers ed should have a chapter or two about emergency reaction and how to handle unexpected situations.
We can hope and assume tires will never blowout, or we can teach our kids how to stop safely and jack a car up and change it when it does. There's plenty of time to figure out who's to blame after the fact.
Old 03-29-2014, 09:34 PM   #35
mynetdude
Drives: 2014 Camaro 2LT RS V6 Silver
This can be an issue in any vehicle, ignition switches aren't designed to have a ton of swinging weight hanging on them. Hit a good bump and the added weight bouncing or swinging will turn the key off. At the very least, it's putting added wear on the ignition.
I never took official driver's ed; and many driver's ed don't teach all this (although I agree they should)
There is a skid driving school I can attend (and I want to go to it); supposedly they use temporary modifications by installing "skid wheels" to your vehicle and they have a remote that controls it so you learn how to do it (and some schools have vehicles already for this purpose).
I've been in enough rolling stalls to first kick it into Neutral so you don't have resistance on the transmission and you can coast farther/safer to a location that will allow you to do what you need to do but you also need to put it in N so you can restart it while rolling.
But I agree, I don't know how losing power results in fatal crashes all by themselves unless they are super weak to turn the wheel (but at decent speeds this isn't a problem mostly) if they are THAT weak then they have no business driving.
mynetdude is offline   Reply With Quote
Old 03-29-2014, 09:47 PM   #36
citabria7
Drives: 2010 LS Rally Yellow
Originally Posted by tomlink View Post
So 12 deaths have been linked to the switches and 2 million cars have been recalled. You have a better chance of being killed by lightning than this defective switch. And while GM is taking the blame, many of the victims were drunk or not wearing a seat belt, or both.
Problem also is their hiding the info. There are other problems with the Solstice that should be a recall. Passenger airbag sensors break, disabling the airbags. Known safety defect, and GM is doing the head in the sand bit. Other smaller problems, also causing injuries. Dealer says the fixes are so expensive, GM is digging their heels in. Wonder what else they are hiding.
citabria7 is offline   Reply With Quote
Old 03-29-2014, 10:45 PM   #37
Austin45
The Logistician
Austin45's Avatar
Drives: 2012 LFX 45th Anniversary
Toyota bounced back and they are fine. In the long term, GM will be fine.
Austin45 is offline   Reply With Quote
Old 03-29-2014, 11:00 PM   #38
mynetdude
Yeah if these fixes are "so expensive" why don't they check for these problems before they roll off the assembly line; after all that is what they have QA for (or they might as well fire them
Old 03-30-2014, 08:27 AM   #39
cmoz28
Drives: 2011 Black 2SS/RS LS3
cmoz28 is offline   Reply With Quote
Old 03-30-2014, 08:43 AM   #40
shrinkdoc
Drives: SRT Yugo GT Super Sport with Manual
All these recalls are from the pre government loan GM. GM would never do that today...to much risk.
shrinkdoc is offline   Reply With Quote
Old 03-30-2014, 10:12 AM   #41
citabria7
What QA? I love driving my Solstice, but there was no quality control in the plant. Totally hit or miss. Either very good or a total disaster. Only a few years old, and some parts, like hoods, are getting very difficult to get. Don't tell me GM gives a damn about customers.
Old 03-30-2014, 10:21 AM   #42
The_Blur
Moderator
The_Blur's Avatar
Drives: 2018 Harley-Davidson Street Bob
Send a message via AIM to The_Blur
RDP Motorsport//GEN5DIY//Cultrag Performance//JPSS//Rodgets Chevrolet//
Operation Demon//Buy at Invoice//RACECARWEAR
RESPECT ALL CARS. LOVE YOUR OWN.
warn 145:159 ban
The_Blur is offline   Reply With Quote
