12-14-2022, 04:34 PM | #29 |
Drives: ZL1/1LE parts added Join Date: May 2018
Location: Somewhere around Texas pines tress and smooth asphalt
It all depends on a person wallet, and what they feel comfortable with, I don't have a lot of money to flush down the drain, but also being a do it yourself mechanic, I have seen dealership and shops that do more harm then good. Get the cash and send them on down the road, but there are some great shops who pride themselves in doing remarkable work, for me being able to do your own work and know that you put the best parts in brings the ultimate satisfaction, I did it and saved a ton on labor, but I admit I would spend money were it benefits more, a 2650 will always put out more than expensive heads, and I'm not shotting for 1K hp, 750 to the wheel or less is plenty for a street car, heck 500Hp is enough. If your a track guy or drag racing go for it but remember your talking broken parts, tires clutches, and someone is always faster.
12-14-2022, 05:30 PM | #30 |
I could prepare a spreadsheet comparison, but I see a lot more in KaTech's pkg:
KATECH STAGE 3 GEN 6 ZL1 CAMARO 850HP PKG ROTOFAB BIG GULP INTAKE KATECH BILLET 103MM THROTTLEBODY KATECH CNC PORTED SUPERCHARGER BASE KATECH CNC PORTED SUPERCHARGER SNOUT GRIPTEC SUPERCHARGER PULLEY GRIPTEC SUPERCHARGER HUB KATECH 160 DEGREE THERMOSTAT KATECH K-FORCE 2 CAMSHAFT OR LT4 RACE CAMSHAFT CHE BRONZE VALVE GUIDES PSI 1511 VALVESPRINGS KATECH TOOL STEEL INTAKE RETAINER KATECH TOOL STEEL EXHAUST RETAINER KATECH STEEL INTAKE LOCATOR KATECH STEEL EXHAUST LOCATOR KATECH SPEC JOHNSON 2110-K LIFTERS TREND 3/8-0.080 PUSHRODS, MEASURE TO FIT GM LIFTER TRAYS KATECH C5R TIMING CHAIN KATECH VVT DELETE GEAR KATECH VVT DELETE GEAR STANCHION KATECH VVT DELETE GEAR BOLT KATECH VVT DELETE BILLET FRONT COVER KATECH CNC PORT CYLINDER HEADS KATECH CNC PORT CHAMBERS KATECH COMPETITION VALVE JOB, 5 ANGLE KATECH VALVE JOB BLEND DECK CYLINDER HEADS .010 GM GEN V LT4 HEAD GASKETS ARP HEAD STUD KIT ATI DAMPER ATI SUPERCHARGER PULLEY GATES SUPERCHARGER BELT KATECH BILLET AFM DELETE COVER GM BRAKE FLUID GM OIL FILTER MOBIL1 0W-40 OIL GM LS FRONT SEAL BRISK RACING 14 SPARK PLUGS GM DAMPER BOLT GM TORQUE CONVERTER OR FLYWHEEL BOLTS O2 PLUG WIDEBAND O2 BUNG O2 WASHER GM DEXCOOL GEN 6 CAMARO ZL1 KATECH SERIALIZED PLAQUE INSTALLATION BASELINE DYNO HPTUNERS CREDITS CHASSIS DYNO STREET DRIVABILITY CALIBRATION MISC SHOP SUPPLIES 1 YEAR, 12,000 KATECH LIMITED WARRANTY, SEE TERMS FOR DETAILS
'20 ZL1 1LE A10.
LME 390, E2650, FBO, 100 oct. Not a DD. |
12-14-2022, 06:46 PM | #31 |
I don’t have a dog in this fight but that’s not apples to apples at all.
12-14-2022, 07:18 PM | #32 |
Drives: 2021 Camaro ZL1 A10 Join Date: Jul 2021
I am not knocking any of the shops on here, but I will say this...... I choose my parts based on alot of research and feedback from forum users. Shop Labor is a big factor that really impacts a build. I have a parts selection from a lot of Vendors! I look at value and function...... One example is the LT4 VVT Delete Cover..... Sure LME has a beautiful product that should be encased in glass and adds a integrated seal but at $800.00 I opted for the TSP VVT Cover for $135.00. Do they do the same thing? Yes My advise is Do a Pro vs Con in comparing parts. I do have a Katech Oil Pump going in my build... Ever wonder why they are on back order most of time? Its a high quality part and the go to pump in these builds especially with the failure rate GM pumps had in the past years 2016-2017 (I believe). Just my two cents and opinion, every one is entitled to their own thoughts on the matter. Do the research and make smart decisions....
12-14-2022, 07:33 PM | #33 | |
Having FUN in the SUN...
