#29 |
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: the 2nd amendment home Join Date: May 2008
badgerbadgerbadgerbadgerbadgerbadgerbadgerbadger
-- Benjamin Franklin lib·er·ty /ˈlibərdē/ noun 1. the state of being free within society from oppressive restrictions imposed by authority on one's way of life, behavior, or political views |
#30 |
Most Known Unknown
From that site so it's either more lies or just someone there doesn't know anything.
TECHNICAL SPECIFICATIONS Vehicle Name Shelby GT500 Body Style 2 Door Coupe Drivetrain Rear Wheel Drive EPA Classification Subcompact Passenger Capacity 4 Passenger Volume (ft 84.7 Base Curb Weight (lbs) 3920 EPA Fuel Economy Est - City (MPG) 14 EPA Fuel Economy Est - Hwy (MPG) 20 Engine Order Code 99S Engine Type Supercharged Gas V8 Displacement 5.4L/330 Fuel System SEFI SAE Net Horsepower @ RPM 500 @ 6000 SAE Net Torque @ RPM 480 @ 4500 Trans Order Code 44E Trans Type 6 Trans Description Cont. Manual First Gear Ratio (:1) 2.97 Second Gear Ratio (:1) 1.78 Third Gear Ratio (:1) 1.30 Fourth Gear Ratio (:1) 1.00 Fifth Gear Ratio (:1) 0.80 Sixth Gear Ratio (:1) 0.63 Final Drive Axle Ratio (:1) 3.31 Total Cooling System Capacity (qts) 25.0 Suspension Type - Front Independent MacPherson Strut Suspension Type - Rear 3-Link/Panhard Rod Suspension Type - Front (Cont.) w/Coil Springs Suspension Type - Rear (Cont.) w/Coil Springs Stabilizer Bar Diameter - Front (in) 1.34 Stabilizer Bar Diameter - Rear (in) 0.94 Front Tire Order Code T9H Rear Tire Order Code T9H Front Tire Size P255/45ZR18 Rear Tire Size P285/40ZR18 Front Wheel Size (in) 18 x 9.5 Rear Wheel Size (in) 18 x 9.5 Front Wheel Material Aluminum Rear Wheel Material Aluminum Steering Type Pwr Rack & Pinion Steering Ratio (:1), Overall 15.7 Turning Diameter - Curb to Curb (ft) 37.0 Brake Type Pwr Brake ABS System 4-Wheel Disc - Front (Yes or ) Yes Disc - Rear (Yes or ) Yes Front Brake Rotor Diam x Thickness (in) 14.0 x - TBD - Rear Brake Rotor Diam x Thickness (in) 11.8 x - TBD - Fuel Tank Capacity, Approx (gal) 16.0 Front Head Room (in) 38.6 Front Leg Room (in) 42.7 Front Shoulder Room (in) 55.4 Front Hip Room (in) 53.6 Second Head Room (in) 34.7 Second Leg Room (in) 30.3 Second Shoulder Room (in) 53.4 Second Hip Room (in) 46.8 Wheelbase (in) 107.1 Length, Overall (in) 187.6 Width, Max w/o mirrors (in) 79.3 Height, Overall (in) 55.4 Tread Width, Front (in) 61.9 Tread Width, Rear (in) 63.0 Trunk Volume (ft 13.1 |
#31 |
Camaro➎ moderator
MUSHROOM MUSHROOM!!!
#32 |
Moderator.ca
Thats correct, the 2009's made 500 hp
__________________ Originally Posted by FbodFather My sister's dentist's brother's cousin's housekeeper's dog-breeder's nephew sells coffee filters to the company that provides coffee to General Motors...... ........and HE WOULD KNOW!!!!__________________ Camaro Fest sub-forum |
#33 | ||
Truth Enforcer
Drives: anything I can get my hands on Join Date: Sep 2006
it would need to make chocolate milkshakes as well as wash itself inside and out
A group as a whole tends to be smarter than the smartest person in that group until one jackass convinces everyone otherwise. Quote:
#34 |
just can't seem to leave
^^Reeves-Sain drugstore here in town makes the BEST milkshakes i've ever had in my life!
Eve ('00 FRC): hot-air intake
Rowan ('09 H3): 5spd mom-mobile Penny ('99 Sierra): 5.3 / HD 5spd... gone but not forgotten Samson ('18 HD): compounded 408 |
#35 |
![]() Drives: ex-500hp v6 mustang Join Date: Oct 2008
#36 | ||
Truth Enforcer
if I'm going to spend that kind of money on a car, im going to drive it till the wheels fall off, then put new wheels on and drive it till the motor blows
