dave@hennessey
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Camaro DIY & HOW-TO instructions & discussions
Old 10-24-2011, 11:27 PM   #29
Yellow_Glide
Yellow_Glide's Avatar
Drives: 2011 1LT "Chakita". 04 Yota
did mine a few weeks back - not too bad,
Hi, my name is Chakita. I have cams!!!!
Build thread: http://www.camaro5.com/forums/showthread.php?p=3847083
Yellow_Glide is offline   Reply With Quote
Old 10-25-2011, 01:37 AM   #30
IOM Black Diamond
HT5 COTW 1/21/13
IOM Black Diamond's Avatar
Drives: 2010 Camaro Inferno 2SS RS 6M
Looks good. Nice job
IOM Black Diamond is offline   Reply With Quote
Old 12-28-2013, 07:55 AM   #31
He11bent
He11bent's Avatar
Drives: 2019 2SS Convertible Camaro
This is a great write up and the results look great!
I did mine a bit different. I removed the caliper and the disk mostly because the disc was rusted and looked terrible. I still used the Duplicolor paint but used the spray paint. Additionally, I used 'Chevy Orange' and then applied a Brembo hi temp decal and then used hi temp 'Duplicolor Clear' paint with several coats. You can used the engine enamel ($6) or the caliper paint as they are both rated to 500*. The engine enamel has a larger variety of colors. This paint dries really fast which to me was a huge plus! I bought a one man bleeder kit ($13) so I could bleed the breaks myself without getting and break fluid on my fresh paint.
**NOTE: For those of you that don't know, break fluid will quickly destroy the paint you just applied so if you remove the calipers, use a bleeder kit or at least a piece of tubing to guide the fluid into a container to collect the brake fluid when bleeding. I recommend you buy the clear tubing from a pet shop used for fish tanks. It's the perfect size and you can see if there is air still coming out.**
\(^^^)/ <--A Smile From He11
Escort 360 MAXX w/DIYGen5 hardwire Harness
K&N AirCharger Cold Air Intake
Sound Tube Delete
He11bent is offline   Reply With Quote
Old 12-28-2013, 11:44 PM   #32
ranlights78
Drives: 2010 Camaro SS
Any pics of the paints you used? Where did you pick them up from?
**NOTE: For those of you that don't know, break fluid will quickly destroy the e did paint you just applied so if you remove the calipers, use a bleeder kit or at least a piece of tubing to guide the fluid into a container to collect the brake fluid when bleeding. I recommend you buy the clear tubing from a pet shop used for fish tanks. It's the perfect size and you can see if there is air still coming out.**
ranlights78 is offline   Reply With Quote
Old 01-03-2014, 01:59 AM   #33
He11bent
He11bent's Avatar
They sell it at advance auto parts and autozone.
Sound Tube Delete
Old 02-06-2014, 08:01 AM   #34
shennessy
shennessy's Avatar
Drives: 2012 Camaro SS 45th Edition
awesome job, doing this soon! What size decals are those? Having trouble finding the right size.
shennessy is offline   Reply With Quote
Old 02-06-2014, 04:04 PM   #35
Awdition
Camaro out>CTS-V coupe in
Awdition's Avatar
Drives: CTS-V
http://www.ebay.com/itm/200848743598...B:3160&vxp=mtr
CTS-V Coupe Black Diamond Edition
Awdition is offline   Reply With Quote
Old 02-06-2014, 04:45 PM   #36
shennessy
shennessy's Avatar
I was hoping to find the size of the ones used here, that just say Brembo.
Old 02-06-2014, 07:53 PM   #37
Awdition
Awdition's Avatar
Drives: CTS-V
Look at the sellers store
Chevrolet is 4"
If you go for the brembo only it is 3.75"
http://www.ebay.com/itm/BREMBO-Calip...item2ec347b31e
Old 02-07-2014, 07:41 AM   #38
shennessy
shennessy's Avatar
is that the size you used?
Old 02-09-2014, 08:47 PM   #39
Awdition
Awdition's Avatar
Drives: CTS-V
I have the Chevrolet/Brembo combination to look like stock. And they look perfect. The Brembo only (3.75") will be perfect too.
Old 08-01-2014, 10:04 PM   #40
Natti337
Natti337's Avatar
Drives: 2014 Chevy Camaro LT
There is nooo way I have the balls to do this myself and I don't really have a handyman that can help, how much do you think I would be charged by a shop to get my calipers painted? I really love the way it looks when they are painted red. Thank you in advance
Natti337 is offline   Reply With Quote
Old 08-16-2014, 01:20 PM   #41
Imdyinhere
Keeper of the Gold Acorn
Imdyinhere's Avatar
Drives: 2011 2SS/RS
I asked a friend who does this at his shop and he told me about $100 per axle. It involves taking off the calipers and then bleeding the brakes after they finish. $125 if you go powder coat. So, $400-$500 basically.
However, if you are comfortable removing the wheels from your Camaro then you can do this. Even if you only do one wheel at a time. The trick is to be patient, take your time. Make an afternoon out of it.
2011 RJT 2SS/RS - Kooks 1-7/8 Long Tubes, High Flow Cats, Corsa Cat Back Exhaust, MTI Short Throw Shifter, Vmax Ported Throttle Body, Fasster Billet Fuel Rails & Custom Braided Vapor and Fuel Lines, CAI Cold Air Intake, RX Catch Can, Nitto Invos, Hawk HPS, BMR Trailing Arms, 2x Zapco ST4x-SQ amps, ST850x-II Sub amp, Morel Tempo 6 componenets, Morel Maximo 6x9, Morel 124 Primo Sub, Zapco DSP8Z Processor... More to Come.
Imdyinhere is offline   Reply With Quote
Old 08-16-2014, 08:58 PM   #42
YoungMulaBaby
Drives: Camaro 2014 2LT
Took me about two days (2 calipers per day), to finish my calipers. But they turned out amazing! Thanks Snoopy
YoungMulaBaby is offline   Reply With Quote
I need a diy for painting the interior of a 2ss Jenifers bee Camaro DIY & HOW-TO instructions & discussions 13 10-16-2012 04:44 PM
DIY Painting heritage grille? rxfox3 Camaro DIY & HOW-TO instructions & discussions 5 12-25-2011 11:37 AM
Painting the calipers? bigwayne3000 Camaro DIY & HOW-TO instructions & discussions 46 05-30-2011 05:28 PM
Painting rims and break calipers LED Crazy Cosmetics and Lighting Modification Discussions 0 02-13-2011 10:45 PM
Painting calipers + track days, good or bad? robertway Suspension / Brakes / Chassis 10 09-03-2010 05:19 AM
