Vararam
Go Back   Camaro5 Chevy Camaro Forum / Camaro ZL1, SS and V6 Forums - Camaro5.com > Technical Camaro Topics > Dragstrip and Launch Techniques Discussion
Old 08-01-2020, 12:35 AM   #29
2NASSTY
2NASSTY's Avatar
Drives: 2014 M6 ZL1
On that night I was running a 325/35/18 MT Street R DRs. I switch over to a 335/35/17 Hoosier DR2 on a different rim sometimes. Thank you!
15' Ashen Gray Metallic Z/28
14' Crystal Red Tintcoat ZL1 6M, 9.62 at 150.75 MPH
12' Opulent Blue Metallic CTS-V Sedan, 10.690 at 129.60 MPH - SOLD
06' LeMans Blue Metallic Z06, 11.726 at 127.80 MPH Motor - SOLD.
96' Impala SS LTx, 11.397 at 118.10 MPH Motor, 1st stage 10.526 at 127.46 MPH
2NASSTY is offline   Reply With Quote
Old 08-03-2020, 03:18 PM   #30
Genfive427camaro
Drives: 2015 Z28
How does the M/T ET street Rs hook on a 6 speed car? I know, no DL will hook as good as a Bias Ply but just curious. Torn between them and the new Nitto NT555r2 . Nitto is claiming they are even better than the NT05R tires that come on the demon stock
Genfive427camaro is offline   Reply With Quote
Old 08-06-2020, 02:39 PM   #31
2NASSTY
2NASSTY's Avatar
Drives: 2014 M6 ZL1
The MT Street R is probably the best hooking and most consistent DR I’ve run. Bias Ply is great on absorbing the hit on a manual but does not MPH no where near a radial.
I would not even put Nitto in the same category as a MT Street R for the track or street. Technology has passed them by I believe.
Old 08-06-2020, 04:28 PM   #32
Genfive427camaro
Drives: 2015 Z28
I would have to agree, do you think the ET street R does better than the Hoosier DR2? I will be running 18 inch weld S71s on rear. They dont make a 18 inch Bias ply M/T so i am not even considering that. Hoosier will be a 26 inch tire and M/T is a 27 inch tall tire. I think personally the 26 might be a little short even tho mine is a Z/28 and has 26 inch tall tires on it now.
Old 08-06-2020, 05:41 PM   #33
2NASSTY
2NASSTY's Avatar
Drives: 2014 M6 ZL1
My personal best has been on the Hoosier DR2 335/35/17 which was a 26" tire. It is very inconsistent on hooking up unless there is great track prep and I run low tire pressure. It has serious MPH though with the gear ratio change compared to the 27" MT Street R 325/35/18 tire.
The MT Street R is more consistent off the line.
Old 08-06-2020, 05:54 PM   #34
Genfive427camaro
Drives: 2015 Z28
Gotcha! You are the man, i appreciate all your info.. I will most likely go with the ET Street R... Your ZL1 running 390 gear?
Old 08-06-2020, 08:17 PM   #35
2NASSTY
2NASSTY's Avatar
Drives: 2014 M6 ZL1
You're welcome Man. I think you will really like the Street R. No gear swaps are available for the ZL1 rear. I change gear ratio by going back & forth on rear tire diameter changes.
The 17" DR2 is 25.6". Th 18" Street R is 27". Things happen a lot faster on shorter DR2.
Old 08-07-2020, 12:07 PM   #36
Genfive427camaro
Drives: 2015 Z28
I gotcha! Thats awesome tho.. Good run and yes, i think i will like the ET street R better for my car especially with 390 gears in Z28
Old 08-10-2020, 02:42 PM   #37
Dutchman427
Dutchman427's Avatar
Drives: 2012 ZL1 #1329 M6
Way to go Chett!
2012 Camaro ZL1 #1329 M6 Summit White
Built by Mike @ Rapid Motorsports
784rwhp 757 rwtq on 93 Octane ET - 10.97 @ 128
Heads-Blower-Snout-TB ported & prepared by Jeremy Formato of FasterProms
http://www.camaro5.com/forums/showthread.php?t=395950
Rapid Motorsports 396ci Build
https://www.camaro5.com/forums/showt...1#post10321301
10.832 @ 130.99
Dutchman427 is offline   Reply With Quote
Old 08-11-2020, 02:07 PM   #38
2NASSTY
2NASSTY's Avatar
Drives: 2014 M6 ZL1
Thanks Andy!
Old 08-11-2020, 02:40 PM   #39
BiggFoot
BiggFoot's Avatar
Drives: 2010 Camaro (M6) 1000+ HP SBE
Nice run! It sux when you have a good run like that and you happen to draw a rocket in the opposing lane.
F-1X, Cog Drive, ATI Super Pulley/Sprag ~ 19 psi
Blower Cam
Brodix BP BR 3 Heads
Kooks LT Headers and full 3" exhaust
Fore Triple Pump Fuel System with ID 1700X Injectors - E85 conversion
DSS 9” Conversion (1400 hp axles, driveshaft, pumpkin) & Strange 3.70 gears
McLeod RXT Twin HD Clutch & Upgraded Slave
RPM Level VII
TR6060
BMR Drag Suspension Package w/Strange shocks
Carlyle 15" and M/T ET Street R radials
10.1 @ 143 mph 1/4 mile
BiggFoot is offline   Reply With Quote
Old 08-11-2020, 09:26 PM   #40
2NASSTY
2NASSTY's Avatar
Drives: 2014 M6 ZL1
Man who are you telling. I knew they Guy too. I wanted to back-out the staging lane. Fastest Demon in the Country. Real nice Racer. He cut me a break by just running Blower only. 9.0 at 150. I thought I ran a 11.5 hahahaha. Tried to run him down lol. Got a NPB and my ass handed to me all at once!!
Old 08-23-2020, 03:59 PM   #41
Big Biscuits
Big Biscuits's Avatar
Drives: 2010 1SS LS3
Man that’s some fancy driving. Congrats! What shift light are you running? Mine revs like a 2 stroke and it is hard to hit shifts soon enough.
2010 CGM 1SS
408/4L80E/ZL1
ESS G4
Big Biscuits is offline   Reply With Quote
