02-18-2016, 09:30 PM | #29 | |
Drives: 2014 SS/RS 1LE Join Date: Sep 2014
Normal sounding exhaust |
02-18-2016, 10:18 PM | #30 |
I used to get a real loud harmonic vibration noise under passenger seat area only when cold out <40. Once engine warmed up noise went away ... went away permanently when I installed Solo HFCs
02-19-2016, 06:53 AM | #31 |
Drives: 1LE Join Date: Feb 2013
If I have my car backed up against a wall, and do a cold start up, I can hear the NPP rattling a little until the RPMs drop down to normal idle. When I started it in front of a buddy who owns a Corvette with the NPP exhaust, he commented that his sounds exactly the same.
Sent from my iPhone using Tapatalk |
02-19-2016, 09:35 AM | #32 |
Drives: 23 LT1 / 19 Z06 / after 6 5th gens Join Date: Jan 2014
The removal of the guide tabs I posted above completely fixed my issue.
"Make yourself sheep and the wolves will eat you"
02-19-2016, 10:51 AM | #33 | |
Drives: 2013 2SS (sold) Join Date: Jan 2016
Track Parts/Stock Parts Part Out http://www.camaro5.com/forums/showthread.php?t=515534
02-19-2016, 11:46 AM | #34 |
Drives: ‘13 1LE Join Date: Jul 2013
If any of you guys can post up a pic of the location of those metal tab guides, that would be great!
02-19-2016, 11:47 AM | #35 |
I may get mine on a lift this weekend to do my brake lines, so I'll look then and take pics if I find them
02-19-2016, 06:28 PM | #36 | |
Drives: GM Vehicles Join Date: Jun 2010
I am sorry to hear you're experiencing this rattle concern with your Camaro. Are you interested in visiting your dealership for a diagnostic appointment? If so, feel free to reach out to us. We would be happy to facilitate a service visit on your behalf. Please send us a private message along with your full contact information, VIN, current mileage, and preferred dealership if this is something of interest. Kindly, Julie C Chevrolet Customer Care
For information on the GM Privacy Statement, please visit http://www.gm.com/privacy-statement.html
02-19-2016, 06:30 PM | #37 | |
Apologies for the rattle noise concern you've encountered with your Camaro and I can certainly understand your frustrations. If you would like, we would be happy to provide an additional layer of support while your Camaro is in service. Please don't hesitate to send us a private message containing your VIN, full contact information, and preferred dealership if you would like our assistance. Sincerely, Julie C Chevrolet Customer Care
02-20-2016, 06:55 PM | #38 | |
Drives: 2014 Camaro 2SS/RS 1LE Join Date: Oct 2013
Exhaust Rattle Noise June 19, 2014 On some 2010-2014 Camaros, a rattle noise may be heard coming from the exhaust system. It may sound like the noise originates from the transmission area. If a noise condition is being addressed from underneath the vehicle, first strike the exhaust system with a rubber mallet or a deadblow hammer. If a noise is heard, inspect where the two front exhaust band clamps join the front catalytic converter assembly to the rest of the exhaust system. (Fig. 11) Fig 11 This joint is called a Torca coupling. In this coupling, a small alignment tab is welded onto the exhaust pipe. A band clamp is positioned around the joint and slid toward the rear of the vehicle until a notch in the band clamp is positioned around the alignment tab. This ensures that the clamp is properly positioned on the exhaust before it is tightened. With this clamp in position, a J-shaped clip slides up and over the alignment tab to lock the clamp into position on the pipe. (Fig. 12) Fig 12 In some cases, a rattle noise may be heard coming from this coupling. The noise may be due to the J-shaped clip rattling against the exhaust pipe or from the alignment tab that was originally welded on the exhaust pipe becoming separated from the exhaust pipe. If a noise has been confirmed from the coupling, inspect the exhaust system for any obvious damage or looseness in the related components. If nothing is found, bend the J-shaped clip away from the exhaust pipe. If the small alignment tab is found to be loose, completely remove it from the exhaust pipe. This can be accomplished with the use of a regular screwdriver. Make sure the J-shaped clip will no longer contact anything that may cause a rattle noise in the future. (Fig. 13) Fig 13 - Thanks to Matt Bierlein If this is what your talking about... Peace, Brent
'14 Camaro 2SS/RS 1LE
'96 Impala SS '69 Camaro Convertible |
02-20-2016, 06:58 PM | #39 |
GMUSA#1!
03-12-2016, 10:12 AM | #40 |
Drives: 2010 Camaro Join Date: Feb 2016
I have this same issue. I'll see if the clips get it sorted
