02-05-2015, 10:33 AM | #29 | |
Drives: 2011 ctsv Join Date: Sep 2013
02-05-2015, 10:50 AM | #30 | |
Drives: 2014 SS Join Date: Jan 2011
I thought you put a triple carbon in that? |
02-05-2015, 11:40 AM | #31 | |
Speed Freak
Drives: 2013 ZL1 Camaro, 2016 Camaro SS Join Date: Jun 2013
He didn't have a triple at the time and I needed a clutch ASAP.
I dropped the cash to upgrade to a quad carbon clutch, basically the same clutch the Ford GT that went 278mph in the mile is using, just in a Camaro housing. I'm hoping this will reduce my transmission heat and failures.... The slayer clutches are unbreakable.... they are expensive but they will hold whatever you can throw at them.
2016 SS -AGP twin Borg Warner 7163 EFR's, LT4 mechanical pump, LT4 injectors, Walbro 255 low side, Castrol SRF. 734whp/759 tq
2013 ZL1 -ADM - 427 LSX 6 bolt, O-ringed block built by LME. Twin PT6466 turbos. RPM custom manual trans, RPS Quad carbon clutch, 9" Hendrix rear diff & axles. ADM/squash fuel system, Ron Davis radiator, Spal fans, AGP air to air, turbo plumbing. LPE oil cooler, rear bushing upgrade, roll bar...etc. rwhp 1400+... 212.5mph, best Texas mile to date. |
02-05-2015, 11:49 AM | #32 | |
If you keep running into issues with those expensive carbon clutches give me a shout. I've got a one-time solution for you whenever you're ready. |
02-05-2015, 11:55 AM | #33 | |
would the double carbon be sufficient in a 700rwhp ctsv?? I was just looking at them now looks like the LT1sc should, is this a carbon clutch?? |
02-05-2015, 12:01 PM | #34 | |
Speed Freak
02-05-2015, 12:34 PM | #35 | ||
Our twin SC is a ceramic clutch variation and will easily work with your V and will hold that power without any issues at all. Quote:
Keep me posted on how that one works for you, I wish you'd have called me instead of forking out more money. |
02-05-2015, 12:50 PM | #36 | |
will the stock mc work or should I get yours?? what is the advantage with your release bearing suport?? thanks |
02-05-2015, 12:57 PM | #37 | |
C/C coefficient is around .28-.30, for instance, my ceramic is .38 and iron is over .40... that's a huge difference. The stock master works great. The release bearing support is billet steel instead of plastic which means it doesn't melt/fail like the stock unit does. The ceramic will work perfectly for what you have. If you feel that you will be slipping the clutch excessively in an aggressive manner then I'd get you the iron setup which works flawlessly. |
12-19-2015, 12:22 PM | #38 |
Drives: 2014 ZL1 Join Date: Dec 2015
ZL1 clutch failure
I recently purchased a 2014 ZL1 with 15,000 miles. Probably around 600rwhp at the moment. I noticed during a couple pulls last weekend that in 4th gear at high rpm's there was repeated slight hesitation, and what smelled like burning clutch. Do the factory clutches really go bad at the 600whp range? I realize the previous owner could be the issue......
12-19-2015, 08:25 PM | #39 |
Treasure Coast Camaro 5
ZR1 NO! Have it. It was the talk back in 2010-11 so I got it. Better ones out there!
12-24-2015, 07:02 AM | #40 |
Drives: 2013 Camaro ZL1 Join Date: Nov 2012
Replace it with a stock one. You'll love it
13 ZL1 A6
LSX 427 with AGP Twin Turbos, E85 and Flex Fuel. Built and tuned by ADM Performance 1000rwhp |
12-24-2015, 10:59 AM | #41 | |
ANGRY Z
Drives: 2015 Camaro ZL1 Join Date: May 2012
2015 ZL1 A6 396 stroker RWHP- depends on nitrous
01-10-2016, 11:26 AM | #42 |
Drives: 2010 Camaro SS Join Date: Oct 2013
I have the ZR1 clutch as well. Not real happy with it.
Excellent street manners but does not like to be beat on. Anyone know if I could use the ZL1 clutch with the ZR1 flywheel and slave?
2010 Camaro SS RS, Maggie with 3.4" pulley, 60# injectors, ADM dual fuel pumps, ADM Stage 2 Cam with Brian Tooley springs and pushrods, black CAI intake, Stainless Works long tube headers w/gutted cats, ZL1 Diff w/offset bushings, Pfadt lowering springs, Pfadt sway bars, Pfadt solid sub frame mounts, BMR trailing arms and toe rods, Hurst short throw shifter, Painted on Hugger Orange stripes, Forgestar F14 Piano Black wheels, Nitto NT05 rubber.
