10-28-2016, 01:14 PM | #29 | |
Drives: 2016 1LT RS Camaro; 72 Chevelle Join Date: Apr 2008
My car has the standard small brakes. I believe they are 2 piston, but I'd have to look close. I know the rear brakes are single piston on my car. You can actually see a picture of the standard small brakes back on post #17 http://www.camaro6.com/forums/showpo...9&postcount=17 Last edited by Jason@JacFab; 10-28-2016 at 01:56 PM. |
10-28-2016, 04:22 PM | #30 |
Drives: Summit White 1LT RS I4 M6 Join Date: Oct 2016
Thank you Jason. I couldn't think of anything smaller than the 4 piston Brembos that would be sufficient for a Camaro. The other OE one looks too small :-(
Regards, Suresh |
10-28-2016, 08:20 PM | #31 |
Drives: 2016 Camaro RS 1LT 2.0L Turbo Join Date: Apr 2016
Well...to those who have the 4 pot brembos. Either taken from the SS or the GM upgrade kit....
How are they??? I have the stock 1LT base brakes and they do their job decently. SS takeoffs will be on my car someday. Love how we can use the hand me downs!
'16 1LT 2.0T RS - Catless DP, Intake, Tune/ Eibach springs FE3 shocks/ BMR front bar FE4 rear bar/ Xpel'd front end, CP Reload sealed/ Radenso Pro M.
10-29-2016, 07:36 AM | #32 | |
Drives: 2017 Camaro 2.0T RS Join Date: Jul 2016
I encounter no fade and push the car deep into the corners while braking on the late side... Very confidence inspiring; I think just fluid and maybe a pad with some more initial bite would make this setup track worthy. (wouldn't mind adding the brake cooling ducts though for added piece of mind) The brakes bite just as hard at the bottom of the hill as they do the top |
10-29-2016, 08:24 AM | #33 |
Drives: 05 GTO / JETTA TDI Join Date: Jan 2012
That is just sick on the Chevelle, great work!
10-30-2016, 02:12 PM | #34 |
Got the car back and after driving it for a 20 min there seamed to be much more braking then I remamber.
11-08-2016, 12:40 PM | #35 | |
Drives: NGM '16 2LT A8 Join Date: Feb 2014
I bought the calipers from a member on here but he didnt include the backing plate. Edit: I also got the rear calipers but no rotors or backing plate, do you have any mounting info on the rear? If it's different maybe ill have to get it from the dealer... |
11-08-2016, 01:25 PM | #36 |
I just got off the phone with the chevy parts guy and supposedly, all the dust shields are the same
They had 2 part numbers for the fronts, which one says "for track use" but both are for $66/pair And same number for rear at $44/pair |
11-09-2016, 12:09 PM | #37 |
From checking part numbers last week, I gather that the dust shields are the same also. I ordered the hoses and bolts, and in theory all I need to get is the rotors.
I'm hoping to try and bolt the calipers on in the next few days to make sure they bolt up to the stock caliper brackets before I order the rotors. |
11-09-2016, 02:41 PM | #38 |
Any idea what rotors or pads you're going to run? I have searched a few discussions on here but I'm not sold yet.
As of now I'm lookong into stock rotors and Powerstop Z26 pads (daily driver). Dealership was wanting $200 for the pair of rear pads lol |
11-09-2016, 03:24 PM | #39 |
The rear SS rotors are 140 each from local dealership
Might be a good idea to upgrade all 4 rotors all the way around. I plan on creating a Info post with everything was gather |
11-10-2016, 11:25 AM | #40 |
Here is a fun fact, at SEMA GM had a autocross car, in the front they had a the SS brakes and on the rear it was the stock non HD brakes, that tells me there is no need to update the rears.
11-10-2016, 04:39 PM | #41 |
I was doing it for aesthetics, not performance. It would look weird to me with nice powder coated brembo up front and cast brakes in the back
11-10-2016, 04:58 PM | #42 | |
For rotors, I'd be looking for Centric Stop-Tech Sport, but they don't seem to have them yet. Maybe the Power Stop brand? Good to know. I had no plans on updating the rears. That said, I may not even put the brembo's on the front if they won't clear my 17" race wheels. |