Drives: 2022 M6 ZL1 1LE Join Date: Jan 2022
Great question... I would have also been hoping for closer to 100rwhp with that list, but as many have stated before, dyno numbers are only a tool. If the car does not feel strong enough, I suggest he look into an E85 kit... that would help alot with the current mod list. I can't speak to the TUNE of the car, but I assume that is a big factor. I assume based on their reputation that there tunes are more on the conservative side also. What I do know, is that they are a great shop, with great products and service, and that DOES come with an equivalent price. For those who are cheap like me, i would rather save on the labor costs and do it myself. But if money was not an issue, they would have been top of the list for a stage 5 package for the peace of mind. Tell your friend his numbers are not terrible, but on the lower side of what i am guessing is a 20-40rwhp range from car to car, day to day, dyno to dyno. So long the car pulls hard, keep on smiling. and start saving for round 2
2022 M6 ZLE: Katech Standard Ported Blower + Ported Heads + 103mm TB + Oil Pump + C5R Chain + Valve Covers + Coil Relocation Kit
TSP VVT and DoD Delete Covers + LME Chain Guide + DSX Billet Lid + ATI Damper + 9.17" Lower + 2.4" Upper + MM Wild Catch Can Coated AR Headers + GESI UHO Cats + V Bands + AWE Touring + Magnaflow Center X + MSD Coils + Banks iDash + JMS Booster ALL the BMR Read End Goodies + BMR Motor Mounts + JRE Terminator Cam Package + Big Gulp + GMS High Flow Crash Bar DMS Front HX + Fender Tank + FIC 30's + APEX SM.10's + TOYO 305/345 R888R's = 775rwhp 815rwtq @E55 13.5psi |
12-14-2022, 09:09 PM | #34 |
BanHamWatch
Drives: 21 ZL1 1LE Join Date: Jan 2021
Can I just get a free T shirt for staying out of this thread pls. That’s got to be worth something in this day and age of everyone has an opinion!!
2021 ZL1 1LE
Auto |
12-14-2022, 11:44 PM | #35 | |
Drives: 21 ZL1 Join Date: Feb 2022
12-15-2022, 08:28 AM | #36 |
83whp gain from baseline is about right for those mods with a stock blower on pump piss. Yeah you paid a lot of money for that extra power but just because you took the car to a big-name shop doesn't mean you will get Unicorn power out of it.
2016 NFG 1SS A8
12-15-2022, 08:30 AM | #37 |
Wheres the like button
12-15-2022, 08:38 AM | #38 | |
Well said... like i said, if the car doesnt meet his butt meter expectations, getting away from pump and using an E30-50 blend will really wake this bad boy up!
12-15-2022, 08:52 AM | #39 |
Drives: 2022 Rapid Blue ZL1 Join Date: Feb 2022
$10k is slightly overpriced for this build, but just parts cost alone is over $6k. They might be a little high with their price, but not for this amount of hate. KaTech makes really good parts, I will be putting their oil pump, C5.R timing chain, and 103mm TB on my build.
2022 M6 Rapid Blue ZL1
Performance: Kong X-Port OEM blower, 1 7/8" TSP headers (Polydyn coated), Corsa Intake/X-pipe/NPP Exhaust, LT5 95MM TB, DSX FlexFuel sensor, Dedicated Motorsports inline fuel filter / fender tank, Katech Dual fuel pump, WeaponX Boost freeze chiller, WeaponX center and aux HX, PWR oil cooler, Elite E-2X catch can, and Griffin Motorsports front crash bar. Tuned by Pat G 731 WHP on a Mustang Dyno. Suspension/Brakes: Eibach lowering springs, Vorshlag camber plates, Full SPL rear control arms, DSC Sport suspension controller, Blackwing F/R brake cooling ducts. |
12-15-2022, 09:19 AM | #40 |
Drives: 2017 Chevrolet Camaro ZL1 Join Date: Jul 2018
Is this not you comparing apples to oranges just because they both say "stage 3" as if there is a universal definition that every shop must use? Zach showed you they have a package that's like the stage 3 from RPM, but also includes ported heads for only $2k more... I'm still waiting for the proof of "2x more" that you claim across here and social media between them and Vengeance.
2017 ZL1 - PB 8.05 @ 172 MPH @ 3730 lbs @ 70 DA (work in progress)
Built by Vengeance Racing, tuned by Elite Tuned |
12-15-2022, 09:25 AM | #41 | |
And no those are very similar packages with the exception that SCAMTECH is porting the heads. Is that worth another $10k??? LOL hell no. |
12-15-2022, 09:29 AM | #42 |
So you still don't have proof? Just making up multipliers of 2x out of thin air... Got it.
